[Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
Postby Whaat » Thu Nov 19, 2009 4:47 am
I have decided to release the next version of UVTools as a public beta. I'm not certain at this point whether this plugin will end up commercial or not but in either case, I am very anxious to release it so here it is!
New in UVTools 0.2
- UV Import/Export bridge to external UV mapping software.
Confirmed Compatible External UV Mapping Software
Blender (free)
Ultimate Unwrap 3D
UVMapper Classic (free)
UVMapper Pro
Roadkill (free)
Argile
Lithunwrap (free)
3DS Max
UVLayout
I need your help to test to see what other external software is compatible. I suspect that almost any app that can import and export OBJ files should be compatible. If you find a compatible app that is not listed here, please let me know so I can add it to this list. Some suggestions for testing are:
- Maya
- Modo
- Cheetah 3D
I have NOT yet tested this plugin on a Mac but I suspect that it will work fine. Some of the apps listed above have Mac versions available including Blender, UVMapper classic, and Argile.
How to use the External UV Bridge
The basic workflow is the same no matter what external application is used.
1) Paint a textured material directly on any any number of faces in your SketchUp model. Do not paint on groups or components. You must paint on the faces.
2) Select the faces that you want to UV map. Currently, you can only map one material at a time so be sure to only select faces that have the same material applied.
3) Go to the menu item Plugins->UVTools->Export UVs to OBJ.
4) A message should show if the export was successful. Pay attention to the location that the OBJ was saved. The location cannot be changed.
5) Load/Import this OBJ file into your external UV mapping application.
6) Edit the UVs with your application as desired.
7) Save/Export the model as an OBJ file using the same filename and location that you exported from SketchUp.
8) Go to the menu item Plugins->UVTools-Import UVs from OBJ.
9) You should receive a message that the import was successful.
The workflow probably sounds complicated by I assure you that it runs pretty smoothly. Below is a video of the workflow using Ultimate Unwrap 3D as the external mapping tool.
Most external applications will give you an options dialog box when you import or export an OBJ file. Do NOT change any options! The default settings should work fine in most external apps.
I have not yet modified any of the existing UV mapping methods from version 0.1. You can still apply cylindrical or spherical mapping as before by using the right-click context menu. The axis for mapping will always be the z-axis. To change the tiling, just adjust the width and height of the texture using the SketchUp material editor (after applying the UV projection).
Please post feedback and bugs. Enjoy!
Whaat
EDIT: Updated version to work with SU6
4
Whaat
PluginStore Author
PluginStore Author
Re: UVTools 0.2 Pro (Beta)
Postby majid » Thu Nov 19, 2009 9:04 am
:berserk: , even the first version was incredibble,thank you mate and would you plz add more options ,like cubic, and maybe more options for sylanderical mapping too?...it is really great , man!!!
majid
Top SketchUcator
Postby NewOne » Thu Nov 19, 2009 12:56 pm
Well... seems to be amazing. I just tried UVMapper Classic and LithUnwrap, but I think for now I will stick to :paint: :mrgreen: It's to hard for me to figure out how to use that uv mapping software. I always thought is more simpler and intuitive :cry:
NewOne
Postby Whaat » Thu Nov 19, 2009 3:21 pm
NewOne wrote:Well... seems to be amazing. I just tried UVMapper Classic and LithUnwrap, but I think for now I will stick to :paint: :mrgreen: It's to hard for me to figure out how to use that uv mapping software. I always thought is more simpler and intuitive :cry:
UV mapping programs are generally not very intuitive from my experience. However, there are tons of UV mapping tutorials on the internet and many of them are applicable to different software. It then becomes a matter of figuring out the UI for your particular program.
Whaat
PluginStore Author
PluginStore Author
Re: [Plugin] UVTools 0.2 Pro (Beta)
Postby DIEGO-RODRIGUEZ » Thu Nov 19, 2009 3:24 pm
thank you very much for sharing.
excellent plugins
a question, naive.
can make plugins to map from sketchup?
it work as well as UVtools.rb
DIEGO-RODRIGUEZ
Banned
Postby Khai » Thu Nov 19, 2009 3:31 pm
if it works with UVmapper Classic, it should work with Pro.. I'll test that for you later on. (I've been using Pro for years)
Khai
Postby remus » Thu Nov 19, 2009 3:32 pm
Any tips on opening the .obj in blender 2.5? ive tried just straight file->import but i cant see anything afterwards...
remus
Postby Khai » Thu Nov 19, 2009 3:58 pm
Works fine with UVmapper Pro :)
Khai
Postby Khai » Thu Nov 19, 2009 4:03 pm
oh MAN
I love this already!!!!!!!!!
