[Plugin] Material Replacer (1.1.0) — 12 January 2010
• Page 1 of 2 • 1, 2
[Plugin] Material Replacer (1.1.0) — 12 January 2010Tools -> Material Replacer
Tool that let you replace materials by picking from the model. 1. Pick the material to replace 2. Pick the material to replace with Result: the first material is replaced with the second material in the entire model Please, register (free) to access all the attachments on the forums. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Should now be picking the material from the side of the face visible to the user.
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Thanks, I will test the plugin this weekend, it seems very interesting.
Your cookie: Please, register (free) to access all the attachments on the forums. Forgive my spanglish...
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010what a delightful virtual cookie.
Now... if I can only fit my monitor inside my mouth? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010In fact I was eating cookies while I was reading you, I have been working with my scanner all the week making pdfs for my work, and I couldn't resist the temptation to scan one cookie for you!
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Thanks TT! Trying to limit the number of new plugins I download, but this one looks useful!! Keep up all you great scripting efforts....it's definitely appreciated!
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Any plans to get an icon for this great plugin ?
Thanks agrazdi
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010definitely a time saver. thanks thom2
visit my blog: http://www.nomeradona.blogspot.com
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Don't yet tested but if I understand you are not obliged to pass with the bucket tool for have the eye dropper?
here my Proust's madeleine
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010I thought about an additional function in this plugin that may be useful for a lot of people.
The plugin would create several squares (or plans, or boxes) in the scene, in a separate place, maybe in separate tab. The of number of the squares (or plans, or boxes) it would be the same as the number of the materials in the scene. In each one of them it would be applied a material. The objective of this function would be the one of to join identical materials or to join similar materials in the scene, reducing the number of materials in the scene. That would aid a lot in the moment of preparing the materials for rendering. Another interesting function would be to erase all of the squares and to recreate all from materials purged. That would be very special for me. Please, think with love about this possibility.
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Another interesting thing would be if it was possible to change materials just in the selected objects.
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Thomtom huge thank you!
2 things that would make this script a dream come true: 1. To be able to make the 'first eyedropper click' a multiple one (with control key)- to select a set of materials to be replaced. 2. To insert material editor into the picture. I mean ability to select materials (to be replaced\replacement candidate) both in model and mateditor. Almost forgot: Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Excellent ideas!
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Very cool! Thank you!
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010I have a real need for something very similar to bagatelo's request.
I have a need that doesn't seem to fit "Select by Material" or "Material Replacer" or "Repaint" or "GlobalMaterialChange". In the development of my major models I was not very consistent with color application. As I've learned more and have gotten much more involved with rendering (TwiLight originally and now Thea) the actual colors are very important. What I would like to be able to do is select a material/color that is in the model from the materials dialog (or something like bagatelo's idea) and then be able to select all objects that have that color/material. Then I need to be able to isolate them so I can see what's been selected, and, finally, with all of these selected, I can change their color. But I need to know which objects, groups, components are that color so I don't accidentally change one that I don't want changed. Does anyone have an idea of how to do this or even if it could be done? "If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010One can select all entities that has material with the same colour.
However, this isolation - not quite sure what you mean there. You mean hide all other faces/edges? Can't think of nay other way to isolate. You do have the Hide Rest of Model feature in SU, but then everything would need to be inside a group/component - and the API doesn't let us upen up groups etc... Thomas Thomassen — SketchUp Monkey & Coding addict
That's what I don't know how to do: If I could select all the entities with the same color and then isolate only those entities I could see which ones had the "wrong" color so I could change it. Very belated update: Karen Walkerman has done just what I requested above. http://forums.sketchucation.com/viewtopic.php?t=31378 Thanks again Karen Last edited by Bob James on Sat Oct 30, 2010 10:01 pm, edited 2 times in total.
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010someone buy thomthom a cookie at base camp and take a picture of it
"...And if he says that one more time i'll punch him right in the throat" - Armstrong and Getty
My website http://dragoonprogramming.weebly.com/
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010I'm not going to Basecamp...
Bummer "If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Is it possible to change just the material of the picked face?
Can't you just paint it ?? TIG
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010The beauty of this tool - You don't have to open a component to change the material of the faces.
But it changes all the material in the whole model - not just the face You click on.
BUT your question was to change the material of the picked face ! You mean to change the material of the picked face INSIDE THE GROUP/INSTANCE ! It could be done... but I must leave it to others...... TIG
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Yes, inside the group or component. And only of that picked fase.
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010How do you install this plugin
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Open the zip file and drop the .rb file and the folder with it into the Plugins folder where SketchUp is installed.
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010It would be possible to create a function swap some materials? Something like this:
Imagine a blue box and a red ball. We play the plugin, we click on the box and after the ball, and the colors are reversed. It would be interesting too, if it were possible to exchange materials not in the whole scene, but only on selected objects. Thanks for this fantastic tool.
Re: [Plugin] Material Replacer (1.1.0) — 12 January 2010Is there any way we can use this plugin to replace a specific material [.skm]..that has been used in the model with vray materials [i.e. .vismats]...??
SketchUcation One-Liner AdvertsVertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
