SketchUcation Premium Membership
[code] 3ds2obj.rb
[code] 3ds2obj.rb
Postby Jim » Wed Feb 17, 2010 6:14 pm
This is not a plugin - but a rudimentary code snippet that extracts data from a binary .3ds and outputs it to std out.
usage:
$ 3ds2obj.rb model.3ds > model.obj
Jim
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: [code] 3ds2obj.rb
Postby thomthom » Wed Feb 17, 2010 6:22 pm
You got hold of file format specs for 3ds?
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Jim » Wed Feb 17, 2010 6:23 pm
It is readily available online.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby xrok1 » Wed Feb 17, 2010 6:28 pm
thomthom, does it work, does it work?? :bounce:
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby thomthom » Wed Feb 17, 2010 6:34 pm
xrok1 wrote:thomthom, does it work, does it work?? :bounce:
A bit early to ask that. ;)
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jim » Wed Feb 17, 2010 6:35 pm
It appears there is a CAMERA chunk (0x4700), so if you can't find the format for that chunck, then you should be able to dump the chunk and view it in a hex editor to see if it can be deciphered.
So once the chuck is identified, it is followed by its length. this line gives you the number of bytes to read the rest chunk:
Code: Select all
when 0x4700
  puts "# CAMERA DATA"
  # NOT sure of the proper way to unpack?
  chunk_len = f.read(2).unpack('s')[0]
  chuck_len.times do
    # something?
  next
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Jim » Wed Feb 17, 2010 6:43 pm
Whoops, check that command-line example I gave for usage - I changed it.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Jim » Wed Feb 17, 2010 6:53 pm
getting closer..
Code: Select all
* 4700 - Camera
 Describes the details of the camera in the scene
 start end size type   name
  0     3   4   float  Camera pos X
  4     7   4   float  Camera pos Y
  8    11   4   float  Camera pos Z
 12    15   4   float  Camera target X
 16    19   4   float  Camera target X
 20    23   4   float  Camera target X
 24    27   4   float  Camera bank ( rotation angle )
 28    31   4   float  Camera lens
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Jim » Wed Feb 17, 2010 7:04 pm
I see , the camera is a fixed-length chuck so has no length - you just start reading the values:
Code: Select all
when 0x4700
        xpos = f.read(4).unpack('f')[0]
        puts "xpos:#{xpos}"
        ypos = f.read(4).unpack('f')[0]
        puts "ypos:#{ypos}"
        zpos = f.read(4).unpack('f')[0]
        puts "zpos:#{zpos}"
        next
Although strangely the values are close but not exact as:
Sketchup.send_action(10624)
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Wed Feb 17, 2010 7:05 pm
Ah, I see. It's a standalone ruby - not a SU ruby. have not looked at the code yet.
28 31 4 float Camera lens - what would this be then?
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Feb 17, 2010 7:08 pm
Jim wrote:I see , the camera is a fixed-length chuck so has no length - you just start reading the values:
Code: Select all
when 0x4700
        puts "xpos:#{xpos}"
        puts "ypos:#{ypos}"
        puts "zpos:#{zpos}"
        next
would this not be doing the same?
xpos, ypos, zpos = f.read(12).unpack('fff')
a one-liner.
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Feb 17, 2010 7:09 pm
Jim wrote:Although strangely the values are close but not exact as:
How close? Minor - something that could be explained by floating precision?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jim » Wed Feb 17, 2010 7:10 pm
thomthom wrote:would this not be doing the same?
Maybe - I'm in "make it work" mode. Optimize mode comes later.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Jim » Wed Feb 17, 2010 7:29 pm
Yeah, that's pretty much all there is to it. Make sure to read all the values; you can't skip them even if you don't use them.
I made a mistake when I said the values did not match - it works out no problem.
Code: Select all
when 0x4700
        puts "eye: (#{xpos}, #{ypos}, #{zpos})"
        tx, ty, tz = f.read(12).unpack('fff')
        puts "target(#{tx}, #{ty}, #{tz})"
        rotation = f.read(4).unpack('f')[0]
        puts "#rotation:#{rotation}"
        lens = f.read(4).unpack('f')[0]
        puts "#lens:#{lens}"
        next
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Wed Feb 17, 2010 7:37 pm
Jim wrote:Yeah, that's pretty much all there is to it. Make sure to read all the values; you can't skip them even if you don't use them.
Because of variable chunk length?
Jim wrote:I made a mistake when I said the values did not match - it works out no problem.
You managed to recreate an SU camera?
What's the lens value? AOV? FOV?
Global Moderator
SketchUp version: 8
License type: Pro
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Return to Developers' Forum
Users browsing this forum: No registered users and 5 guests
