[Plugin] hide all edges
Postby CadFather » Sun Dec 13, 2009 3:13 pm
Thanks to Fredo, a script that can hide recursively all the edges inside a group or nested groups\components
scroll down for the plugin by Fredo:
http://forums.sketchucation.com/viewtopic.php?f=180&t=24424#p209144
CadFather
PluginStore Author
PluginStore Author
Re: hide all edges?
Postby juan974 » Sun Dec 13, 2009 8:41 pm
hello,
when you are in a component change render mode for "wireframe" then hit ctrl+A to select all (edges only because you are in wireframe mode), then goto edit > hide.
return to "shaded whit textures" render mode .
hope it s helps
juan974
Re: hide all edges?
Postby CadFather » Sun Dec 13, 2009 8:54 pm
thanks Juan, to do that you can also use Thom's selection tools or Didier's selection filters
..but my aim is to be able to hide the edges inside all sorts of nested groups/components
the script mines down all the levels and hides all the edges it finds...fingers crossed
CadFather
PluginStore Author
PluginStore Author
Re: hide all edges?
Postby fredo6 » Sun Dec 13, 2009 10:57 pm
CadFather wrote:hi, is there a script that can hide recursively all the edges inside a group or nested groups?
Here is a old, undocumented script I wrote a while back.
It will Hide, and Unhide, all edges, at all levels of the current selection, or to the whole model if the selection is empty.
There are 2 entries in the Plugins menu for these operations
[Edit 13 Dec 09, 11:45pm] I made it work on the selection too.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: hide all edges?
Postby solo » Sun Dec 13, 2009 11:00 pm
Fredo, I wonder if it's possible to have one that will show all edges too (opposite), reason for that is when I need to save an line image for overlay, I need to go into all the groups, components, nested stuff and unhide them.
-1
http://www.solos-art.com
solo
Global Moderator
Re: hide all edges?
Postby CadFather » Sun Dec 13, 2009 11:10 pm
Fredo, the script works perfectly and very fast.. Superthanks! :enlight:
Pete, isn't the script already doing this with unhide?
CadFather
PluginStore Author
PluginStore Author
Re: hide all edges?
Postby solo » Sun Dec 13, 2009 11:21 pm
Cadfather
The problem I have is with imported geometry, normally Maya and Max models that have lots of embedded groups, you need to go into every group to unhide the edges.
solo
Global Moderator
Re: hide all edges?
Postby CadFather » Sun Dec 13, 2009 11:31 pm
perhaps i don't understand you, but when i hit unhide it does so on all sub groups..
CadFather
PluginStore Author
PluginStore Author
Re: hide all edges?
Postby fredo6 » Sun Dec 13, 2009 11:50 pm
CadFather,
I just make it work on the current selection. If it is empty, then the script considrs the whole active model.
The rb file is updated in my post above
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: hide all edges?
Postby CadFather » Sun Dec 13, 2009 11:58 pm
thanks Fredo, fantastic time saver... :D
CadFather
PluginStore Author
PluginStore Author
Re: [Plugin] hide all edges
Postby jonatanr » Wed Aug 21, 2019 9:41 am
Awesome!
jonatanr
Return to Plugins
Users browsing this forum: CMC007, kayuya101, tahoheto and 15 guests
