[Plugin] Multi face offset
Postby remus » Sun Jun 28, 2009 11:27 am
As per this request: viewtopic.php?f=180&t=20193
version 3 now up.
You'll need offset.rb, courtesy of RickW.
How it works:
1. select the faces you want to offset
2. Plugins->Multi face Offset
3. Put in the distance
4. ...and away you go
Stuff id like to change but probably wont:
-condense it in to one script with a choice of units. Added, sort of. See thoms post.
7
Reason: Just cleaning up and organizing the Plugin forum. Correcting [Plugin] tag
remus
Re: [plugin] Multi face offset
Postby thomthom » Sun Jun 28, 2009 11:34 am
Why all the different versions? .to_l http://code.google.com/intl/nb/apis/ske ... .html#to_l should take care of the units for you.
PluginStore Author
PluginStore Author
Postby remus » Sun Jun 28, 2009 11:41 am
thats a rather handy tip, thanks.
remus
Postby thomthom » Sun Jun 28, 2009 11:52 am
Btw, .to_l might give different result from what you expect - depending on that object you convert.
If you have a number - 30.to_l <- that means 30 inches.
If you have a String - "30".to_l <- that means 30 model units, so if your model units are mm - then you'll get mm.
And then with a string, users can override the model units. If the model units are mm and a user type "30m" you'll still get the correct length.
PluginStore Author
PluginStore Author
Postby rv1974 » Sun Jun 28, 2009 1:21 pm
Isn't windowizer already make the same ?
rv1974
Postby thomthom » Sun Jun 28, 2009 1:28 pm
Windowizer generates window components. This is just plain offset.
PluginStore Author
PluginStore Author
Postby Gaieus » Sun Jun 28, 2009 1:37 pm
Remus, please, post some image in the first post so that we can have some clue what it does (and I can rip it for TDC, too)
Postby rv1974 » Sun Jun 28, 2009 2:12 pm
thomthom wrote:Windowizer generates window components. This is just plain offset.
A "window component" is a pure abstraction. With glass inset =0 it makes the same plain offset+ additional options (i.e. materials assignment, edit and eraze in the future)
rv1974
Postby chango70 » Sun Jun 28, 2009 2:29 pm
Does the faces have to be on the same plane?
chango70
Postby remus » Sun Jun 28, 2009 6:06 pm
No, the faces can be on any plane. It wont work on curvy things, though.
As for windowizer doing the same thing, it probably can, and i think Fred06's offset on surface could do it as well, i just fancied writing it for a bit of practice.
remus
Postby DIEGO-RODRIGUEZ » Sun Jun 28, 2009 8:19 pm
Thanks, but does not work.
Using sketchup 6 and 7, windowsxp SP3 in Spanish
If you have a solution, thank you
DIEGO-RODRIGUEZ
Banned
Postby remus » Sun Jun 28, 2009 9:11 pm
Could you open the ruby console (window->ruby console), run the script and post whatever comes up in the console?
remus
Postby DIEGO-RODRIGUEZ » Sun Jun 28, 2009 9:49 pm
Error: #<NoMethodError: undefined method `offset' for #<Sketchup::Face:0x5aad818>>
C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:23:in `multi_face_offset'
C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:21:in `each'
C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:21:in `multi_face_offset'
C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:34
C:/Archivos de programa/Google/Google SketchUp 6/Plugins/multi face offset.rb:33:in `call'
DIEGO-RODRIGUEZ
Banned
Postby remus » Sun Jun 28, 2009 10:17 pm
most unusual, i'll have a look in to it and see if i can find out whats going on.
remus
Postby TIG » Sun Jun 28, 2009 10:22 pm
Remus - do you have RickW's [free from Smustard] 'offset.rb' and elcorto doesn't ?
Global Moderator
Postby DIEGO-RODRIGUEZ » Sun Jun 28, 2009 10:26 pm
Thanks Tig, I had no offset.rb.
Now works fine
DIEGO-RODRIGUEZ
Banned
Postby remus » Sun Jun 28, 2009 10:28 pm
I havent got it, but im guessing its included in some other script. Thanks for the pointer by the way, i'll add it to the 1st post.
remus
Postby TIG » Sun Jun 28, 2009 10:32 pm
It's the simple things that are often the most complicated !
[¡Se trata de las cosas simples que a menudo son las más complicadas!]
Global Moderator
Postby pilou » Mon Jun 29, 2009 1:39 am
And seems Protrude by Jim Foltz makes the same and more! :mrgreen:
Speedy Galerie
Top SketchUcator
Postby remus » Mon Jun 29, 2009 8:18 am
A veritable Smörgåsbord of repeated functionality :P
remus
Postby pilou » Mon Jun 29, 2009 8:56 am
@Remus
Thx for this new curious name :lol:
Speedy Galerie
Top SketchUcator
Postby Pixero » Mon Jun 29, 2009 11:09 am
Smörgåsbord is a swedish word. :thumb:
Pixero
Postby DIEGO-RODRIGUEZ » Mon Jun 29, 2009 2:25 pm
Be possible. After applying offset. be selected the new drawing?
then able to apply, for example, multiple Push Pull
sorry for my English. Thank you
DIEGO-RODRIGUEZ
Banned
Postby pilou » Mon Jun 29, 2009 3:43 pm
Protrude above can make that , just offset= 0 after use it and enable Height = that you want ;)
Only Protrude keep the selection ;) Protrude is a very funny plug! :fro:
For Push Pull multiple in general you can also use Joint Push Pull by Fredo6 or Projection2 by Didier Bur ;)
But both lost the selection! :o
Speedy Galerie
Top SketchUcator
Postby DIEGO-RODRIGUEZ » Mon Jun 29, 2009 8:07 pm
"Pilou" You're right, thank you very much
DIEGO-RODRIGUEZ
Banned
Postby CadFather » Tue Jun 30, 2009 3:25 pm
Hi Remus, first thanks for the useful script - i found out the offset may end reversed at times
CadFather
PluginStore Author
PluginStore Author
Postby remus » Tue Jun 30, 2009 5:46 pm
So it does. I dont suppose youve found what causes it? Whatever it is, i suspect it is a bug in offset.rb, it would be good to be able to pass it on to rickw, though.
remus
Postby CadFather » Tue Jun 30, 2009 9:38 pm
the hunch, says it may be something to do with the direction of the lines (start-end-front-back business..) - but i could not spot the pattern for sure yet
CadFather
PluginStore Author
PluginStore Author
Postby CadFather » Thu Jul 02, 2009 9:03 pm
Remus, couple of icons if needed..
CadFather
PluginStore Author
PluginStore Author
Postby remus » Thu Jul 02, 2009 9:04 pm
I dont know how to do toolbars :oops:
I'll give it a go, though, those icons are too nice to waste :thumb:
remus
Next
Return to Plugins
cron
Users browsing this forum: filipecadu and 10 guests
