SketchUcation Premium Membership
[Plugin] ExtendTool v0.2 (update 20090708)
Postby Matt666 » Tue Jun 16, 2009 3:11 pm
Hi all!
Here is a plugin that extend edge you pointed on. It tries to work like acad Extend tool...
Usage:
  • First select edges or faces that will be limits of the extended edges. If you don't select anything, script will select all the model as the limit.
  • Point on each edge you want to extend. Be careful of side of the edge pointed. It determinates sense of the extension.
I hope it works with Win and Mac version. A cursor replaces standard SU cursor.
This script may contain bugs... No. IT contains bugs! Please be patient if you find a bug, I will do my best to update the script.
All suggestions/improvments are welcome!
[EDIT] 20090708 - V0.2
New extended edges broke edges of the limits. So limits changed while script worked.
Frenglish at its best !
My scripts
Matt666
Re: [Plugin] ExtendTool v0.1 (unofficial version!)
Postby rv1974 » Tue Jun 16, 2009 3:42 pm
A very good intention Matt!
Make it a perfect example of the reverse engenering :P :
To select boundary at the beginning and then with window select a bunch of lines to be extended.
Maybe trim with shift could be added?
P.S. And what about extend faces?
rv1974
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Matt666 » Wed Jun 17, 2009 7:03 am
Hi rv1974!
With this method you can't select side of edge you want to extend... That's why I copied Autocad method. A possible improvment would be to select side of multiple edges by a path, like acad tool...
My scripts
Matt666
Postby rv1974 » Wed Jun 17, 2009 7:41 am
2009-06-17_0937.swf
I mean something like this.
P.S. BTW how to embed video in the post?
rv1974
SketchUp version: 8
License type: Pro
Postby majid » Thu Jun 25, 2009 8:48 pm
it doesn't work for me :(
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Pilou » Thu Jun 25, 2009 10:03 pm
I must try it ;)
Edit: works fine for me! :fro: (PC)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Matt666 » Fri Jun 26, 2009 7:00 am
majid wrote:it doesn't work for me
Of course lines must coplanar. That's strange it doesn't work for you...
Can you show me errors in the ruby console please?
Thank you!
Nice to read that Pilou! :D
My scripts
Matt666
Postby majid » Fri Jun 26, 2009 7:42 am
I imported a cad file , and as usuall it had lots of stray lines...so I desided to use the plugin, but nothing happend :(...
here is my plugin folder view :
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Matt666 » Fri Jun 26, 2009 8:47 am
Thank you for your answer.
Sorry, but... I don't see any ExtendTool folder and ExtendTool.rb in your plugin folder...
Can you try to download it again and to unzip it directly into plugins folder, please?
My scripts
Matt666
Postby Chris Fullmer » Fri Jun 26, 2009 8:47 am
Majid, the plugin isn't in there. Where did you put it?
Try downloading and installing again.
All my Plugins I've written
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Postby majid » Fri Jun 26, 2009 10:10 am
yes I see :roflmao: , when it didn't worked for me , I deleted it ... :), then I thought that maybe other plugins interfer it , so i shared the plugins folder picture..
also all lines are coplanar , and i repaired the inserted cad file by hand (149 trim extend needed ... :) as the autocad is going to be more fuzzy!!!!)
ok ... I am thinking that if we could have a better (smarter) cad import plugin? bkz when we import cad files , then su convertes circle to 24 sided su native cirles , and then there would be a gap between the circle and rest of the model... so maybe we could resolve this with a ruby cad importer!!! :?: :idea:
majid
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Matt666 » Fri Jun 26, 2009 10:58 am
majid,
this plugin cannot do what you describe... Perhaps try ExtendCloseLines?
My scripts
Matt666
Postby Pilou » Fri Jun 26, 2009 11:20 am
Tig has made something for that!
I must refind that ;)
Found! changearcsegments ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby EarthMover » Fri Jun 26, 2009 1:09 pm
Matt,
It works well when I have a face selected, however when I select a coplanar edge to extend to, I get a "no limit found" error in the ruby console. Any ideas?
