[Plugin] Bounding Box View
Postby AdamB » Tue Aug 25, 2009 9:05 pm
Right-click on a ComponentInstance and choose "Replace with Proxy Component" to flip it into a box.
Right-click again to restore the original geometry.
Available in the PluginStore
Adam
Last edited by Rich O Brien on Wed Dec 04, 2013 10:53 pm, edited 8 times in total.
Reason: Just cleaning up and organizing the Plugin forum. Correcting [Plugin] tag and uppercase title
AdamB
LightUp Support
LightUp Support
Re: BOUNDING BOX VIEW
Postby thomthom » Tue Aug 25, 2009 9:10 pm
PluginStore Author
PluginStore Author
Postby DJMX1 » Tue Aug 25, 2009 9:19 pm
thanks, ghostcomp is great for far render, but bounding box is better for work immediately.
DJMX1
Postby Chris Fullmer » Tue Aug 25, 2009 9:53 pm
I had worked on a script that replaced groups with more of a true bounding box, but never quite got it to do what I wanted it to do. I have some more ideas now, as I am learning more about Ruby and the SU API. But I would not ocunt on anything from me, especially seeing that Fredo is working on Ghost Comp.
As for actually forcing the screen to stick on that level of bounding box detail, its not something that is do-able through Ruby. We can only come close, with things like ghostcomp.
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby Gaieus » Wed Aug 26, 2009 6:56 am
Hey Adam, thanks for this cool plugin. :thumb:
However, I do believe it would really deserve its own topic (marked with the [PLUGIN] tag for everyone's benefit). If you also agree, I can split this post off the above topic.
Re: [PLUGIN] BOUNDING BOX VIEW
Postby AdamB » Wed Aug 26, 2009 8:00 am
Sounds like a plan. I guess something like:
[PLUGIN] Proxy View
[Burn after reading :-)]
AdamB
LightUp Support
LightUp Support
Postby DJMX1 » Wed Aug 26, 2009 8:21 am
Thank you Adam. Your plugin is based Ghostcomp really! is very useful but I still am disappointed, I just want an even lighter than wireframe in order to turn quickly in a complex scene.
NORMAL VIEW with shadows
BOUNDING BOX VIEW apply automatically when the computer is on its knees
i want to control myself this view 8-)
DJMX1
Postby rv1974 » Wed Aug 26, 2009 11:58 am
AdamB wrote:I mentioned sometime ago I'd post the LightUp version of this. So here it is - just put the Ruby in your plugins folder.
Adam
Adam if only you could make proxy boxes be rendered as original components (on export 2d grafics) it'd be the greatest break thru!
rv1974
Postby AdamB » Wed Aug 26, 2009 4:06 pm
DJMX1 wrote:Thank you Adam. Your plugin is based Ghostcomp really! is very useful but I still am disappointed, I just want an even lighter than wireframe in order to turn quickly in a complex scene.
What you're asking is Level-of-Detail switching which is going to be clunky in SU. You could do something that watched the camera position etc but its a real hack. So what you ask is something for Google not me. :-(
DJMX1 wrote:Adam if only you could make proxy boxes be rendered as original components (on export 2d grafics) it'd be the greatest break thru!
Ah, well if you're using that very fine LightUp software, this happens automagically when you switch to Tourtool mode.
Adam
AdamB
LightUp Support
LightUp Support
Postby tfdesign » Mon Nov 15, 2010 11:19 pm
AdamB wrote:Right-click on a ComponentInstance and choose "Replace with Proxy Component" to flip it into a box.
Adam, I can't seem to get this plugin to work.
If I right click on a component, the component doesn't box up. If I click it again, it disappears altogether.
Any clues? Mac OSX perhaps?
My book "Let's SketchUp!" Download from here
tfdesign
Top SketchUcator
Re: [Plugin] Bounding Box View
Postby tfdesign » Tue Nov 16, 2010 5:28 pm
Got the proxy plugin working- but only with specific types of components, ie it doesn't seem to work with 2D components (not that this really matters at this stage though :) )
Tom
tfdesign
Top SketchUcator
Postby Didier Bur » Tue Nov 16, 2010 5:43 pm
I also have a plugin called "proxy" on the RLD: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=599 by A. Billyard: "Swaps component definitions with bounding boxes."
Does this one do the same thing ? Apparently yes.
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Postby david23lara » Sat Mar 24, 2012 4:43 am
Just AWESOME! thanks!
david23lara
Postby alien_killer » Tue Sep 25, 2012 7:54 am
Thanks alot mate... i hope it works with vray.... one reason i moved to Max was cause of proxies.... but SKP is the best
alien_killer
Postby ccaponigro » Thu Nov 20, 2014 4:44 pm
I love this plug in. If it did batches or mixed selections I'd be over the moon. I like to make all my furniture and appliances proxies and switch them back for viewing or publishing but doing them one at a time is a bummer.
cfcaia.com
ccaponigro
Premium Member
Premium Member
Postby sdmitch » Thu Nov 20, 2014 9:43 pm
cc, I have sent you, by personal message, my version of Bounding Box View. It works with individual components or a selection.
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby ccaponigro » Sun Nov 23, 2014 1:08 am
sdmitch wrote:cc, I have sent you, by personal message, my version of Bounding Box View. It works with individual components or a selection.
Got it and using it! Works great I place all my heavy components on a layer and use select all on layer and bingo a punch of simple boxes.
Here is a little trick. Some times snaping to a point on some components can be a pain. So I just make a proxy move or copy it using the proxy rectangle which is easy to find points on and then just switch it back.
Anyway thanks!!!
cfcaia.com
ccaponigro
Premium Member
Premium Member
Postby Spartipilo » Sat Oct 28, 2017 8:22 am
I liked a lot this plugin, until I had a bugsplat, and my autosave didn't store the original models of the proxy cubes.
Spartipilo
Return to Plugins
Users browsing this forum: alanazuquello156, Diamoss, puntoclassic and 15 guests
