[Plugin] VisMap Pro Beta Available, Free
Postby MartinRinehart » Wed Oct 07, 2009 4:50 pm
http://www.MartinRinehart.com/models/ru ... p_doc.html
VisMap Pro, beta test, is available. Its primary goal is to handle many more layers and scenes. The scene list is in a separate window; the windows support frames so you can eliminate banner and button frames and you can expand and shrink the map and the scene list.
Post beta test there will be a send-me-money feature added, but it's not there yet.
Reason: Just cleaning up and organizing the Plugin forum. Correcting [Plugin] tag
Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
MartinRinehart
Re: [plugin] VisMap Pro Beta Available, Free
Postby JClements » Thu Oct 08, 2009 12:46 am
Martin, looks like you've been doing fine tuning of the UI.
Will this work with SU6?
JClements
Premium Member
Premium Member
Postby MartinRinehart » Thu Oct 08, 2009 12:47 pm
JClements wrote:Will this work with SU6?
I foolishly let SU7 replace my SU6. Try it and tell me.
MartinRinehart
Postby JClements » Thu Oct 08, 2009 3:04 pm
Martin, it doesn't work in SU6 or SU7.0.
It can send data but in can NOT GET DATA.
Simple Test file attached.
JClements
Premium Member
Premium Member
Postby MartinRinehart » Thu Oct 08, 2009 4:58 pm
JClements wrote:Martin, it doesn't work in SU6 or SU7.0.
Odd. It was developed in 7.0. I haven't upgraded yet.
Thanks for the test model, but it got and sent fine on my machine. What problem was I supposed to see?
MartinRinehart
Postby JClements » Thu Oct 08, 2009 5:11 pm
Get Data From Model doesn't update after using it the first time.
So,
open file.
Open VisPro
Get Data from Model
Make changes via the Layers Window
Get Data From Model ... changes are not picked up.
Likewise, close model and reopen, make visibility changes, open VisPro, Get Data From Model doesn't change anything.
JClements
Premium Member
Premium Member
Postby MartinRinehart » Thu Oct 08, 2009 5:28 pm
JClements wrote:Make changes via the Layers Window
I bet you didn't Update. Scene changes aren't part of the model until you Update the scene.
MartinRinehart
Postby JClements » Thu Oct 08, 2009 5:41 pm
But I didn't change any scenes. I merely opened the file, made layer visibility changes, and tried to update VisPro.
JClements
Premium Member
Premium Member
Postby MartinRinehart » Thu Oct 08, 2009 6:48 pm
JClements wrote:But I didn't change any scenes. I merely opened the file, made layer visibility changes, and tried to update VisPro.
VisMap can't "see" any changes until you update a scene. Internally, it marches through your scenes one at a time asking "who's visible here?" So, until you change a scene it can't see what you've done. This is in the "Gotchas" in the VisMap doc. Maybe I should repeat that in the VisMap Pro doc.
If it will make you feel any better, you are not the first person bitten by this "bug." You are corresponding with the man who has that honor.
MartinRinehart
Postby Edson » Thu Oct 08, 2009 6:52 pm
martin,
i have tried it on a simple model and it worked but on larger files i get the old message and no layers appear.
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby JClements » Thu Oct 08, 2009 7:06 pm
Can't you just add a ruby snippet which performs a Scene update to a scene called "VisPro Updater Proxy".
It would just be a proxy with no attributes associated with it so the rest of the VisPro script could get around the "bug".
If no scene named "VisProUpdater Proxy" existed it would be created and if it does exist then an update function would be performed and the rest of your existing script would be executed
JClements
Premium Member
Premium Member
Postby MartinRinehart » Thu Oct 08, 2009 7:53 pm
JClements wrote:If no scene named "VisProUpdater Proxy" existed it would be created and if it does exist then an update function would be performed and the rest of your existing script would be executed
A Scene0, roughly analogous to Layer0? What you're looking at? Hmmm.
MartinRinehart
Postby JClements » Thu Oct 08, 2009 8:00 pm
Yup. I used the name VisPro with a detailed description so the user would know its origin.
I guess you could delete the Proxy Scene at the tail end of the script. Not sure creating and deleting would slow things down tho.
JClements
Premium Member
Premium Member
Postby chrisglasier » Fri Oct 09, 2009 2:37 am
JClements wrote:Get Data From Model doesn't update after using it the first time.
So,
open file.
Open VisPro
Get Data from Model
Seems Martin hasn't got to the bit about observers just yet.
With JSON machines we can analyse what is to be achieved so that IT can help with automation to achieve it.
chrisglasier
PluginStore Author
PluginStore Author
Return to Plugins
Users browsing this forum: alegamba, fadynm, kamaluz, Maksmp, MKBate and 14 guests
