[Plugin] Layer Manager New Release
Postby Didier Bur » Thu Nov 29, 2007 9:52 pm
Hi all,
This is version 2 of my Layer Manager for SU6 (free and Pro).
What's new:
· Undo for all commands
· 2 new commands that deal with current layer
· 3 new commands to filter the layers visibility ;)
· 2 new commands to save/load states to/from external files
· Enhanced display of state dialog box
· Numerous bugs fixes :oops:
· New icons
· Active layer setting added
· "Delete all" layers states option added
· Overwrite existing states (while loading) option added
· Restore "Show only" and "Append" added
Enjoy, :!:
PATCHED on 12.06.07 6pm to fix a load bug.
Please get the latest version from the PluginStore
Download
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: LAYER MANAGER NEW RELEASE
Postby Edson » Sat Dec 01, 2007 11:44 am
didier,
this is a fantastic script. thanks for your genius and generosity. and the documentation that comes with it is an example to be followed.
i have installed it and have started using it right away.
regards,
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby yaza » Wed Feb 13, 2008 11:58 am
Architecte enseignant aussi, mon outil de predilection etant SU et Podium, j'ai laisse aux autres les divers autocad revit et archicad.
Un grand merci, je me demandais s'il n'etait pas possible de povoir gerer les layers a la facon de archicad. Tu l'as fais. Bravo :thumb: :ecstatic: :thumb: :ecstatic: :thumb: :ecstatic:
yaza
Postby ken » Thu Feb 14, 2008 1:37 am
Didier Bur
I know you want to protect your work, and I certainly agree with that position, but did you mean to make the PDF file unprintable? I have a note book filled with directions on using scripts, and this particular script will not print.
Thanks for the script and thanks in advance for your reply.
Ken
ken
Premium Member
Premium Member
Postby Mike Lucey » Thu Feb 14, 2008 2:01 am
Thanks Didier, just what I needed. This is fantastic :ecstatic:
Mike
Mike Lucey
Mayor
Postby Didier Bur » Thu Feb 14, 2008 10:58 am
Didier Bur
Didier Bur
Postby ken » Thu Feb 14, 2008 12:51 pm
Didier
Thanks for the quick reply and the printable directions.
Ken
ken
Premium Member
Premium Member
Postby russellbeta » Wed Apr 09, 2008 1:14 pm
Hey didier, first of all great work! it really saves me alot of time.
I have many groups within groups within groups in a model I'm working on, is there a way to move a selection to current layer that digs into groups/subgroups and moves every line/face along with it?
this would save me a whole lot of tedious work.
thanks again for the freeware.
russellbeta
Postby Didier Bur » Wed Apr 09, 2008 1:55 pm
No... :oops: But you may take a look at TIG's defaults2layers.rb recently published. It can help you a bit.
Regards,
Didier Bur
Didier Bur
Postby Edson » Wed Apr 09, 2008 2:20 pm
Regards,
didier,
where is it to be found? i could not find here nor at your site. are you sure it has been released by TIG?
Edson
Global Moderator
Postby JClements » Wed Apr 09, 2008 4:45 pm
try this for Hidden2Layer version 1.2:
viewtopic.php?f=180&t=6870
JClements
Premium Member
Premium Member
Postby Edson » Wed Apr 09, 2008 5:49 pm
thanks, john. i have not gotten used to the indexes yet...
Edson
Global Moderator
Re: [Plugin] Layer Manager New Release
Postby GhossbGood » Sun Jul 06, 2008 2:39 am
Thank's Didier,
It's very helpfull for me
:thumb: :thumb: :thumb:
GhossbGood
Postby zed252000 » Wed Sep 10, 2008 4:41 pm
"Good Ruby,"
"That will Do" 2x
:enlight:
Whatever we IMAGINE....
zed252000
Postby banhdau » Fri Apr 03, 2009 4:01 am
thanks
banhdau
Postby Bob James » Fri Apr 03, 2009 8:15 am
Curious problem on my Macs (work and home): The Layer Manager toolbar does not appear automatically. Each time I open SU7 I have to go to View/Tool Palettes and click on Layer Manager. Sort of a nuisance, but Layer Manager is a major player for me in SU.
Is this normal or do I have a problem? :?:
Bob James
Premium Member
Premium Member
Postby banhdau » Tue Apr 21, 2009 5:33 am
thanks
banhdau
Postby xrok1 » Tue Apr 21, 2009 11:48 pm
can someone post a screenshot or two of this layer manager. i'd like to see it before i decide whether to rearrange my toolbars.
