[Plugin] Stick groups to mesh ver. 1.2.
Postby kirill2008 » Wed Dec 23, 2009 9:27 pm
mshstick.rb
Description:
Plug-in, which deforms selected group of faces to follow the selected surface
How to use:
1) put “mshstick.rb” to “Google SketchUp 6\Plugins” folder
2) start SketchUp 6
3) select some groups of faces, which you want to stick to another group of faces (surface mesh)
4) choose the command "Plugins>>Stick selected groups to mesh group" command from the main menu
5) pick the group with mesh, to which you are going to stick selected groups
ver. 1.0. demo video:
Known limitations:
- the current vesion (1.0) processes correctly only terrain-like* 'rulling' surface mesh group (* only one z for each x,y)
- ver. 1.0. has only vertical 'sticking' direction (script projects vertices of selected groups normaly to the XY plane)
- ver. 1.0. processes only geometry of selected groups (discards materials information)
ver. 1.1.
functions added:
- ability to choose stick direction added (only parallel to main axises yet)
- "Stick type" option added (allows to switch between "normal" and "super" stick type)
- ability to cancel process added (by hitting <Esc> key)
- ability to process almost any kind of ruling surface (solid-like surfaces are also supported now)
bug fixes:
- undo performance improved
ver. 1.1. demo videos (set of 4 ones):
ver. 1.2.
functions added:
- ability to specify free vector as stick ray direction (has not to deviate from preset direction much if stick type option is set to 'Normal')
- 'Skip edges projection stage' option added (it is useful if sticking group(s) has(have) enough dense mesh or it is necessary to leave the initial vertex count of sticking groups for some reason)
- 'Reflection ray' option added (refer to the video for more information)
- 'Offset value' adjustment value added (allows offset of sticked groups from the ruling surface)
- 'Magnify' adjustment value added (a kind of scale coefficient for 'reflection ray' vector length)
ver. 1.1. demo video:
known issues:
- groups transformations such as scale and rotate process still insufficiently (so it is necessary to explode 'em and regroup before sticking)
kirill2008
PluginStore Author
PluginStore Author
Re: Stick groups to mesh ver. 1.0.
Postby Jim » Wed Dec 23, 2009 9:32 pm
Incredible! You've just made a lot of people very happy! Thanks for all your great work. :thumb:
Jim
Global Moderator
Postby mitcorb » Wed Dec 23, 2009 9:41 pm
There you go again! Unbelievable.
It is obvious you have a very good command of the Ruby language and the inner workings of Sketchup. Congratulations. I definitely will want to try this gem.
mitcorb
Top SketchUcator
Postby EarthMover » Thu Dec 24, 2009 2:02 am
:o :o :o The possibilities!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :sketchstatic: :sketchstatic: Thanks for the amazing scripts you are writing.
I would like to see the possibility of "timing out" your scripts with the escape button like Fredo has in the Round corner plugin. Especially with the scripts that take a long time to process. It would be a big help.
It's amazing how you manage to allow the script to run while the user is still able to rotate and move around the scene. I think that's unique to your last two scripts.
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby d12dozr » Thu Dec 24, 2009 5:41 am
I can foresee super-easy snow additions...Thanks, Kirill!
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby Khai » Thu Dec 24, 2009 6:21 am
oh gods...
wiring, cables, armour plating..... :twisted:
Khai
Postby urgen » Thu Dec 24, 2009 8:17 am
....красивая работа Kирилл! :thumb: ...nice work! thanks! :D
--pupil forever...------
urgen
Re: [Plugin] Stick groups to mesh ver. 1.0.
Postby remus » Thu Dec 24, 2009 8:32 am
Its like super-drape :D
remus
Postby kirill2008 » Thu Dec 24, 2009 9:18 am
EarthMover wrote:I would like to see the possibility of "timing out" your scripts with the escape button like Fredo has in the Round corner plugin. Especially with the scripts that take a long time to process.
Yes I agree it is _necessary_ to add :thumb: . I think it's number 1 feature in my list of updates for all 'long-lasting' scripts.
EarthMover wrote:It's amazing how you manage to allow the script to run while the user is still able to rotate and move around the scene.
Actually it is not my achievment. It is already implemented ability of sketchup API (so called 'timer' works such a way). You know, as for me, I'm amazed at the sketchup itself
(as well as it's nicely documented API).
kirill2008
PluginStore Author
PluginStore Author
Postby MALAISE » Thu Dec 24, 2009 9:47 am
Hi Kirill,
You've done a new incredible tool. Now making Dali's like watches will be very easy :D .
Best Wishes for 2010
MALAISE
MALAISE
Postby Rich O Brien » Thu Dec 24, 2009 10:26 am
This is a most welcome addition to your already impressive collection of plugins.
Thank you and merry Xmas and a happy new year to you
Rich O Brien
Administrator
Postby kirill2008 » Thu Dec 24, 2009 10:27 am
MALAISE wrote:Now making Dali's like watches will be very easy :D .
Well, actually the initial idea of the script was to stick some master plan elements (paving, roads, grass etc) to the terrain surface (
boring, isn't it?), but why not stick watches too?
