[Plugin] Control points ver. 1.6.
Postby kirill2008 » Wed Oct 14, 2009 6:32 pm
This plugin became obsolete but you can find all its functionality in 'Control Points' tool of 'LSS Toolbar 2.0' extension. It is still only a beta version, but this particular tool works stable enough. Find out more at viewtopic.php?f=323&t=47399
kirill2008
PluginStore Author
PluginStore Author
Re: [Plugin] Curve control points ver. 1.1.
Postby Ecuadorian » Wed Oct 14, 2009 6:44 pm
:shock:
Wow, thank you!
Ecuadorian
Postby pilou » Wed Oct 14, 2009 6:48 pm
Seems a cool one! :fro:
Speedy Galerie
Top SketchUcator
Postby thomthom » Wed Oct 14, 2009 6:51 pm
Just saw the video - very nice!
Does it remember the control vertices across sessions?
PluginStore Author
PluginStore Author
Postby d12dozr » Wed Oct 14, 2009 7:02 pm
Wow! Organic modeling just got easier :sketchstatic: Thanks, Krill!
Is there a way to set each node's position on the curve manually, instead of just being evenly spaced?
http://goo.gl/f7ooYh
d12dozr
Top SketchUcator
Postby pav_3j » Wed Oct 14, 2009 7:03 pm
now this is very cool!
thanks ever-so much!
yay another toy to play with...
pav
Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
pav_3j
Postby Daniel S » Wed Oct 14, 2009 7:11 pm
Thank you Kirill!!!
:berserk: :berserk: :berserk:
Looks amazing!!
Daniel S
Daniel S
Postby kirill2008 » Wed Oct 14, 2009 7:17 pm
thomthom wrote:Just saw the video - very nice!
Unfortunately no :?
I knew it would be one of the first questions :) , but it's not implemented yet. Actually I don't know yet how to make it... Maybe to launch a kind of entity scanner each time when new file loads. It will scan entities to link c-points to curve vertices again. But it will slow opening of huge models...
kirill2008
PluginStore Author
PluginStore Author
Postby kirill2008 » Wed Oct 14, 2009 7:19 pm
d12dozr wrote:Is there a way to set each node's position on the curve manually, instead of just being evenly spaced?
That's a cool idea :thumb: I'll try to implement it. Current version does not allow manual node positionig.
kirill2008
PluginStore Author
PluginStore Author
Postby mitcorb » Wed Oct 14, 2009 7:26 pm
Looks interesting, Kirill.
Will this technique do away with bezier curves?
What would be the difference in this and polylines?
EDIT!!! never mind my stupid questions. I had a good long look at the demo video.
Excellent work.
mitcorb
mitcorb
Top SketchUcator
Postby boofredlay » Wed Oct 14, 2009 7:31 pm
Wow, great stuff.
In your notes above you mention SU6. It seems to work fine in SU7.1 as well.
boofredlay
Global Moderator
Postby c.plassais » Wed Oct 14, 2009 7:39 pm
Excellent!!!
c.plassais
PluginStore Author
PluginStore Author
Postby boofredlay » Wed Oct 14, 2009 7:55 pm
It might be nice also to have the undo function work for the whole action rather than each individual step in the script. For example I added 6 control points around a 24 segment circle and it took 50 undo clicks to get back to the creation of the circle, when all I did was run the script once. Make sense?
Not sure how to do this however, just a thought.
This one is going to be very useful for me indeed.
Thanks :thumb:
boofredlay
Global Moderator
Postby thomthom » Wed Oct 14, 2009 8:25 pm
kirill2008 wrote:Maybe to launch a kind of entity scanner each time when new file loads. It will scan entities to link c-points to curve vertices again. But it will slow opening of huge models...
That's my concern for a plugin I'm working on as well... was curios to hear if there was any other way.
PluginStore Author
PluginStore Author
Postby olishea » Wed Oct 14, 2009 9:00 pm
this is amazing :berserk: :berserk: :berserk: :berserk:
thank you
oli
olishea
Premium Member
Premium Member
Postby EarthMover » Wed Oct 14, 2009 11:52 pm
FANTASTICO!!!! Awesome Krill! I think an add control point tool would be a great improvement. Also maybe a simple option to add control points only to existing vertices. This would be great for a subdivided or tesselated mesh, but I think it would require an implementation of soft selection to make a further advancement towards organic modeling.
Thanks again Krill.
EDIT - DUH! I looked right past the option to add to "each vertex". Nevermind.
I do vote for a Krill Toolbar though!!!
