[Plugin] #SelectionHideShow.rb v1.1
Postby TIG » Wed Jun 03, 2009 10:25 am
#SelectionHideShow.rb adds a context-menu sub-menu with various Selection, Hide and UnHide tools, such as 'Invert Selection', 'Hide/UnHide Selection', 'UnHide All Active' etc...
Edit:
v1.1 Now tests with ".is_a?" to speed-up and avoids testing already unique groups[after AlexM's advice].
Global Moderator
Re: [Plugin] #SelectionHideShow.rb
Postby pilou » Wed Jun 03, 2009 10:34 am
Very practical! :fro:
Speedy Galerie
Top SketchUcator
Postby Mr S » Wed Jun 03, 2009 11:49 am
Great!
I asked for this a while ago.
I suggested it was something that should be a standard feature in SketchUp
Now it is. Thanks for another great contribution.
Regards
Mr S
Mr S
Postby boofredlay » Wed Jun 03, 2009 1:28 pm
Thanks TIG. However I expected to see Reverse Faces in there too.
boofredlay
Global Moderator
Postby erikB » Wed Jun 03, 2009 2:06 pm
Thanks TIG, and I second the request made by Boofredlay.
erikB
erikB
Postby TIG » Wed Jun 03, 2009 4:00 pm
Reverse and Orient faces is already built-in on the context-menu - near the top [as are some other 'select tools']... adding them would only duplicate stuff...
Global Moderator
Postby AlexMozg » Thu Jun 04, 2009 7:01 am
:?: Why constantly to use the method of group_miner, when in him practically is not there a necessity?
:?: Why to apply properties to entity, when are new properties of entity equal to the applied properties?
These questions are linked at a speed of implementation of script on the large scenes.
:!: Example of considerable increase of speed of implementation of script:
Code: Select all
class Sketchup::Group
    def definition
        self.entities.parent
def SelectionTool::group_miner(ents)
    ents.each do |e|
        if e.is_a? Sketchup::Group
            e.make_unique if e.definition.instances.length > 1
            SelectionTool::group_miner(e.entities)
:!: At the use of method of typename speed of implementation of script goes down in once or twice!
It would be desirable to correct these shortages...
AlexMozg
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Thu Jun 04, 2009 7:42 am
Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
I'd rather use the faster method too, I just never knew there was a faster one. I'm sure TIG isn't using a slow method on purpose either...
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby AlexMozg » Thu Jun 04, 2009 9:37 am
Chris Fullmer wrote:Alex, I have not run any tests on typename, but I use it regularly. Are you saying that it is much slower than .is_a?
Chris
Easily to check...
The more elements in the model - the better results script.
SpeedTest
is_a? - 0.36c
kind_of? - 0.39c
class - 0.422c
typename - 1.313c
Model Statistics:
edges = 48981
faces = 8009
groups = 729
components = 365
construction_lines = 1
construction_points = 4
images = 3
section_planes = 4
texts = 4
others = 2
AlexMozg
PluginStore Author
PluginStore Author
Postby thomthom » Thu Jun 04, 2009 9:45 am
That's some interesting numbers. I've always used kind_of? - wasn't aware of the is_a?. then again, I've never tested the speed of methods either.
Thanks for posting this test.
PluginStore Author
PluginStore Author
Re: [Plugin] #SelectionHideShow.rb v1.1
Postby TIG » Thu Jun 04, 2009 11:08 am
Thanks Alex - you've probably noticed I used the .is_a? test everywhere else in the script - however, I didn't realise it was so much slower to use typename=="". :oops:
I've also incorporated my own version of your group_miner speed-up suggestion that now avoids testing groups that area already unique... :geek:
I just need to edit ALL of my other scripts to change e.typename=="" to e.is_a?() !!! :cry:
Here's v1.1 viewtopic.php?p=161963#p161963
Global Moderator
Postby thomthom » Thu Jun 04, 2009 11:16 am
Maybe we could add this info to a new stickcy where we collect such useful tips and info?
PluginStore Author
PluginStore Author
Postby AlexMozg » Fri Jun 05, 2009 10:34 pm
TIG wrote:...I didn't realise it was so much slower to use typename=="". :oops:
For a model ot a few kilobytes to 10 megabyte of substantial difference it is not, but my models ot 40 to 75 megabyte!
_________________________
My model statistics:
Model 68.4 Mb:
Edges 485016
Faces 128906
Component Instances 6055
Groups 3078
Section Planes 4
P.S.
It was even necessary to write the analogue of SketchUp Text tool, because a standard tool begins to work very long.
:roll:
AlexMozg
PluginStore Author
PluginStore Author
Postby bianhai » Mon Jun 08, 2009 4:25 am
Very good :fro: !
bianhai
Banned
Postby thomthom » Sat Jun 20, 2009 2:20 pm
Chris
Easily to check...
SpeedTest
is_a? - 0.36c
kind_of? - 0.39c
class - 0.422c
typename - 1.313c
Model Statistics:
edges = 48981
faces = 8009
groups = 729
components = 365
images = 3
section_planes = 4
texts = 4
others = 2
Hmm... .kind_of? is an alias for .is_a? - Is that fraction of a differences just some other random outside co-incidence?
http://www.ruby-doc.org/core/classes/Ob ... ml#M000370
PluginStore Author
PluginStore Author
Postby thomthom » Mon Jun 22, 2009 12:11 pm
I did a somewhat larger test. By the looks of it .is_a?, .kind_of? and .class are pretty much the same. I take the differences due to other system factors at the time of execution.
AT - SpeedTest:
is_a? - 0.89c
kind_of? - 0.782c
class - 0.875c
typename - 2.297c
Model Statistics:
edges = 159630
faces = 61300
groups = 0
components = 1000
construction_lines = 0
construction_points = 0
images = 0
section_planes = 0
texts = 0
others = 0
PluginStore Author
PluginStore Author
Postby thomthom » Mon Jun 22, 2009 12:51 pm
Much larger test. (did have a few programs open while I did the tests.)
AT - SpeedTest:
is_a? - 16.297c
kind_of? - 16.141c
class - 18.703c
typename - 88.703c
Model Statistics:
edges = 8396595
faces = 1026520
groups = 52643
components = 526428
construction_lines = 2
images = 0
section_planes = 0
texts = 0
others = 0
PluginStore Author
PluginStore Author
Postby 3dsmax9 » Thu Jul 28, 2011 5:19 pm
a tool bar will be very great with this script
3dsmax9
Postby irwanwr » Sat Dec 24, 2011 11:36 am
i think i need this plugin
thank you in advance, sir.
irwanwr
Postby Ivancho » Fri Mar 15, 2013 12:06 pm
NICE!! :ecstatic:
Ivancho
Postby hygicell » Tue Sep 10, 2013 8:49 am
I have lost a component somewhere in my drawing
to find it, I pasted a second one in a visible place
when I select this, the entity info clearly says Component (2 in model)
with the components window context menu, I selected all components
I thought then, if I could hide the rest of the model, I would easily spot where the original one is
but view/hide rest of model doesn't work unless you are inside the component,
which means you can select only one of both, and the other one is deselected
please help
Frank
hygicell
Premium Member
Premium Member
Postby TIG » Wed Sep 11, 2013 11:44 am
View > Hidden Geometry ON will show all hidden objects.
If it's on a Layer that is OFF you won't see it though...
The Outliner will also show all instances that are on ON Layers...
You can select them in the Outliner and they select in the model.
Global Moderator
Return to Plugins
Users browsing this forum: camutanga1000, cprassis, mire88, spazziodesign, Zohir and 9 guests