Khai
Postby pilou » Thu Nov 19, 2009 4:03 pm
Seems a new true gem :enlight:
@Remus: you have Blender 2.5? :shock:
Speedy Galerie
Top SketchUcator
Postby Whaat » Thu Nov 19, 2009 4:03 pm
remus wrote:Any tips on opening the .obj in blender 2.5? ive tried just straight file->import but i cant see anything afterwards...
I haven't used version 2.5 yet. With my older version, I had to go the menu item 'File->Import->Wavefront OBJ' and then browse for the file.
Depending on the scale and location of the object, it might not be immediately visible in the Blender 3D view. Is there a command in Blender to 'Fit the view to the scene'?
Whaat
PluginStore Author
PluginStore Author
Postby pilou » Thu Nov 19, 2009 4:08 pm
Blender Shortcuts ;)
Seems it's Home
Speedy Galerie
Top SketchUcator
Postby Khai » Thu Nov 19, 2009 4:10 pm
testing it now.. but it looks like as a sideline, you've created a good OBJ exporter.....
ok. you've created as a sideline, a almost perfect OBJ exporter for Sketchup. (just the naming / save location)
hot damn. UVmapping and OBJ exporting.... you should see the grin on my face!
Khai
Postby remus » Thu Nov 19, 2009 5:01 pm
Pilou, you can get the latest builds (pre beta at the moment) from here: http://www.graphicall.org/builds/
Whaat, i'll give 2.49 a try this evening and let you know how it goes.
remus
Postby Khai » Thu Nov 19, 2009 8:26 pm
ok been playing with this today and I consider it a must have already...
Khai
Postby jeff hammond » Thu Nov 19, 2009 8:30 pm
khai - you have to sell it man!
let's see some pictures of what you've come up with :D
dotdotdot
jeff hammond
Global Moderator
Postby Khai » Thu Nov 19, 2009 8:34 pm
lol sorry
the bugbears I've had is UVmapping and OBJ export..and this solves both in one shot.. I'm kinda excited lol
Khai
Postby Whaat » Thu Nov 19, 2009 9:44 pm
Jeff Hammond wrote:khai - you have to sell it man!
Yeah...let's see some pictures of what you guys can do with this! :)
Whaat
PluginStore Author
PluginStore Author
Postby Stinkie » Fri Nov 20, 2009 11:09 am
Thanks, Dale. Will try this with Modo.
Stinkie
Postby EarthMover » Fri Nov 20, 2009 1:27 pm
Dale, tested with 3ds Max and it worked flawlessly on this teardrop shape using the Unwrap UVW modifier. Thanks for the plugin. It will fix a lot of headaches!!
One of the issues is that once a UV is imported, it does not "stick" to the geometry it was assigned to. For example if I did not like this brick and wanted to replace it with another material, the UV's become scrambled again. Also when I try to undo after importing the UV's, I get a SU crash.
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby Whaat » Fri Nov 20, 2009 3:15 pm
EarthMover wrote:Dale, tested with 3ds Max and it worked flawlessly on this teardrop shape using the Unwrap UVW modifier. Thanks for the plugin. It will fix a lot of headaches!!
Great! Another app to add to the list! Thanks for testing :)
Yeah, I hate that SketchUp does not keep UVs when switching materials. I'll look into that crash, too. Thanks!
Whaat
PluginStore Author
PluginStore Author
Postby NewOne » Fri Nov 20, 2009 3:18 pm
Can you write the UV data in an attribute? And using it from there... It would increase the size of the file, I think... for each face to write separate UV. But it can be a way.
NewOne
Postby Whaat » Fri Nov 20, 2009 3:28 pm
NewOne wrote:Can you write the UV data in an attribute? And using it from there... It would increase the size of the file, I think... for each face to write separate UV. But it can be a way.
