[Plugin] ExtrudeTools - Full Set
Postby TIG » Thu Jan 21, 2010 5:35 pm
By popular request here are all of the Extrude Tools [current versions at the file's date-code] all collected into one RBZ archive.
Donations:
Are welcome by PayPal.com = info @ revitrev.org
The links to the tools' threads, containing explanations and notes etc are:
ExtrudeEdgesByEdges http://forums.sketchucation.com/viewtop ... 80#p166780
ExtrudeEdgesByLathe http://forums.sketchucation.com/viewtop ... 77#p184477
ExtrudeEdgesByRails http://forums.sketchucation.com/viewtop ... 86#p201286
ExtrudeEdgesByVector http://forums.sketchucation.com/viewtop ... 77#p216977
Note: from 20100212 the EEby... these scripts can only be downloaded from this thread in the archive set found below...
Two new tools added 20100212...
ExtrudeEdgesByFace http://forums.sketchucation.com/viewtop ... 18#p224218
ExtrudeEdgesByRailsByFace http://forums.sketchucation.com/viewtop ... 19#p224219
New tool added 20100219...
ExtrudeEdgesByFaces http://forums.sketchucation.com/viewtop ... 49#p226249
New tool added 20100309...
ExtrudeEdgesByLoft http://forums.sketchucation.com/viewtop ... 16#p231016
New tool added 20100428
ExtrudeEdgesByRailsToLattice http://forums.sketchucation.com/viewtop ... 39#p242239
New tool added 20110524 and 20110525
ExtrudeEdgesByVectorToObject http://forums.sketchucation.com/viewtop ... 59#p331059
ExtrudeEdgesByOffset http://forums.sketchucation.com/viewtop ... 03#p331303
Two tools now have 'Quad Faces' options to complement Thomthom's Quad-Tool
20111003/04
20111020 update includes new ES lingvo files and a minor db correction to EEbyLathe
20111023 update now only smooths mesh edges with more than one face in EEbyLathe/..Faces/..Loft and ..Rail
20111102 update EEbyLathe - Fixed Picked-Angle's messy undo. Smoothed-edges now stop @90º.
20111113 There are two tools updated so that the 'Quad Faces' options to meet Thomthom's revised spec for Quad-Tool's 'quad-faces'...
Built-in method 'group.copy' method replaced to avoid clashes with some rogue scripts that mess with built-in methods, in six of the scripts
The Tools should now appear in the 'Plugins' Menu 'Extrude Tools' submenu and also on an 'Extrude Tools' toolbar, which you might need to activate from the View > Toolbars menu item...
If you have an earlier installation of the tools, which had some other .rb files within the Plugins folder and some support files inside the 'TIGtools' folder then these are automatically removed as the new toolset is installed, and equivalent files are added into the new locations...
None of the various tools' basic processes have changed in this upgrade.
It has been done to rationalize the location of files, make the code more robust and it also anticipates possible future changes to the way plugins might work to avoid issues in the coming months... Because it deletes some old files from earlier versions you might get error messages, and it's now an Extension you'll need to restart SketchUp to register it and activate it... Restarting SketchUp should resolve these issues [you will need FULL security permissions to your Plugins folder to add the file and make the possible deletions]
Latest update resolves some issues with 'TIGtools' folder tidy up, and require 'extensions.rb'... :roll:
Enjoy :ugeek:
To download the toolset's latest RBZ archive find its listing/download-link at the 'SCF PluginStore' page:
Download
then for >=v8 use the Preferences > Extensions > Install... button...
OR you can AutoInstall it using the 'SketchUcation Plugin Store' dialog within SketchUp itself...
http://sketchucation.com/resources/plug ... download...
For earlier SketchUp versions <v8M2 add .ZIP on the end of the RBZ file's name and extract its contents into the Plugins folder manually. The top-level .rb file should go directly into the Plugins folder: the other files [rb, lingvo, png etc] must stay in the 'ExtrudeTools' subfolder, inside Plugins.