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby utiler » Thu Oct 15, 2009 2:16 am
Ditto, EarthMover!!! Toolbar for sure!!!!! :berserk: :berserk: :berserk:
Will somebody stop this guy............... :o
utiler
Top SketchUcator
Postby wind-borne » Thu Oct 15, 2009 5:18 am
Very interesting plugin.
i am having a strange problem, plugin only shows up on initial opening drawing. If I open a new one without closing Sketchup completely, no plugin.
I've tried copy from initial( where it works) and paste to new with real odd results also. The plugin then shows up but misbehaves. If I draw a new object, new construction points are put on the pasted object(even though I have deleted it) instead of new object which was selected.
"To read between the lines was easier than to follow the text."OSX 10.11.6 _ _ _ _ _ SU 8 pro
wind-borne
Premium Member
Premium Member
Postby dedmin » Thu Oct 15, 2009 5:43 am
Да здравствует дружба между народами :sketchstatic: :berserk: :berserk: :berserk: :berserk:
dedmin
Postby kirill2008 » Thu Oct 15, 2009 6:18 am
wind-borne wrote:i am having a strange problem, plugin only shows up on initial opening drawing. If I open a new one without closing Sketchup completely, no plugin.
As I can see on attached picture the whole face is selected, but current version of the script (ver. 1.1.) actually processes only curves. So try select only boundary curve without face itself (you may deselect face by pressing shift and single-clicking on face). Make sure that only boundary is selected. Of course script processing does not depend on opened file (old or new). It depends on what entity is the first one selected: if it occures that curve edge is the 1-st item of selected entities collection, then everything works, if the 1-st item is face, then the command does not appear within context menu.
So I'll try to make the script more tolerant to the selection in future versions :) .
Speaking of copy-paste behaviour, I'll try to find out why it processes so strange (don't know why yet).
kirill2008
PluginStore Author
PluginStore Author
Postby wind-borne » Thu Oct 15, 2009 7:20 am
kirill,
Thanks for your response, the problem is that the plugin only appears in the first file of a session, be it opening Sketchup with an old file or a new one. If I open an old or new after the initial startup, plugin is simply not there, curves or curves/faces selected doesn't make any difference( works both ways in first file opened).
The strange behavior is that the plugin follows the copy/paste and works on the original object (even though I have deleted it after pasting) in the new file but not on anything newly drawn.
Actually by thinking out loud I can see now how to do what I need to, just a cumbersome path.
The plugin, itself, has a nice feel. :D
wind-borne
Premium Member
Premium Member
Postby halroach » Thu Oct 15, 2009 7:53 am
very nice plugin!
but, there's always a but... :)
1. would be nice if copying and pasting a controlled object between documents would work.
2. doesn't work within components
3. undo function doesn't quite work well... takes many undos to go back one visual step.
keep up the good work!
halroach
Postby Panga » Thu Oct 15, 2009 7:55 am
Thanks a lot for this one, it'll be very usefull !!
Panga
Premium Member
Premium Member
Postby pep75 » Fri Oct 16, 2009 4:13 pm
:enlight:
GREAT WORK!!!!!
grtzzzz
pep75
Postby MALAISE » Sat Oct 17, 2009 10:14 am
Kirill , allways a new idea, on the way to interactiv drawing. :ecstatic:
MALAISE :thumb:
MALAISE
Re: [Plugin] Control points ver. 1.2.
Postby kirill2008 » Sat Dec 12, 2009 7:33 am
Deformation of geometry groups in the current version (1.2) has plastic nature. It means when the control point places back to its previous position, previous deformation does not disappear completely (some rest deformation remains).
I'll try to make deformation nature optional (plastic or elastic) in future versions.
kirill2008
PluginStore Author
PluginStore Author
Postby REGIS » Sat Dec 12, 2009 12:56 pm
Nice Plugin and thanks for your hard work
Works fine but sometime SU6 suddenly crash.
Unfortunately it doesn(t works with SU7(mac).
Cheers
REGIS
Postby pilou » Sat Dec 12, 2009 2:45 pm
Cynetic :)
Speedy Galerie
Top SketchUcator
Postby notareal » Sat Dec 12, 2009 10:35 pm
Thanks!
notareal
Thea Render Support
Thea Render Support
Postby Carrozza » Sat Dec 12, 2009 10:48 pm
One of the most powerful plugins I've seen to date! Bravo Kirill! :berserk:
Carrozza
Next
Return to Plugins
Users browsing this forum: HoangHieu1410, renjiano, salazar enciso and 14 guests
