[Plugin] Geom Interpolated Curve ver. 1.3.
• Page 1 of 1
[Plugin] Geom Interpolated Curve ver. 1.3.This plugin became obsolete but you can find all its functionality in 'Recursively Smoothed Curve' tool of 'LSS Toolbar 2.0' extension. It is still only a beta version, but this particular tool works stable enough. Find out more at viewtopic.php?f=323&t=47399
Re: [Plugin] Geometric curve smoothing ver. 1.1.Very cool, particularly like the explanation lines
![]() Re: [Plugin] Geometric curve smoothing ver. 1.1.Funny for curious caligraphy
Re: [Plugin] Geometric curve smoothing ver. 1.1.![]() Welcome to try Thea Render, Thea support | kerkythea.net -team member
Re: [Plugin] Geometric curve smoothing ver. 1.1.good idea...
I'm concerned that the word "Smooth" is already "taken" in SketchUp... and usually applies to a specific type of edge, so if we could come up with a better name for this tool, it may avoid confusion. may I suggest "Curve Toy" or "Curve Control" or "Squishy Curve" or "Marilyn Monroe" ![]()
Re: [Plugin] Geometric curve smoothing ver. 1.1.Very cool. What do you do with the explanation lines? can you manipulate the geometry with those lines? Sorry I am not with SU range.
Re: [Plugin] Geometric curve smoothing ver. 1.1.Very interesting videos. I will have to review them again.
I agree. I like "Marilyn Monroe" ![]() ![]() Well maybe "Geom Interpolation" (long, but close to what it really is).
Unfortunately explanation lines are only to show, how intermediate vertices were modelled (lines are practically useless and there is no way to interact with them only to admire). Actually it is necessary to implement 2 additional 'control lines' at the start and at the end of the initial opened curve to affect 1-st and last segment curvature (the same way as cubic spline). Closed curve does not need it. And another issue: current version does not 'remember' control points across sessions also (the same as 'ctrlpnts.rb'). I'm on my way to implement such functionality. Last edited by kirill2008 on Wed Oct 28, 2009 6:00 am, edited 1 time in total.
Re: [Plugin] Geometric curve smoothing ver. 1.1.Tremendously useful for me
![]() It seems like a good plugin to make the curves as a start for a soap-skin-bubble session. Thanks Kirill! ![]() Re: [Plugin] Geometric curve smoothing ver. 1.1.![]() ![]() ![]() ![]() This is amazing and very very helpful, thank you very much for your generosity. greetings Re: [Plugin] Geom Interpolated Curve ver. 1.2.In the current version (1.2.) the command name to launch the plugin was renamed to "Geom Interpolation..." to avoid confusions with other commands.
And now script recalls control points after opening the file which contains curve. I'm going also to add interactive control points editing (the same way as in ctrlpnts.rb).
Re: [Plugin] Geom Interpolated Curve ver. 1.3.Kirill, thank you for this plugin.
Several I watched your videos demonstrating it and then tried to use it. I must be missing something because you seem to be able to make it do things I can't. Could you give a little basic training? I can get the curve alright after setting the control points out. After that, I select Edit Geom Interpolated Curve... If I click on the left arrow key I get some additional points but no lines joining them to the points on the curve. Also, if I click on a control point and try to drag it, nothing happens. If I click on a control point and let go of the button, the next click creates a new point away from the first point as if placing a guide point with the Tape Measure tool. Nothing I do will let me edit the curve. I've tried following the messages displayed at the bottom of the screen but with no luck. Could you give some guidance? Thank you. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] Geom Interpolated Curve ver. 1.3.Dave,
I have tried this and find it a bit hit and miss to pick a control point. You have to move the select tool around a fair bit until a tool tip says "Guide point". You can click on this and the curve turns red and a message in the status bar says "Feel free to pick a c_point to interact with" then clicking on that point allows you to move the point and the line will follow. Chris
Re: [Plugin] Geom Interpolated Curve ver. 1.3.Thanks Chris. I did see that deal with the curve turning red and the message "Fill{sic} free to pick..." but even then I can't move the control point.
I don't know if it helps but here is a little video I made of using it. http://www.youtube.com/watch?v=6dSNuvlzJwg Chris
Re: [Plugin] Geom Interpolated Curve ver. 1.3.I think it would be interesting to check out the video of 'crvsmth.rb' revival:
Finally I decided to reanimate this ancient 'scripture' and make its use more intuitive this time... So now it is adapted into modernized 'LSS Toolbar' infrastructure and its reincarnation name is 'Recursively Smoothed Curve' tool. For now 'pre-alpha' version of 'LSS Toolbar' is available. Feel free to use it at your own risk.
This is just downright awesome ![]() ![]() i7-4930K 3.4Ghz, 2x GTX780 6GB, 32GB DDR3-1600 ECC, OCZ Vertex 4 500GB, WD Black 3TB, 32TB NAS, 4x 27" Monitors, SpaceMouse Pro, X-keys XK-60
Re: [Plugin] Geom Interpolated Curve ver. 1.3.Nice update!
Actually update is still under construction, I was just excited about the way it works and decided to share current stage ![]() BTW, I'm a huge fan of Kerkythea ![]() ![]()
Re: [Plugin] Geom Interpolated Curve ver. 1.3.Thankyou! How does one learn to use the tool (LSS toolbar)? I am just guessing and clicking and getting no results so far. Also the text fields are solid black.
MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
I plan to make manuals after functionality update completion: there are 2 more tools are to be added in 'LSS Toolbar' and after their addition I'll start testing and documenting this plugin. The reason, that 'LSS Toolbar' does not work on mac is that settings-dialog forms are not adapted yet for displaying by 'Safari' (default macOS browser, which SU uses to display web-dialog forms). I use pc at work and at home, so it'll be a bit tricky for me personally to make these dialog-forms work on mac too, but I'll try to do it anyway.
Re: [Plugin] Geom Interpolated Curve ver. 1.3.Hi, kirill:
Your update video is very impressive. I take the slow, deliberate approach in my aimless wandering.
I see. Thanks for the reply. I also found the black input fields is a problem on the Mac end that users need to sort out for themselves. http://forums.sketchucation.com/viewtopic.php?f=11&t=45382&hilit=black+dialog But it's very impressive work! MacOSX Mojave ShetchUp Pro v19 Twilight Pro v2 M2 Kerkythea PowerCADD
• Page 1 of 1
Users browsing this forum: danjochims, sjiine and 6 guests