Individual tools with the subfolder can also be disabled as desired, by adding a ! to the end of their .rb suffix... Then those won't load or make a menu/toolbar command.
31
Global Moderator
Re: [Plugin] ExtrudeTools - Zipped Set
Postby erikB » Thu Jan 21, 2010 6:02 pm
Tig,
I already installed them from the separate threads, and they work like a charm (including the toolbar.
Thanks very much for these exellent tools. :thumb: :!:
erikB
erikB
Postby mitcorb » Thu Jan 21, 2010 6:26 pm
I agree with Jim, and thank you for providing this as a set. Of course, I did not see this thread until after I batch unzipped the separate ones and looked at New Posts.
mitcorb
Top SketchUcator
Postby DIEGO-RODRIGUEZ » Thu Jan 21, 2010 6:37 pm
very good contribution tig. as ever.
greetings and thank you very much
DIEGO-RODRIGUEZ
Banned
Postby thomthom » Thu Jan 21, 2010 6:44 pm
I agree with Jim - offering these tools as a single package only seem easier for everyone. Very nice tool set. :thumb:
PluginStore Author
PluginStore Author
Postby haynesc » Thu Jan 21, 2010 8:59 pm
could some video tutorials ala chris fullmer ... explaining when its best to use which tool over the other one for us mere mortals and explain how exactly they work ... that'll be great
haynesc
Postby TIG » Thu Jan 21, 2010 10:07 pm
haynesc wrote:could some video tutorials ala chris fullmer ... explaining when its best to use which tool over the other one for us mere mortals and explain how exactly they work ... that'll be great
So much to do... so little time...
Any volunteers ? :D
Global Moderator
Postby thomthom » Thu Jan 21, 2010 10:22 pm
We should hire Chris to do a weekly video of a Featured Plugin. :D
"Featured" being picked by bribery of course. ;)
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Thu Jan 21, 2010 10:33 pm
Thats odd, I was just off playnig with another of TIG's plugins thinking about how it could use a good tutorial made for it. Perhaps it is time to dig in and start doing more script videos. They do get a lot of hits on Youtube. And I get hate mail from people saying I don't speak clearly enough. But the crickets, kids and dishes being washed in the background are big hits! :)
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby TIG » Thu Jan 21, 2010 10:36 pm
Perhaps we need to start a Plugin Video Tutorial thread ?
We could determine which ones would be suitable for them and swap tips on how best to do it ?
:mrgreen: :geek: :ugeek:
Global Moderator
Postby thomthom » Thu Jan 21, 2010 10:37 pm
Chris Fullmer wrote:And I get hate mail from people saying I don't speak clearly enough.
:?: :shock: Really? I've always thought you spoke very clearly in your videos. (They should hear me talking - then they'd shut up!) I have several times considered to offer to hire you to do some videos.
PluginStore Author
PluginStore Author
Postby pilou » Thu Jan 21, 2010 11:12 pm
That is the cherry on the cake! :fro:
Top SketchUcator
Postby boofredlay » Thu Jan 21, 2010 11:13 pm
Chris, you need your own band playing while you do your tuts :)
boofredlay
Global Moderator
Postby Arc » Fri Jan 22, 2010 3:41 am
Here is video I created tut use EEBR.
Arc
Premium Member
Premium Member
Postby TIG » Fri Jan 22, 2010 9:04 am
Arc wrote:Here is video I created tut use EEBR.
Arc - it's reporting as 'blocked in your region' - at least in the UK...
Global Moderator
Postby sunchart » Fri Jan 22, 2010 10:00 am
Thank u very much.
sunchart
Postby thomthom » Fri Jan 22, 2010 10:02 am
And I get just a white square. (Norway)
PluginStore Author
PluginStore Author
Postby TIG » Fri Jan 22, 2010 11:50 am
Pilou has updated all 4 of the FR lingvo files - they'll be included in future updates but if you want to install them straightaway then download this zip file and extract the 4 files into ../Plugins/TIGtools/ and overwrite any earlier copies...
