[Plugin] Heightmap from model
Postby Didier Bur » Wed Dec 16, 2009 10:25 pm
Hi all,
After a long silence, here is another toy I wrote to export SU terrains to Unity3D game engine, which uses RAW heightmaps to create terrains. I thought it could be of any interest to others, so here it is.
Features:
- creates BMP or RAW images, greyscale or color, 8 bits or 16 bits from any view of your model (top view recommanded of course)
- creates a colored mask where no faces found in the view
- can crop the image to the model projection
- can blur the heightmap before writing it.
Extract in Plugins folder, PDF doc included.
Regards,
EDIT: new release May 5th 2010, instant bugsplat fix :P
Get the latest version from the PluginStore
Download
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: [PLUGIN] Heightmap from model
Postby thomthom » Wed Dec 16, 2009 10:28 pm
That is interesting. Could probably use the generated image as displacement texture in render engines.
PluginStore Author
PluginStore Author
Postby CadFather » Wed Dec 16, 2009 11:06 pm
Thanks Didier, very interesting and good to see you around.. :thumb:
CadFather
PluginStore Author
PluginStore Author
Postby Gaieus » Thu Dec 17, 2009 8:48 am
Hi Didier,
Indeed, long time no see and good to know you are still around.
I have been looking at Unity for a while now so I guess this will come handy soon - thanks! :thumb:
Postby Pixero » Thu Dec 17, 2009 10:49 am
I get a instant BugSplat upon starting SU.
When I remove it from the plugins folder SU starts normally.
Using latest SU and the english version of your script.
Pixero
Postby TIG » Thu Dec 17, 2009 2:48 pm
Same here... :(
Global Moderator
Postby ilay7k » Thu Dec 17, 2009 6:28 pm
Works at 6 version, but slow, seems my pc is slow
same thing at 7 as TIG and Pixero
ilay7k
Postby DIEGO-RODRIGUEZ » Thu Dec 17, 2009 7:48 pm
thank you very much for sharing.
Could make the menu visible, in order to personalize it.
the plugins *.rbs , and menu of plugins *.rb
DIEGO-RODRIGUEZ
Banned
Postby Didier Bur » Thu Dec 17, 2009 7:50 pm
:evil: :evil:
Are you on Mac, guys ? or do you use 7.1. ?
Always the same boring SU version update problems with rubies, I guess...
Didier Bur
Didier Bur
Postby TIG » Thu Dec 17, 2009 8:05 pm
PC, Vista, with latest SUp v7.1+M1
Global Moderator
Postby Didier Bur » Thu Dec 17, 2009 8:29 pm
@TIG:
I'm on SU v7.0.8657
Do you know of any change in the API for 7.1. ?
Didier Bur
Didier Bur
Postby TIG » Thu Dec 17, 2009 8:37 pm
Didier Bur wrote:@TIG:
I'm on SU v7.0.8657
- arccurve.is_polygon?
- adding entities to groups initially seems less bugsplatty but it's not documented...
so none that should affect this...
Global Moderator
Postby thomthom » Thu Dec 17, 2009 8:49 pm
I'm on SU v7.0.8657
Model.number_faces
only additions AFIK
PluginStore Author
PluginStore Author
Postby TIG » Thu Dec 17, 2009 8:52 pm
Have you modified any 'built-in' methods that might clash with others mods ?
Global Moderator
Postby Didier Bur » Thu Dec 17, 2009 11:15 pm
@TIG: No, I never do that !
Didier Bur
Didier Bur
Postby Didier Bur » Thu Dec 17, 2009 11:17 pm
Didier Bur
Didier Bur
Postby AcesHigh » Fri Dec 18, 2009 1:23 am
awesome Didier! I had asked for such a plugin some months ago! It will be great to create some bumpmaps (or displacement maps) to use with VRAY!
AcesHigh
Postby EarthMover » Fri Dec 18, 2009 3:14 am
Didier I extracted the plugin to the plugins folder and it causes SU to crash upon opening. I removed the plugin and SU opened fine.
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby Didier Bur » Fri Dec 18, 2009 6:53 pm
It seems that crappy Vista is causing the problem (as usual).
Since the script writes binary BMP or RAW files, ensure you have the right to do this (be logged as admin ?)
Any other clue anyone ?
Didier Bur
Didier Bur
Postby Pixero » Sat Dec 19, 2009 7:32 am
Well...I had the same problems on XP at work, so... it can't be just Vista.
Pixero
Postby notareal » Sat Dec 19, 2009 1:27 pm
:thumb: Nice tool. Wonder if hdr or exr would be possible as file options.
notareal
Thea Render Support
Thea Render Support
Postby TIG » Sat Dec 19, 2009 4:37 pm
Didier Bur wrote:It seems that crappy Vista is causing the problem (as usual).
Where does it write these to?
I am an admin so it shouldn't matter.
Also it crashes SUp BEFORE you try to do anything - just by loading it you get the problem.
Global Moderator
Postby charly2008 » Sat Dec 19, 2009 5:13 pm
Hi TIG,
i have the same problem with XP. SU7 was just by loading and then came a Bugsplat.
Karlheinz
charly2008
Postby Didier Bur » Sat Dec 19, 2009 6:58 pm
It writes images at the same location than the SKP is.
That's what is really strange. I don't overwrite built-in methods, don't do any 'require' or something that involve other files.
Would you please test this version and tell me if the problem persists ? :bounce:
Didier Bur
Didier Bur
Postby Pixero » Sat Dec 19, 2009 7:05 pm
Still crashes instantly while loading SU. Now on Windows 7 64bit. SU 7.1.
Pixero
Postby charly2008 » Sat Dec 19, 2009 7:25 pm
it still crashes while loading SU.
Karlheinz
charly2008
Postby TIG » Sat Dec 19, 2009 8:19 pm
Test file = instant Bugsplat.
Didier - why not PM or email the 'uncompiled' script to one of us for debugging - you can trust me ;) ...
You know that I hack into your encrypted rb files all of the time, but the rbs ones are a bit harder... just easier if you supply it unencrypted...
It must be simple to fix...
Global Moderator
Re: [Plugin] Heightmap from model
Postby georglorenz » Sat Jan 16, 2010 4:11 am
Slightly off topic here: Is there a plugin that does the exact opposite of this one? That is creating a terrain from an greyscale image (.jpg or anything else)? Thank you. G
georglorenz
Postby Chris Fullmer » Sat Jan 16, 2010 4:46 am
There is, Didier wrote a script that imports a heightmap image into SU. I forget what its called, but it was written by didier bur and should be posted here on the forum somewhere....
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby notareal » Sat Jan 16, 2010 3:07 pm
Nice work!
notareal
Thea Render Support
Thea Render Support
Next
Return to Plugins
Users browsing this forum: Bing [Bot], JorgeChiri, liutao91, namrfb and 14 guests
