SketchUcation Plugin Store
[Plugin] Area Formatting
Postby TIG » Mon Dec 03, 2007 12:48 am
This lets you format area text tags with any desired area format... For example you are working in mm but want areas in m2...
Read the notes at the start... Before picking the tool off the menu select what you want formatting or let it choose from 'everything' available...
I can't make it spot 'Millimeter 2' - the regexp seems to fail at recognising the superscript 2 whatever I try... Thus the script uses 'Millimeter ' etc... Any hints on how to fix this are welcomed...
It converts mm2, cm2, m2, in2 and ft2 into mm2, cm2, m2, hectares, sq in, sq ft, sq yds and acres; all as you might select from the dialog...
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: Area Formatting
Postby gullfo » Mon Dec 10, 2007 5:30 am
wonder if its one of those unicode things where you have to have the regex search for the specific character that looks like its superscript... U+00B2
gullfo
SketchUp version: 8
License type: Pro
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Return to Plugins
Users browsing this forum: denizmir, humblehome, jhonnysolano, plessis, raineysky, tiljanssen and 7 guests