Tip: If you want the FR language for the tools' dialogs and prompts etc BUT have your locale set to another id - e.g. EN-US - then simply rename the file with that suffix and it'll be used... e.g. XxxxFR.lingvo becomes XxxxEN-US.lingvo
Global Moderator
Postby Arc » Fri Jan 22, 2010 5:25 pm
Now I upload video on youtube.
Arc
Premium Member
Premium Member
Postby TIG » Fri Jan 22, 2010 5:30 pm
Arc wrote:Now I upload video on youtube.
Thanks, it works fine now - a quick and useful insight into just one way of using EEbyRails... :D
Global Moderator
Postby Gaieus » Sat Jan 23, 2010 10:35 am
And it's a cool video, too! :thumb:
First I thought I would hate that there is music with it but then I even liked it!
:D
Postby MALAISE » Sat Jan 23, 2010 10:40 am
Hurrah for TIG :ecstatic:
MALAISE
MALAISE
Postby TIG » Sat Jan 23, 2010 5:16 pm
viewtopic.php?p=217663#p217663
Is the latest update - the main changes are updated lingvo files and in EEbyR a picking order glitch has been fixed.
See the individual tools' threads' links for more details... :enlight:
Global Moderator
Postby mitcorb » Sat Jan 23, 2010 5:29 pm
@Arc:
Nice video!!! Music was pleasant enough, just not my style :)
Would love to see the process between the completion of the crescent and the final product, perhaps in another thread.
mitcorb
Top SketchUcator
Postby jeff hammond » Sat Jan 23, 2010 7:07 pm
TIG wrote:http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
hey TIG,
is the zip updated as well?
personally, it's easier to update the entire suite instead of individually (even if only one of the tools have been updated) because i can just overwrite everything instead of having to open the TIGtools folder and only overwrite certain files.
dotdotdot
jeff hammond
Global Moderator
Postby TIG » Sat Jan 23, 2010 7:12 pm
hey TIG,
viewtopic.php?p=217663#p217663 links to a zip of everything current today [in this thread] - see the suffix on zip's name... This time I also updated each tools' thread too - from now on I'll probably keep the combo zip up to date, and then remove any zips from the four tools' threads - bt keeping the threads' links for the tools' instruction/version-info parts only...
So there's no need to get the other tool zips... IF you get the combo-zip here viewtopic.php?p=217663#p217663
Global Moderator
Postby jeff hammond » Sat Jan 23, 2010 7:19 pm
TIG wrote:[
cool, thanks
i think that's the best way to keep everyone up to date. (vs 4 individual threads/tools)
dotdotdot
jeff hammond
Global Moderator
Postby driven » Sat Jan 23, 2010 7:40 pm
Cheers TIG,
zip Combo works first time out on the Mac, great to see them altogether now, well done...
still get the 5th button? maybe Jeff could see if it replicates on his Mac.
Jeff, if I open SU with the toolbar off, and then open it I get 4 EEby... tool buttons, if I open SU having not turned off EEby...TB before quiting, I get a 5th button, it does nothing except changes colour, everthing works if it's there or not, would you mind checking before I fresh install everything again? it might be a Mac thing...
john
driven
PluginStore Author
PluginStore Author
Postby notareal » Sat Jan 23, 2010 7:41 pm
Thanks, It's good to have just one archive that is needed to load.
notareal
Thea Render Support
Thea Render Support
Postby jeff hammond » Sat Jan 23, 2010 8:28 pm
driven wrote:Cheers TIG,
john
i can't replicate it.. i always get only 4 toolbar buttons no matter what i do.
i've done it on a PPC/tiger/SU6 & intel/leopard/SU7.
could there be a conflict with another plugin causing this?
dotdotdot
jeff hammond
Global Moderator
Next
Return to Plugins
Users browsing this forum: ChairilAnn, Huongdx, syukio and 14 guests
