SketchUcation Premium Membership
[Plugin] triangulateFaces.rb v1.2 20101120
Postby TIG » Fri Jul 03, 2009 5:47 pm
Now new improved 'triangulate' - It now 'triangulates' [almost] everything...
Script: triangulate.rb
Code Usage: triangulate(array_of_faces)
Result: it triangulates faces in array...
Plugin Usage:
Result: it triangulates faces in selection...
Known Issues:
Even complex single looped faces should work OK.
Simple faces with one or two holes are also usually OK.
Very large numbers of faces might cause a 'white-out',
processing is continuing, please be patient...
Complex faces with complex multiple holes in them might 'splat' !
Add some extra dividing lines and retry...
Very small faces might not work properly and 'splat' ! Scale them...
Failed triangulations are warned and can be undone...
Save your work before using this tool...
v1.0 First issue. 20090703
v1.1 4 sided faces with 3 in line vertices trapped.
undo operation added. 20090703 pm
v1.2 L-shaped AND 4-sided faces trapped. 20090703 pm+
v1.3 Menu added, warns if no suitable selection. 20090703 pm++
v2.0 Now triangulates all >= 4-sided faces and traps awkward L/U/holed
shapes etc. 20090707
v2.1 Renamed 'triangulatefaces' to avoid clashes with delauney/cloud etc.
20090708
Now Obsolete - see triangulateFaces.rb later in thread... HERE http://forums.sketchucation.com/viewtop ... 13#p175613
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] triangulate.rb v1.1
Postby TIG » Fri Jul 03, 2009 6:14 pm
Updated
v1.1 4-sided faces with 3 in line vertices trapped,undo operation added 20090703pm
viewtopic.php?p=169956#p169956
Global Moderator
License type: Pro
Postby Chris Fullmer » Fri Jul 03, 2009 6:31 pm
Are you going to put into the menu system? Or just run it in the webconsole? or...?
All my Plugins I've written
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby sepo » Fri Jul 03, 2009 6:35 pm
Well it does not appear in plugins menu nor in context menu.
sepo
License type: Pro
Postby Burkhard » Fri Jul 03, 2009 6:47 pm
What's the difference to this plugin?
Author unknown!
Burkhard
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Postby Burkhard » Fri Jul 03, 2009 9:59 pm
It is possible to add a seperate " add detail" tool for further triangulations?
It could be usefull for detail modeling.
1- Triangulate face and open:
2- Input Box with values like: 10x and available smoothcheckbox
3- Set complete triangulation in one step
You can seperate the Sandbox " add detail" from the original script. But then the new script should be coded ( with strings) in the same way to add it in one toolbar.
usefull?
Burkhard
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Re: [Plugin] triangulate.rb v1.2
Postby TIG » Fri Jul 03, 2009 10:51 pm
Here's v1.2 viewtopic.php?p=169956#p169956
Burkhard: To add extra detail sub-division to faces use my Advertex+.rb tools - using the appropriate modifier key you can add a vertex onto a face and new edges will then be added up to it from every face-vertex...
It's a little different from the other script (which I don't recall seeing before) - mine only sub-divides quads - as Chris's request and it also traps for any possible new 'dividing' edges not falling on the face - e.g. with L-shaped or 3nr co-linear-vertex faces...
B/Chris: It runs by selecting some faces and then typing triangulate in the Ruby-console... To add a menu item you can simply add these lines onto the end of the script using a plain-text editor...
Code: Select all
### Menu ###
UI.menu("Plugins").add_item("Triangulate 4-edged Face in Selection"){triangulate}if not file_loaded?(File.basename(__FILE__))
file_loaded(File.basename(__FILE__))
Global Moderator
License type: Pro
Postby TIG » Fri Jul 03, 2009 11:03 pm
OK, OK... 8-) Here's v1.3 viewtopic.php?p=169956#p169956
It now has a menu and traps for unsuitable selections...
I only made it as a quick hack because Chris asked how to triangulate the quad faces of a sphere........................