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby Bob James » Wed Apr 22, 2009 6:57 am
Layer Manager is one of my top-usage plug-ins: especially the "all layers invisible except current" (the one with the red dot) and "all layers visible" (the one with the green dot).
Didier has just released a new version that "remembers" the state of the toolbar so you don't have to keep opening it.
Very useful (at least for me).
Bob James
Premium Member
Premium Member
Postby takesh h » Wed Apr 22, 2009 8:50 am
bob.james5 wrote:Didier has just released a new version that "remembers" the state of the toolbar so you don't have to keep opening it.
Really? :enlight: Do you care to share where I can get it from?
takesh h
Postby Didier Bur » Wed Apr 22, 2009 10:56 pm
Workaround:
Open the main rb file with a texte editor,
go to line 160
type: layers_tb.show
save the rb file
the end of file must look like:
Code: Select all
layers_tb.add_item(cmd10)
layers_tb.show
# End of load
$layer_manager_menu_loaded = true
file_loaded("fr_layer_manager_extension_v6.rb")
restart SU, you're done.
Didier Bur
Didier Bur
Postby mariocha » Mon Jul 13, 2009 2:23 am
Ok, workaround works fine on my Mac.! :D
Now is there also one for the Main toolbar on top? Icons do not stick there either. :P
merci beaucoup.
updt: I tried to find one plugin that would do it to see how it was done. But it seems like it's a real problem since not one of my plugins can keep its icons up there. Be it LightUP, Subd&Smooth, JPP, Tools-on-Surface or BezierSpline. :?: :?:
Mario C.
Certified SketchUp Trainer, QC CA.
Every rule has exceptions, but some.
mariocha
Premium Member
Premium Member
Postby watkins » Mon Jul 13, 2009 8:04 am
Where can I find the latest version of this plugin?
Regards,
Bob
watkins
Postby Didier Bur » Mon Jul 13, 2009 4:58 pm
Below is a preview of next release, still at beta:
I have split the script in 2 toolbars: 1 for the tools, 1 for the layers configs.
Features of toolbar 1:
Set layer of clicked object current
Set layer of clicked object current and isolated
Set layer of clicked object invisible
All layers visible
All layers invisible (except current)
Toggle visibility of all layers
Select/Deselect layer content
Move selection to current layer (digs in compos and groups)
Set layers of selection isolated (digs in compos and groups)
Set layers of selection invisible (digs in compos and groups)
Show layers by filter (add to visible layers)
Isolate layers by filter (digs in compos and groups)
Hide layers by filter (digs in compos and groups)
Toggle display color by layer
Match layer property of clicked object
Create layer and control behavior
Delete layer (digs in compos and groups)
Lock layer
Unlock layer
The other toolbar should have the same features than the previous release had, more or less.
Regards,
Didier Bur
Didier Bur
Postby Bep » Mon Jul 13, 2009 8:45 pm
Hello Didier,
It would be great iff the new version of your tool also be able to pasword protect for instance a invisable/locked layer.
Will it be?
If not,do you think it is possible inside Sketchup?
Thanks for all your efforts.
Greetings,
Bep van Malde
"History is written by the winners"
Bep
Postby dedmin » Sun Jan 17, 2010 6:03 pm
Doesn't work with cyrillic names. Seems a lot of things are like this ;)
dedmin
Postby thomthom » Sun Jan 17, 2010 6:47 pm
dedmin wrote:Doesn't work with cyrillic names. Seems a lot of things are like this ;)
what doesn't work? some functions? or the plugin as a whole?
PluginStore Author
PluginStore Author
Postby dedmin » Sun Jan 17, 2010 8:18 pm
dedmin
Postby zdouk » Fri Jan 22, 2010 1:12 pm
Bob James wrote:Curious problem on my Macs (work and home): The Layer Manager toolbar does not appear automatically. Each time I open SU7 I have to go to View/Tool Palettes and click on Layer Manager. Sort of a nuisance, but Layer Manager is a major player for me in SU.
This pluggin seem magnificient however I have an issue similar to yours Bob. Except , the layer manager tool bar does not even show under the "view-->toolbars" menu. help? I do I get it to display?
Mazdak
Landscape Architect / Paysagiste
http://www.land8.fr
zdouk
Postby TIG » Fri Jan 22, 2010 1:17 pm
This type of plugin is loaded as an 'extension', so it needs to be registered before it appears in the View>Toolbars list
To register it [once only needed] open Window>Preferences > Extensions tab, scroll to find 'Layer Manager' and tick its box: it should them be available on the View>Toolbars list :ugeek:
Global Moderator
Next
Return to Plugins
Users browsing this forum: ananan1523, ChristianJeru16, Dienifer, franky338, Happybro, oliv23 and 14 guests