I think it is necessary to make some enhancements to the script (materials support, optional sticking direction etc) to make it more flexible than just master plan elements 'sticker'.
kirill2008
PluginStore Author
PluginStore Author
Postby mitcorb » Thu Dec 24, 2009 4:50 pm
Kirill:
Your openness to suggestions is a wonderful trait, which seems to be shared by all of the Ruby masters in this forum.
May you and all here have a joyous season!
mitcorb
mitcorb
Top SketchUcator
Postby EscapeArtist » Thu Dec 24, 2009 8:51 pm
To sum up:
Dude, you rock! What a great plugin.
EDIT: I seem to find a way to break your plugins! Same as my comments about the "add control points" plugin, I applied the plugin, undid the action, and then tried to reapply it. Now I have the rapidly scrolling error messages in the Ruby window the don't stop, and a pop-up error dialog that says "It is necessary to select some groups of faces before calling the command".
Only fix is to restart SU.
Code: Select all
Error: #<TypeError: reference to deleted Group>
L:/Modeling/Sketchup Google/Plugins/ctrlpnts.rb:214:in `entities'
L:/Modeling/Sketchup Google/Plugins/ctrlpnts.rb:214:in `deform_group'
L:/Modeling/Sketchup Google/Plugins/ctrlpnts.rb:213:in `call'
(eval):892
(eval):892
(eval):892
(eval):892
(eval):892
(eval):892
PS: I love watching these scripts work, it's like watching Jeff Bridge's character get digitized in Tron.
EscapeArtist
Top SketchUcator
Postby charly2008 » Thu Dec 24, 2009 11:55 pm
Hi Kirill,
What a great plugin. An incredible tool. But it doesn't work in Sketchup 7.
Karlheinz
charly2008
Postby Chris Fullmer » Fri Dec 25, 2009 5:58 am
Awesome Kirill, glad you wrote this. This script has been the "next script" on my list to do for a long time, and I have just never quite got around to figuring it out. Saved me a lot of headaches :)
Seriously, very cool script!
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby kirill2008 » Fri Dec 25, 2009 7:45 am
EscapeArtist wrote:EDIT: I seem to find a way to break your plugins! Same as my comments about the "add control points" plugin, I applied the plugin, undid the action, and then tried to reapply it.
Undo performance correct handling is my headache
. I promiss to fix it.
EscapeArtist wrote:PS: I love watching these scripts work, it's like watching Jeff Bridge's character get digitized in Tron.
A kind of retro-futurism
UPD: I mean real-time sticking would look much more impressive, of course. Just imagine: you see neither '>' sign moving left-to-right, nor Jeff Bridge's digitizing characters after picking a surface, just _immediately_ sticked geometry group. It is possible for sure (and maybe already exist in some other modeling soft), but demands a bit low level coding, I guess.
I believe, SU developing team will take in account an interest of SU community and will add similar tool in future versions of SU (at least in pro version).
a bit off-topick: http://www.youtube.com/watch?v=jz8QWDBYn5w
kirill2008
PluginStore Author
PluginStore Author
Postby kirill2008 » Fri Dec 25, 2009 8:08 am
Chris Fullmer wrote:Saved me a lot of headaches :)
I must say, that the most brain-damaging part was addition of edges projections of 'ruling' surface to the group
. Finaly I recalled, that sketchup API has the very powerful built-in method (it actually has a plenty of) for entities collection 'entities.intersect_with'. The rest part was more or less obvious.
So actually almost all 'housekeeping' details SU handles itself :thumb: .
kirill2008
PluginStore Author
PluginStore Author
Postby pp1357pp24 » Fri Dec 25, 2009 2:20 pm
thank you,I need for my model
pp1357pp24
Postby jerome » Sat Dec 26, 2009 2:20 am
charly2008 wrote:Hi Kirill,
Karlheinz
Dear charly2008
It's work fine in my sketchup 7.1.
jerome
Postby driven » Sat Dec 26, 2009 3:43 am
Merry Xmas, New Year, etc...
Kirril, works on OSX10.5.8 + 7.1, however, 3D text needs to be exploded and regrouped, and it seems to prefer, grid patches made with sandbox, or I get issues.
but that's fine because it is so neat (and I don't mean in the corny American way), it is tidy, precision engineering tidy, 3D stainless steel printing tidy, fantastic, I certainly hope Santa bought you something nice.
Anyway heres my test, on a torrus, with a material I made using blend(dot)rb, I'll put a You tube Texture anim up tomorrow. I want to make fire in sketchup... for some reason.
all the best
john
driven
PluginStore Author
PluginStore Author
Postby notareal » Sat Dec 26, 2009 10:33 am
:o Really cool plugin! Happy holidays!
notareal
Thea Render Support
Thea Render Support
Postby charly2008 » Sat Dec 26, 2009 1:16 pm
Hi Jerome,
You're right, it works. It was my fault. But I noticed the changing of the selection frame.
Karlheinz
charly2008
Postby fredo6 » Sat Dec 26, 2009 4:33 pm
Kirill,
The plugin seems very powerful, but I can't make it work on SU7.
