[Plugin] Projections version 2a UPDATED
Postby Didier Bur » Thu Jun 25, 2009 11:11 am
Hi all,
It's time for an update of my projection and guides tools set, with new features and more interactive tools.
What's new ? Everything.
PDF doc included.
Here's the toolbar:
Updated 29.06.09: 4 new tools and several bug fixes
Updated 03.07.09:
- a new tool by TIG (thanks to him)
- you can now select what guides to erase: SU guides, plugin guides or all guides
- edges are soften when extruding arcs, circles and curves.
Developpers note: anyone knows how to smooth surfaces ? entity.smooth=true doesn't seem to work as expected.
Patch on 05.07.09 (missing icons) :oops:
Patch on 08.07.09 just the RBS, including faces smoothing when extruding curves.
Download the latest version from the PluginStore...
Download
Older versions...
6
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: [plugin] Projections version 2
Postby pilou » Thu Jun 25, 2009 11:46 am
AH cool this new version ! :thumb:
Whish there is the extrude along vector with selection at the end :) (yes it is!) :berserk:
Bravo :fro:
Ps Extrude along a vector will be absolutely terrific if "offset" (or tricky sign of vector) can be integrated when necessary!
Maybe with CTRL pressed?
Because if I use the normal offset I lost the selection for follow the extrude along a vector! :o
Allez Didier un dernier petit effort et c'est gagné! :enlight:
Speedy Galerie
Top SketchUcator
Postby troyhome » Thu Jun 25, 2009 11:57 am
Thanks so much! i'm going to try it out right now!
IOviz.com
SU Pro 2017 PC
Thea: latest
vray4SU latest
troyhome
Postby massimo » Thu Jun 25, 2009 1:22 pm
Hi Didier, first of all thanks for this great update (i especially like tools n#4 and n#5). I tried it quickly and i had two problems.
1) In SU 6 i overwrote the folder and the .rb file on the older projections ones. I opened SU, the new toolbar was there but, with the exception of the point tool, nothing worked. So i deleted the .rb file and the folder from the plugins folder, i reinstalled them and that worked. But..
2) The tool n#2 seems not working properly. The temporary display appears, but when i click on a face, for example on a cube face, the behaviour of the tool is strange. Sometimes it draws only 3 construction lines, sometimes nothing. The same happens with a line click.
Maybe my fault?
Thanks.
Massimo.
massimo
Postby silver_shadow » Thu Jun 25, 2009 2:29 pm
gonna give it a shot, thanx
silver_shadow
Postby dmatho » Thu Jun 25, 2009 2:34 pm
Ahhhh-mazing! Thanks Didier!
Cheers,
- Diego -
dmatho
Postby Didier Bur » Thu Jun 25, 2009 2:44 pm
Hi Massimo,
You found the first bug !
The automatic guides cleaner is guilty :bounce:
Let's wait a little for other bug reports, and I'll publish a patch.
Thanks for reporting,
Didier Bur
Didier Bur
Postby urgen » Thu Jun 25, 2009 4:36 pm
....many thanks Didier! :thumb:
--pupil forever...------
urgen
Postby massimo » Thu Jun 25, 2009 5:28 pm
I've played a bit with tool n#5 with 4 divisions.
Maybe another bug?
massimo
Postby CadFather » Thu Jun 25, 2009 5:43 pm
glad to see Didier is back.. Thanks Didier!
CadFather
PluginStore Author
PluginStore Author
Postby MALAISE » Thu Jun 25, 2009 6:35 pm
Hi, Masters are back ! :thumb: :thumb:
I'll try it very soon.
MALAISE
MALAISE
Postby Didier Bur » Thu Jun 25, 2009 6:46 pm
Massimo,
I cannot reproduce the division problem. How do you do it ?
Didier Bur
Didier Bur
Postby massimo » Thu Jun 25, 2009 7:02 pm
Really strange. I've tried again. Sometimes works and sometimes not. Simply draw a rectangle then pushpull. Copy the solid along the green axe and apply to the first solid "insert guide at divisions" horizontally (it works), press esc, and then apply to the second the tool vertically (sometimes it doesn't works). The same happens (never works) if you try to do that on a single face in order to have a grid (horizontally + vertically).
