[Plugin] Snap to Unit
Postby alz » Thu Nov 12, 2009 3:25 pm
Handy item that'll snap anything selected to the nearest unit described in Model Info, Units, Enable Length Snapping.
Reason: Just cleaning up and organizing the Plugin forum. Correcting [Plugin] tag
alz
PluginStore Author
PluginStore Author
Re: [Plugin] Snap to Unit
Postby derei » Mon Mar 07, 2011 2:25 am
What this plugin exactly does? I'm not sure that I understand from description. Can you post a movie, or a better detailed explanation?
DESIGNER AND ARTIST DEREI.UK
derei
Postby alz » Mon Mar 14, 2011 2:13 pm
I don't have a video of it, but it's fairly simple.
It takes whatever object(s) you have selected and moves them to the nearest "grid" setting. The grid settings are found in: Model Info: "Units". To turn on the grid also check "Enable Length Snapping" in Model Info.
The action uses the origin point (local axis) of the object as the snap-to-location.
alz
PluginStore Author
PluginStore Author
Postby derei » Mon Mar 14, 2011 2:37 pm
alz wrote:It takes whatever object(s) you have selected and moves them to the nearest "grid" setting. .
So, if I have snapping set at 1cm and I have an object situated at 10,5cm from origin, it will be snapped to 100? (I assume that my "grid" cell is 1cm, right?)
derei
Return to Plugins
Users browsing this forum: Julio Costa, kurabiye, lolwas23, mneciosup, weyrauc3, wnscjfdlzz and 17 guests
