SketchUcation Plugin Store
[Plugin] Add Point at Line Face Intersection
Postby TIG » Tue Jun 30, 2009 12:03 pm
### Select at least one face and at least one line/cline[guide-line], run the tool...
### a cpoint [guide-point] is added at the intersection of each face's plane and each line,
### an edge/cline[guide-line] need not physically intersect the face,
### the cpoint[guide-point] can also be located off a face, on it's plane.
### edges/clines[guide-lines] parallel with a face's plane are ignored.
### You can project any lines onto any face-plane - try the edges of a complex 3D shape... :ugeek:
cpointAtLineFaceIntersection.rb
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] Add Point at Line Face Intersection
Postby Pilou » Tue Jun 30, 2009 12:12 pm
Very reactive ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Free Agent » Tue Jun 30, 2009 2:02 pm
crazy, you are a life saver, thank you, i was using add point from the projections tool bar to manually place 600 points... my mouse finger thanx you :) :thumb:
Free Agent
Postby utiler » Tue Jun 30, 2009 11:44 pm
Thanks TIG, but doesn't point.rb do this?
I guess the difference is if you have multiple point required then this will be a real time saver!!
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby TIG » Wed Jul 01, 2009 9:28 am
utiler wrote:Thanks TIG, but doesn't point.rb do this?
No: 'point.rb' draws a cpoint wherever you pick for one to be placed:
but 'cpointAtLineFaceIntersection.rb' takes selected faces, edges and clines [note that it also works on multi-selections] and it then works out their intersections [even if these fall 'off-face' but are still on the face's plane], it then places a cpoint at each of these intersections... As you can see from the illustrated example - you make a selection of an inclined 'cylindrical' set of edges [made by unsmoothing the cylinder, erasing its faces etc] and the blue-coloured face, you run the tool off the menu and you quickly get the set of projected cpoints - in this case they form an ellipse where the cylindrical edges [if extended] would intersect with the plane of the face [in this case off the face to one side as the intersections with the face-plane occur off the face itself]...
It's a bit like the 'intersect' tool, but instead of making geometry it makes cpoints and with this tool the faces/edges/clines don't even need to physically intersect - just potentially intersect if they were to be made bigger/longer etc...
Global Moderator
SketchUp version: 8
License type: Pro
Postby utiler » Wed Jul 01, 2009 11:23 pm
Thanks for the reply, TIG. I did try your script over night and yes, it is quite different!!!! Thanks; i think it will be a handy addition.....
I love this place.
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Return to Plugins
Users browsing this forum: fgi3d, Heritrix Crawler, kajka and 8 guests
