[Plugin] YZ + X v1.0
Postby Chris Fullmer » Sun Nov 29, 2009 10:43 pm
This is from a request here:
viewtopic.php?f=323&t=24011
This script is highly specialized, I don't recommend downloading and installing it unless you know you need it. Which you probably don't. :)
Description
This script lets you pick 2 vertices. It then takes the YZ coordinates from the first vertex and the X coordinate from the 2nd vertex and use those 2 points to create a new point, and it adds a construction point in that location.
Usage
Plugins > Chris Fullmer Tools > YZ + X. Select the first point, then the 2nd. It will add a construction point. This plugin does not work right if the model axis has been altered. So reset the model axis first - sorry!
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Re: [Plugin] YZ + X v1.0
Postby Mael » Sun Nov 29, 2009 10:55 pm
Thank you so much for creating this plugin for me! I was having no luck creating this plugin myself or finding a similar one on the web. You really have saved me a great deal of time, assuming this plugin works as intended ;P I can't thank you enough!
Nvm I found the problem. Thanks again :D
Mael
Return to Plugins
Users browsing this forum: arnaydn, ercplrgdo, Estebantonio8, gwynbleids, HK6600, Tufalos, xuantran and 12 guests