Yes, you can. I use that method in SkIndigo but I have not yet added the feature to UVTools.
Whaat
PluginStore Author
PluginStore Author
Postby NewOne » Fri Nov 20, 2009 3:31 pm
When using Oscar's UV mapping and tried to render with Maxwellrender I noticed that it exported a bitmap for each face and made a copy of used material for each exported bitmap. So, I had situations when I had 1000 materials just for one object :?
This is strange... I was eexpecting that the bitmap to be folded around object.
NewOne
Postby jeff hammond » Sat Nov 21, 2009 6:02 am
Whaat wrote:I have NOT yet tested this plugin on a Mac but I suspect that it will work fine.
nah, it doesn't even appear in the context menu.. (well, the spherical & cylindrical still do but that's it)
edit-
haha.. hold on a minute.. i guess i'm in the wrong place because it is in the plugins menu.. :lol:
[cut me some slack though..it's friday night and i'm messing around with wine & UV mapping)
dotdotdot
jeff hammond
Global Moderator
Postby Khai » Sat Nov 21, 2009 6:15 am
should one drink and draw? :twisted:
Khai
Postby jeff hammond » Sat Nov 21, 2009 6:55 am
ha.. sure - just don't look at the drawings in the morning and everything will be okay.
the plugin works on mac just fine (tested using argile)
i don't think that's the right app for me but that's beside the point..
dotdotdot
jeff hammond
Global Moderator
Postby princedragoncok » Sun Nov 22, 2009 3:19 pm
Thankyou Whaat for this fantastic plugin. I tried it with UVLayout. It failed to work with Sketchup 6 and had me feeling gutted that I had spent a few hours learning uvlayout for no reason. Then tried it with Sketchup 7 and it worked thankfully!
EarthMover wrote:One of the issues is that once a UV is imported, it does not "stick" to the geometry it was assigned to. For example if I did not like this brick and wanted to replace it with another material, the UV's become scrambled again. Also when I try to undo after importing the UV's, I get a SU crash.
Yes, the uv's will become scrambled momentarily when you change to a completely different material, but go back to the uvtools in the plugins menu and re-import your external uv settings onto the newly scrambled material and it will revert back to the pervious mapping settings you had but with the new material.
So here is a quick example of the plugin in action:
In su7 before:
With the plugin applied using uvlayout:
I have run into perhaps a bug though.. while I set up the uv mapping correctly in uvlayout - I got an error message when importing into sketchup. It told me import successful but 1 face failed.. This is the result:
Before:
After (notice the scrambling along the center)
I have one more question which isn't related to the plugin but something I have experienced myself (with my basic uvmapping skills) and is something I also noticed in Whaat's videos. When I split open my mesh to flatten it, when it reassembles the joining seam never lines up correctly... any simple suggestions to combat this?? i'm thinking there must be some sort of weld function i'm missing inside the uvprogram. Here's an illustration anyway:
princedragoncok
Postby Whaat » Mon Nov 23, 2009 7:58 pm
princedragoncok wrote:Thankyou Whaat for this fantastic plugin. I tried it with UVLayout. It failed to work with Sketchup 6 and had me feeling gutted that I had spent a few hours learning uvlayout for no reason. Then tried it with Sketchup 7 and it worked thankfully!
Are you sure it only works in SU7? If so, that's very strange.
It looks like from your image that more than one face failed. This 'bug' seems to be caused from SketchUp not 'liking' the UVs that are generated from the external application. I'm not sure how fixable it is...
Seams are (by definition) discontinuities in the UV coordinates. I think the only way to avoid seams is to use spherical and cylindrical mapping. I don't have a ton of experience with UV software. There might be a weld-type function somewhere that will align the UVs along both edges of a seam.
Whaat
PluginStore Author
PluginStore Author
Postby vidy » Tue Nov 24, 2009 11:31 pm
yes whaat, it failed in sketch up 6.. could it be fixed? :bounce:
still so much to learn..
vidy
Next
Return to Plugins
Users browsing this forum: anaprates, brayan suarez, Dashabc123, kamranrj, Tazvi and 14 guests
