[Plugin] Make Named Group
Postby thomthom » Thu Nov 12, 2009 10:35 pm
By request-ish: http://forums.sketchucation.com/viewtop ... 80&t=23567
(Code sample turned out to become full plugin.)
Adds Make Named Group to the Edit menu.
Download
PluginStore Author
PluginStore Author
Re: [Plugin] Make Named Group (1.0.0) — 12 November 2009
Postby alz » Fri Nov 13, 2009 12:40 am
Nice! I like the Layer addition.
What about defaulting it so the GROUP NAME field is highlighted first? Then you can immediately enter a group name, instead of selecting it, then naming it?
alz
PluginStore Author
PluginStore Author
Postby thomthom » Fri Nov 13, 2009 8:28 am
alz wrote:What about defaulting it so the GROUP NAME field is highlighted first? Then you can immediately enter a group name, instead of selecting it, then naming it?
hm... don't think I have control of that. Unless I swap the order of them.
Or I could make a custom window. Will see.
PluginStore Author
PluginStore Author
Postby TIG » Fri Nov 13, 2009 10:26 am
Unfortunately with the basic inputbox the last set field is always highlighted...
Global Moderator
Postby thomthom » Fri Nov 13, 2009 10:47 am
TIG wrote:Unfortunately with the basic inputbox the last set field is always highlighted...
I filed a bug on this.
PluginStore Author
PluginStore Author
Postby pilou » Fri Nov 13, 2009 10:59 am
In this order of idea: a ruby who take the name of a group (or Component) selected then create the same "Layer name" and put the group (or Component) in this new Layer named will ne fine :)
Speedy Galerie
Top SketchUcator
Postby thomthom » Fri Nov 13, 2009 11:05 am
Pilou wrote:In this order of idea: a ruby who take the name of a group (or Component) selected then create the same "Layer name" and put the group (or Component) in this new Layer named will ne fine :)
Untested, but this should place all groups/components into a layer based on their name.
Code: Select all
model = Sketchup.active_model
sel = model.selection
sel.each { |e|
  next unless e.is_a?(Sketchup::Group) || e.is_a?(Sketchup::ComponentInstance)
  model.layers.add(e.name) if model.layers[e.name].nil?
  e.layer = model.layers[e.name]
PluginStore Author
PluginStore Author
Postby din_wiesel » Fri Nov 20, 2009 10:02 am
Would it be possible to put the entry from the "Edit Menu" to the context menu?
greets din
din_wiesel
Postby thomthom » Fri Nov 20, 2009 10:15 am
I will see if I can add support for UI Manager - so you can choose. There are people who prefer not to have their context menu filled with more items. So it's not easy to get a balance. But when the user can choose then it's not an issue any more.
PluginStore Author
PluginStore Author
Postby JGA » Fri Nov 20, 2009 2:40 pm
Thanks for the plugin, a great idea.
Regards,
JGA
Regards,
JGA
JGA
Postby dedmin » Mon Feb 07, 2011 10:05 pm
I just saw this - very useful! I started recently using groups instead of components and I'm using this wonderful plugin - viewtopic.php?t=9318
If there is a way to combine them into one - perfect!
dedmin
Postby thomthom » Mon Feb 07, 2011 10:19 pm
dedmin wrote:I just saw this - very useful! I started recently using groups instead of components and I'm using this wonderful plugin - viewtopic.php?t=9318
Is there different functionality?
PluginStore Author
PluginStore Author
Postby dedmin » Mon Feb 07, 2011 10:21 pm
dedmin
Postby thomthom » Mon Feb 07, 2011 10:23 pm
PluginStore Author
PluginStore Author
Postby dedmin » Mon Feb 07, 2011 10:25 pm
It has a drop-down list of 20 names to choose from
dedmin
Postby thomthom » Mon Feb 07, 2011 10:29 pm
That seems very specific...
I still don't see what combination it is you're looking for.
PluginStore Author
PluginStore Author
Postby dedmin » Mon Feb 07, 2011 10:33 pm
Your plugin plus a drop-down list for the group names. Jim's plugin allows You to write 20 most used names in a text file for later use - useful in many fields where the parts are common - furniture and the like.
dedmin
Postby utiler » Sun Feb 27, 2011 2:43 am
Hey Thomas, love your plugins....
With this one; do you think you could have the group added to a layer of the same name? If no layer, ask the user do you want to add a layer? Would be a great timesaver.....
Thanks.
A
utiler
Top SketchUcator
Postby bagatelo » Sun Feb 27, 2011 4:02 pm
utiler wrote:Hey Thomas, love your plugins....
Thanks.
A
It would be interesting if there was a box or drop down menu where it appeared the possibility to create and now include the object in a layer with the same name.
Create components instead of groups might be interesting too.
bagatelo
Postby utiler » Mon May 23, 2011 6:01 am
Thanks.
A
Thom?
utiler
Top SketchUcator
Postby Goonster » Mon May 23, 2011 7:06 am
Great plug in.Thanks. ;)
I`ve assigned `G' as a shortcut to it so I don`t have to keep going to the Edit menu.
Goonster
Postby veerlexyz » Fri Oct 26, 2012 12:56 pm
Thanks a lot for this plugin.
I would love to see this plugin "Make Named Group" in the right-click-menu.
Is that possible?
veerlexyz
Postby thomthom » Fri Oct 26, 2012 2:15 pm
veerlexyz wrote:Thanks a lot for this plugin.
Is that possible?
It is possible - but if I where to add it I'd get requests about removing it from people who want to reduce the amount of items in the context menu. Right now I don't have the time to make a UI for controlling this option.
PluginStore Author
PluginStore Author
Postby tula1847 » Fri Apr 05, 2013 2:57 am
Hello just tried to download and says the .rb file is locked. How do I unlock I have a macbook pro.
tula1847
Postby kaas » Wed May 07, 2014 11:13 am
Just 'discovered' this plugin. Added an array with often used groupnames (SFB codes) which is displayed in the dropdown list instead of the layer names and this speeds up my workflow quite a bit. Many thanks for this gem Thom!
kaas
Return to Plugins
Users browsing this forum: Bing [Bot], xanhxam and 10 guests