Maybe it's only my problem?
massimo
Postby ideas_arte » Thu Jun 25, 2009 7:18 pm
Many thank you very much ..!
If the first is very good, this is much much better ..!
Thanks friend ..! :ecstatic:
ideas_arte
Postby Didier Bur » Thu Jun 25, 2009 8:14 pm
Unfortunately I think it is your problem, because what you describe always work on my side...
Didier Bur
Didier Bur
Postby mitcorb » Thu Jun 25, 2009 9:06 pm
could it be camera position relative to horizon when selection is done? probably not, just wondering.
mitcorb
Top SketchUcator
Postby massimo » Thu Jun 25, 2009 9:11 pm
Unfortunately nothing to do with camera position, Mitcorb. Don't understand why but it simply doesn't work for me.
massimo
Postby pilou » Thu Jun 25, 2009 9:58 pm
Any chance to integrate an "Offset" or similar in the "Extrude line along a vector"?
Speedy Galerie
Top SketchUcator
Postby massimo » Fri Jun 26, 2009 7:37 am
Hi Didier and thanks for your patience. When i use for the second time "insert guides at divisions" some lines are missed (very often the middle line) but i've noticed that if i click a little bit below the edge of the solid it works fine. Maybe this makes some sense to you?
massimo
Postby urgen » Fri Jun 26, 2009 9:13 am
... hi Dider! ....is it possible to add old function "create lines at intersection of selected faces" in a script?...It's very useful function :? ....I do not want come back to old script "ClineAtFaceIntersection.rb" :roll:
urgen
Postby Didier Bur » Fri Jun 26, 2009 3:50 pm
OK, no problem, I was thinking this one were not so useful. I'll put it in next update.
Didier Bur
Didier Bur
Postby urgen » Fri Jun 26, 2009 4:26 pm
....thanks,Didier! :P
...For drawing of difficult roofs this function is very necessary ;)
urgen
Postby Didier Bur » Fri Jun 26, 2009 5:16 pm
Yes, it is due to the "automatic cleaner" bug. Bug was corrected yesterday, that's why this didn't happen here ;)
Didier Bur
Didier Bur
Postby rv1974 » Sun Jun 28, 2009 7:53 am
Hi Didier!
I can't make your new commands work.
Some quotations from console:
Error: #<NameError: uninitialized constant ProjectCpointTool>
C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47
C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47:in `call'
Error: #<NameError: uninitialized constant XLinesThrougLinesTool>
C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23
C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23:in `call'
Any ideas what's wrong in my case?
And thank you again and again for your contributions.
rv1974
Postby Didier Bur » Sun Jun 28, 2009 8:10 pm
hi rv1974,
your installation is incorrect. You must have a sub-folder "projections" under plugins after unzipping the archive. Check for it, i'm almost sure this is not the case ;)
Didier Bur
Didier Bur
Postby DIEGO-RODRIGUEZ » Sun Jun 28, 2009 10:31 pm
Didier, thank you for this fantastic tool.
But I have the same problem massimo, with guide lines
DIEGO-RODRIGUEZ
Banned
Postby rv1974 » Mon Jun 29, 2009 9:10 am
Didier Bur wrote:hi rv1974,
For a 1st sight everything is OK. In fact I have your toolbar and the point tool working (one single click though)
rv1974
Postby Didier Bur » Mon Jun 29, 2009 11:40 am
Yes but I also see that you have another 'projection.rb' file which is the previous version. Do a clean install, removing ALL previous files in the Projections folder, and everything will go OK.
Regards,
Didier Bur
Didier Bur
Re: [plugin] Projections version 2 UPDATED 29.06.09
Postby massimo » Mon Jun 29, 2009 12:37 pm
Thanks Didier, now it works very well. :thumb:
massimo
Postby otb designworks » Mon Jun 29, 2009 1:48 pm
I am using a MAC pro, and this version 2 has no functionality on my computer.
Choosing any function has no effect whatsoever.
I am attaching the errors indicated in the Ruby console.
I have deleted all previous versions from my plug in folder.
Thanks and help! I use these all the time, especially extrude lines, which is a god send sometimes.
Cheers, Chuck
Cheers, Chuck
OTB Designworks is on Youtube
otb designworks
Next
Return to Plugins
Users browsing this forum: ananan1523, gauyeuvit, kamranrj and 16 guests