Global Moderator
License type: Pro
Re: [Plugin] triangulate.rb v2.0
Postby TIG » Tue Jul 07, 2009 8:44 pm
Here's v2.0, now new improved - 'triangulates' [almost] everything...
Global Moderator
License type: Pro
Postby Chris Fullmer » Tue Jul 07, 2009 9:36 pm
Thanks TIG, this is great!!!
SketchUp Team
SketchUp version: 8
License type: Pro
Re: [Plugin] triangulate.rb v2.1
Postby TIG » Wed Jul 08, 2009 9:51 am
Here's v2.1, I've renamed the command triangulatefaces(array_of_faces) as 'triangulate' was already a defined command inside delauney/cloud scripts etc, used to triangulate points...
Please replace earlier versions with this new file to avoid clashes...
Global Moderator
License type: Pro
Postby sepo » Wed Jul 08, 2009 12:01 pm
Cheers Tig...nice one.
sepo
License type: Pro
Postby CPhillips » Fri Jul 24, 2009 2:29 am
Here is the method I use:
Code: Select all
def triangulateFace(face)
    ents=Sketchup.active_model.active_entities
    faces=face.mesh.polygons
    verts=face.mesh.points
    faces.each{|f|
        ents.add_line(verts[f[0].abs-1],verts[f[1].abs-1])
        ents.add_line(verts[f[1].abs-1],verts[f[2].abs-1])
        ents.add_line(verts[f[2].abs-1],verts[f[0].abs-1])
The nice thing is it cant fail to triangulate regardless of the shape or number of holes. But it unfortunately adds faces to the "holes". Or rather Sketchup does. Does anyone a way to add an edge without Sketchup attempting the "heal" the face?
CPhillips
Postby TIG » Fri Jul 24, 2009 9:57 am
I thought of that approach but abandoned it because of that facing hole problem...
Global Moderator
License type: Pro
Postby kwistenbiebel » Fri Jul 24, 2009 12:46 pm
Thank you TIG for this plugin. :thumb:
Do we still need to add those extra lines in the ruby console to get the plugin in a menu?
I couldn't find it in the Plugins/Tools menu, thus my question...
kwistenbiebel
Postby TIG » Fri Jul 24, 2009 1:11 pm
kwistenbiebel wrote:Thank you TIG for this plugin. :thumb:
Do we still need to add those extra lines in the ruby console to get a menu?
'Triangulate Faces in Selection' should be in the Plugins menu...
Global Moderator
License type: Pro
Postby kwistenbiebel » Fri Jul 24, 2009 1:25 pm
Strange, I can't find it anywhere in my long long plugin list :oops: .
Maybe it clashes with some other plugin? (I do have WxSU installed which caused me trouble with other plugins in the past).
By the way, I am on SU6 Pro.
kwistenbiebel
Postby TIG » Fri Jul 24, 2009 4:12 pm
kwistenbiebel wrote:Strange, I can't find it anywhere in my long long plugin list :oops: .
If you have 2.1 open it in a text editor and read the last bit it should define the menu...
Global Moderator
License type: Pro
Postby CPhillips » Wed Jul 29, 2009 8:07 pm
I finally figured out how to triangulate any face without the side effect of filling holes.
Code: Select all
    mesh=face.mesh(1)
    faces=mesh.polygons
    verts=mesh.points
    uvs=mesh.uvs(true)
    outmesh = Geom::PolygonMesh.new
    faces.each{|f|
        outmesh.add_polygon(verts[f[0].abs-1],verts[f[1].abs-1],verts[f[2].abs-1])
    mat=face.material
    face.erase!
    grp = ents.add_group
    grp.entities.add_faces_from_mesh(outmesh)
    grp.entities.each{|e|
        if(e.class==Sketchup::Edge)
            e.smooth=false
            e.soft=false
        elsif(e.class==Sketchup::Face && mat!=nil)
               #handle materials and uvs.