The progress bar appears but seems to block (at 12%).
I am just trying to stick a cube on a dome.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby driven » Sat Dec 26, 2009 5:55 pm
Fredo,
I had to zero out smoothing on the recipient mesh first, and on some of the SU shapes, I also found using 'add-detail' from sandbox seemed to make a difference.
don't know why it worked, but I've been trying to apply 3D text to curved tubes for ages and kept at it till it worked.
Oh, I also grouped a much smaller patch, just bigger than the text footprint. as the recipient and that speeds it all up.
on the mac with 7.1 it was slower than the video implies and I don't seem to get as much shown on screen, but the end result is great.
I need this to be 'watertight' for STL export and I had very little internal clean-up to do.
cheers again Kirill
Any chance of utilising this method in a booleen tool, I can't get as clean an intersection with anything I've tried on a mac
driven
PluginStore Author
PluginStore Author
Postby kirill2008 » Sat Dec 26, 2009 8:28 pm
driven wrote:Anyway heres my test, on a torrus, with a material I made using blend(dot)rb, I'll put a You tube Texture anim up tomorrow.john
Actually I'm surprised a lot that it works for torus. The 1.0 version does not check if each face of ruling surface is the first one intersected by 'sticking' ray (but it has to perform such checking for the surface that is not terrain-like, I'm on my way to implement the mentioned checking).
So the only explanation is that torus faces near the text group were occasionally processed before other torus faces and other faces were occasionally ignored, or maybe a part of torus surface that is the most close one to the text was grouped and used as a ruling surface, as in the following video:
http://www.youtube.com/watch?v=8EB68JdEJSo
So the sticking result does not depend on smoothing, but on surface geometry.
Everything is more or less obvious, but demands a bit of additional work to make the result of script processing more expected one, you know principle of least surprise (POLS)
kirill2008
PluginStore Author
PluginStore Author
Postby driven » Sat Dec 26, 2009 8:58 pm
kirill2008 wrote:torus surface that is most close one to the text was grouped
Kirill
Exactly, on the mac I also re-surfaced the mesh and added detail with sandbox first, my model torus is 128 segments x 32 sides, so making a small patch is essential, experimenting with tube intersections now, had a couple of crashes, but I'm just playing around between domestic chores today, so maybe I'll have more luck later on.
john
driven
PluginStore Author
PluginStore Author
Postby driven » Tue Dec 29, 2009 6:27 am
actually, I can report there's some sort of issue if I've used blend before trying to use this,
it's as if blend hold's on to a required file or path or something
if I quit and retry it works fine, only seems to be blend, but it may of been the problem the other day after I'd used CLF_SimpleLoft and 2Faces+path
I wasn't looking for a clash, but this is repeatable... nothing shows up in ruby or mac console, and I can't read the SU logs although I do have them.
cheers
john
driven
PluginStore Author
PluginStore Author
Re: [Plugin] Stick groups to mesh ver. 1.1.
Postby driven » Sat Jan 02, 2010 3:02 am
Hi Kirill,
1.1 is even better, but I guess that's the point... well done.
I think anyone on the mailing list may have not know about the update yet because your edit of the top frame doesn't appear to send a 'new message' notification and I got a you tube 'new movie' email and came looking for it.
been playing with using it to apply decals, etc to objects. You can sort of do it with photo textures, but grouped or imbedded geometry is way nicer, and easier to change materials, so I'm very happy.
The text is single surface, no thickness
On my first test, which I binned (because it had a typo) I used- Yes check for non terrain, Front and Super, when it was cooked (much faster now) I exploded both groups, smoothed, softened and textured. I then did a volume check and there were no holes at all, perfect first time, except for the typo.
I binned it, changed the font and size, same settings. When cooked it sat off the surface (.25), with one end further away then the other? so I went though everything I could think of until I eventually got one that was almost right, added .002 thickness and merged that.
Nowhere near as nice as the first so I tried scaling down the text used the original settings and ended up with a perfect profile sitting exactly in the other surface, but I couldn't the two to intersect, so this one is actually .00025 in front off the drape ( so that you can see ti from all angles) and it's still grouped separately unlike the first.
EmbroidedCurtainAnyone.skp
driven
PluginStore Author
PluginStore Author
Postby kirill2008 » Sat Jan 02, 2010 10:46 pm
driven wrote:Nowhere near as nice as the first so I tried scaling down the text used the original settings and ended up with a perfect profile sitting exactly in the other surface, but I couldn't the two to intersect, so this one is actually .00025 in front off the drape ( so that you can see ti from all angles) and it's still grouped separately unlike the first.
Hi, Driven.
It is strange, but I did not provide processing of the group with zero thickness, but it is necessary to do it.
In the current version (1.1., 1.2.), it is possible to process zero-thickness groups, but bounding boxes of such groups has to have a non-zero thickness (it is possible if rotate a bit a flat group, then explode it, then regroup again).
mshstick 1 2 balls.skp
I promise to fix the problem to stick flat groups without any additional labor.
kirill2008
PluginStore Author
PluginStore Author
Next
Return to Plugins
Users browsing this forum: Gubjkbbkn and 10 guests
