[Plugin] STL Importer/Exporter
Postby Didier Bur » Wed Dec 16, 2009 10:56 pm
Here is the latest version of SU2STL 1.3.:
- complete units support
- export faces/groups/components, at unlimited nesting levels
- much much faster than previous version
- skips null or flat triangles
- no more special su2stl layer left after completion
Unpack in plugins folder. PDF doc included.
Regards,
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: [PLUGIN Update] STL Importer/Exporter
Postby TIG » Wed Dec 16, 2009 11:37 pm
The English version seems to be missing a rbs file ? :?
Global Moderator
Postby Didier Bur » Thu Dec 17, 2009 7:31 pm
:oops: :oops: :oops: Fixed.
Didier Bur
Didier Bur
Postby DIEGO-RODRIGUEZ » Thu Dec 17, 2009 7:47 pm
thank you very much for sharing.
Could make the menu visible, in order to personalize it.
the plugins *.rbs , and menu of plugins *.rb
DIEGO-RODRIGUEZ
Banned
Postby blixten » Tue Feb 22, 2011 11:34 pm
It would be nice if it was possible to select STL-format (ASCII or binary).
Not only will binary format be a smaller file. But wouldn't it also have more accurate values?
Since you avoid translating the values to ASCII when exporting, and back to float when importing.
blixten
Re: [Plugin] STL Importer/Exporter
Postby ElijahPost » Fri Oct 14, 2011 5:06 pm
Totally doesn't work for me. I could very well be doing it wrong, but when I open SU 8 It's as if nothing ever happened. Am I missing something?
ElijahPost
Postby Didier Bur » Sat Oct 15, 2011 8:40 am
What do you mean ? No menu ? Plugin does nothing when called ? No STL exported ?
Please describe your problem more precisely so I can help ;)
Didier Bur
Didier Bur
Postby Phemto » Tue Nov 29, 2011 1:19 pm
It looks like ElijahPost went dark. Maybe he found the solution himself and was too embarrassed to say just how obvious it was. I, on the other hand, have no shame. I've installed the files from the zip file in the plugin directory of sketchup 8. When I open the program, there's just one problem. I can't find the "plugins" menu item.
Phemto
Postby tomasz » Thu Jan 19, 2012 9:13 pm
Thank you Didier for the exporter! If a price of a printed model won't stop me from printing, I will post a picture of it.
tomasz
SU2TH & SU2KT Developer
Postby hackaddict » Sat Oct 06, 2012 12:17 am
I can't get this to work. I have sketchup 8 and am running mountain lion (osx). I drop the rbs into the application's plugins folder (right click on sketchup and select "show package contents" - then I navigate to the plugins folder). When I relaunch sketchup there is no plugins menu available and when I go to preferences>extensions nothing new shows up. Thoughts?
hackaddict
Postby TIG » Sat Oct 06, 2012 10:23 am
Because the tools are auto-loaded from a RBS file it will load after all of the RB files in the Plugins folder, therefore the tool's two Plugins menu items will appear at the end of the list.
So did you scroll to the very bottom of the menu after the restart of SketchUp?
If so and it's still not there after a restart then you have almost certainly mis-installed the RBS file.
On a MAC the correct location is the 'plugins' folder in the Macintosh HD/Library... NOT the similar folder in the 'User' path...
Typically it should be something like Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins/
It should never have 'User' in its path.
However, if you have elected to install SketchUp in a non-standard manner then your detective work will be harder...
Try a copy+paste +<enter> on these two lines into the SketchUp Ruby Console: they will return the full path to the installed 'plugins' folder - as a double check the second one finds a pre-installed script that should be in that folder too...
Sketchup.find_support_file('plugins')
and then
Sketchup.find_support_file('ocean_extension.rb', 'plugins')
Treble check that your files have been put into the correct folder and restart SketchUp and then look at the end of the Plugins menu...
Report back :?
Global Moderator
Postby danrochman » Tue Feb 12, 2013 7:00 pm
Just wanted to add a quick reply for two reasons:
1. THANK YOU FOR CREATING AND SHARING THIS!! :)
2. I just installed the English version on Windows 8 (64-bit), with Trimble SketchUp 8. I haven't tried exporting yet, but installation was effortless, and I've tested the STL import function - no issues so far. If anyone's wondering, the default plugins path (for me) was "C:\Program Files (x86)\Google\Google SketchUp 8\Plugins\". [Yes, it's Trimble's app now, but the path is still Google's. :)] So for any who may be wondering, this plugin seems to be working fine with the latest versions of Windows & SketchUp. Thanks again, Didier Bur!
danrochman
Postby thomthom » Tue Feb 12, 2013 11:20 pm
FYI, there is a newer STL import/export project, open sourced by the SketchUp team over at: https://github.com/SketchUp/sketchup-stl
PluginStore Author
PluginStore Author
Return to Plugins
cron
Users browsing this forum: filipecadu and 9 guests