            uva=verts.index(e.vertices[0].position)
            uvb=verts.index(e.vertices[1].position)
            uvc=verts.index(e.vertices[2].position)
            e.material=mat
            e.position_material(mat,[verts[uva],uvs[uva],verts[uvb],uvs[uvb],verts[uvc],uvs[uvc]],true)
    grp.explode
CPhillips
Re: [Plugin] triangulateFaces.rb v1.2 20101120
Postby TIG » Thu Jul 30, 2009 9:59 am
Thanks to CPhillips's inciteful ideas I have now made a 'joint' script called 'triangulateFaces.rb' which is attached. It uses CPhillips's triangulateFace(face) code [with a slight TIG addition for back_materials] and the TIG Plugin triangulateFaces(face_array)...
Originally 2009 (c) CPhillips* then (c) TIG** THEN (c) ThomThom ***
Script: triangulateFaces.rb
Code Usage: triangulateFace(face)*
Result: it triangulates a face... all Texture UVs are kept.
Plugin Usage: triangulateFaces(faces_array)**
Result: it triangulates faces in a selection...
v1.0
First Release: Def Code 'mesh' idea by CPhillips*,
retained back_materials added by TIG [failed] ###,
Plugin parts by TIG**. 20090729
v1.1
Rewritten entirely by TIG... THEN completely corrected by Thomthom (TT)!***
It now retains all Texture mapping successfully. 20091203
v1.2
Triangulated faces with 4 sides glitch fixed using intersection.
triangulateFaces.rb
Global Moderator
License type: Pro
Re: [Plugin] triangulateFaces.rb v2.1
Postby Coronel » Thu Jul 30, 2009 12:40 pm
Could you please clarify for a 3D newie the purpose of triangulation in this case?
Does it means the model will be correct or will work better or is merely a way of get more detail?
Coronel
Postby TIG » Thu Jul 30, 2009 8:39 pm
Coronel wrote:Could you please clarify for a 3D newie the purpose of triangulation in this case?
If you have a mesh that's rectangular it won't deform consistently. If you triangulate the faces they will... etc.
Global Moderator
License type: Pro
Re: [Plugin] triangulateFaces.rb v1.0
Postby CPhillips » Thu Jul 30, 2009 10:34 pm
I needed the triangulation to prepare a model for export.
Thanks for incorporating it into your script TIG! Why is it that back facing UV's didn't work?
CPhillips
Postby TIG » Thu Jul 30, 2009 10:53 pm
CPhillips wrote:I needed the triangulation to prepare a model for export.
There is only a method to 'position material textures on a face' - and that assumes a 'front_face' - there's no 'back_face' method ? ...
Global Moderator
License type: Pro
Postby CPhillips » Fri Jul 31, 2009 12:41 am
There is only a method to 'place material textures on a face' - and that assumes a 'front_face' - there's no 'back_face' method...
Do you mean position_material? It takes a bool for front or back material
http://code.google.com/apis/sketchup/do ... n_material
CPhillips
Postby ideas_arte » Fri Jul 31, 2009 5:36 pm
Thanx really useful!
where download? :oops:
ideas_arte
Postby Jim » Fri Jul 31, 2009 5:49 pm
ideas_arte wrote:where download?
That's a valid question; it is not clear which version is the latest, and it is harder than necessary to locate the download.
The download is about 5 posts before this one.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby TIG » Fri Jul 31, 2009 6:45 pm
Duh! :oops: I'll adjust the code and re-post...
Global Moderator
License type: Pro
Postby TIG » Fri Jul 31, 2009 10:02 pm
There's something afoot... What I posted before worked - on keeping the front face texture mapping but not on the back_face... Now when I try it it fails to map both faces ? Any ideas - CPhillips's idea worked fine in tests but now seems to fail...
Global Moderator
License type: Pro
Postby CPhillips » Sat Aug 01, 2009 2:38 am
Post the code and I'll have a look. It might be the face.mesh(1). I think you need to use a different number when you want back uv's as well.
CPhillips
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Next
Return to Plugins
Users browsing this forum: glro, leetran72, massimo, McGyver, robertacuellas and 9 guests