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
EarthMover
Top SketchUcator
Postby JClements » Sat Jun 27, 2009 6:19 pm
Hi Matt:
Works well for me. I like the simple UI.
Could a similar script be developed to extend (move) a vertex (which may or may not be part of a face)?
How it might work: initiate script, pick (click) on the anchoring endpoint or guidepoint, then click on the vertex you want to move. It would basically be the same as manually doing a move-and-drag or alt-move-and-drag function, but inferencing to anything other than end-point or guide-points would be blocked.
This would be helpful when trying to move a vertex a very small distance in an area with lots of geometry.
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby Matt666 » Tue Jun 30, 2009 5:31 pm
EarthMover,
Thank you for testing it!
Can you post tested file, please? Can you show me "limit" lines or faces, and desired edges to extend?
I have no problem here. Oh yes I had a problem, but I corrected the plugin. Update will come soon.
JClements,
Thank you for the comment!
I will "investigate" to find if I can do this plugin... For the moment I think it's out of my ruby level! :lol:
My scripts
Matt666
Postby Chris Fullmer » Tue Jul 07, 2009 7:26 pm
Hey Matt, great plugin, thanks! I've just started a new project and I am putting this to good use. Thanks! Also, I edited my copy to make it so that holding shift will delete the geometry instead of extending it. I have lots of lines that are just a little too long. So instead of extending them, I want to "trim" them, like in autocad. So that little tiny bit of functionality is very helpful.
So a HUGE thanks, this is quite useful,
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby utiler » Wed Jul 08, 2009 6:37 am
Hey Chris, thats a great idea!!! wouldn't mind seeing that incorporated into matt's plugin.... :thumb:
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Re: [Plugin] ExtendTool v0.2 (update 20090708)
Postby Matt666 » Wed Jul 08, 2009 7:37 am
Glad to help you, Chris! :)
I updated code today. If you want I can update the code again with your improvment? Do you agree? Can you show us your bit of code?
My scripts
Matt666
Postby mitcorb » Thu Jul 09, 2009 1:25 pm
I had difficulty with the plugin.
In the drop down menu I see Selection with a fly out trigger that doesn't fly out to show Extend Edges. I posted in Thomthom's thread on Selection Toys, thinking that Selection was part of his suite. I will try to unload and reload to see if it works better.
I have a mild concern that other recently downloaded tools may be interfering--not sure.
Best Regards,
mitcorb
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby stefx » Mon May 10, 2010 8:01 pm
Ehi,
I am using Mac and it sounds that it doesn't work...
Any another feedback?
Stef.
stefx
Postby TIG » Mon May 10, 2010 8:02 pm
Try my 2D Tools Fillet or Adjust tools..........
Global Moderator
SketchUp version: 8
License type: Pro
Postby mirale999 » Mon Sep 12, 2011 6:04 am
mitcorb say:"In the drop down menu I see Selection with a fly out trigger that doesn't fly out to show Extend Edges."
I have the some problem but I can use the tool, the submenu is like this picture:
paranoia is a higher form of awareness...
mirale999
Postby Matt666 » Mon Sep 12, 2011 8:43 am
Ah sorry, try to delete this block at the beginning of the code:
Code: Select all
if !file_loaded?('TtMn_selection') then
    if $submenu
        organizer
= $submenu
    else
        organizer
= UI.menu('Plugins')
    $TtMn_selection_plugins_submenu
= organizer.add_submenu('Selection')
    UI.add_context_menu_handler do |menu|
        $TtMn_selection_contextual_submenu=menu.add_submenu('Selection')
    file_loaded
('TtMn_selection')
My scripts
Matt666
Postby mitcorb » Mon Sep 12, 2011 12:51 pm
Hi, Matt:
Is this block of code intended as a disambiguation, or differentiation of the two Selection tools? Or was it intended as way to allow coexistence?
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Return to Plugins
Users browsing this forum: Bing [Bot], cd3000, darmosantoso, entity66, joergber, krostah, orocriss, pyoyoon, raineysky and 11 guests
