SketchUcation Plugin Store
[Plugin] Shape Bender Beta v0.55 UPDATED April 21, 2010
Postby Chris Fullmer » Wed Apr 08, 2009 7:31 pm
Version: 0.55 Beta
Description: This script will bend an existing group to match a curved line or series of connected lines.
Usage: See videos below :)
Requires: Progressbar.rb
SketchUp Compatibility: Its not compatible with version 5 or earlier.
**Download Shape Bender**
Here is a list of known bugs and planned improvements:
  • The first and last angles of the bend curve are actually not accurate. Its not very noticeable, but it is inaccurate.
  • Every once in a while the grids don't display.
  • Every once in a while I notice small deviations in the bending that are incorrect.
The video is a little bit outdated. I need to remake it with the new features.
Video #2
A new video Dec-03-2009
Thanks for checking it out!
Also, please check out my newest script Repeat Copy at smustard.com.
NEW! Shape bender en Francais, thanks to c.plaissais (Christophe). Download it HERE!
Chris
5856,1184
Last edited by Chris Fullmer on Sun Apr 12, 2009 6:56 am, edited 9 times in total.
All my Plugins I've written
SketchUp Team
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Level of SketchUp: Advanced
Re: [Plugin] Shape Bender Beta v0.1
Postby notareal » Wed Apr 08, 2009 7:36 pm
I'll certainly will keep eye on this.
notareal
Thea Render
Postby Chris Fullmer » Wed Apr 08, 2009 7:39 pm
I add the 2nd video showing how to do a double bend to the first post. I didn't really explain it very well, so hopefully it makes sense what I did. It seems logical to me, but I've been playing with the thing for a while now.
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Daniel S » Wed Apr 08, 2009 8:40 pm
Chris:
I attach my first .skp test using shape bender. :ecstatic: :ecstatic:
Thank you!!!
Daniel S
Daniel S
Postby David_H » Wed Apr 08, 2009 8:50 pm
:thumb:
If I make it look easy. . .rest assured--it probably is.
David_H
Top SketchUcator
Postby Ben Ritter » Wed Apr 08, 2009 9:08 pm
Chris, I can hardly keep up with your wonderful scripts. Most importantly though, you are very much appreciated for your kindness to the SU community.
Ben Ritter
Postby Ben Ritter » Wed Apr 08, 2009 9:13 pm
Just have to thank you again.
Unbelievable!
Ben Ritter
Postby jmmad » Wed Apr 08, 2009 9:15 pm
Thxs Chris
Really usefull plugin.
you are getting really good at programing.
Get Upa !
jmmad
Postby Pilou » Wed Apr 08, 2009 9:24 pm
Well well well :enlight: :thumb: :fro:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby xrok1 » Wed Apr 08, 2009 10:41 pm
excellent thankyou. :berserk:
i guess i will make the first suggestion. when i hit the up arrow i think maybe just the path should reverse but the object should stay with the same offset on the same side of the curve. the way it is now the path is reversed but also the object switches from one side of the curve to the other. it makes it confusing it i want to reverse the path the way it is now, i think i would have to first move the object to the opposite side of the straight line then run the script??
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby TIG » Wed Apr 08, 2009 10:43 pm
Very, very good - well done.
After you bend the group's contents couldn't you re-group all of the bits and give this new group the same name/description/material/layer etc as the original ? That way it'd look like you "just moved and bent the original group"...
It's also quite easy to run it on a component-instance - simply make a group of the instance [ groupp=model.active_entities-add_group(instance) ], later you'll explode it, you might also want to mine through the group's entities for any other groups or instances and explode them back to basics. Now you'll have a group of the geometry just as you do with your 'group-only' version... After bending etc you can re-group bits as outlined above - you could even make that group back into a new component instance (ins=group.to_component) and give it the same defname(made- unique >>#2)/name/description/materials/layer etc as the original instance, so then it looks like you simply bent the instance and made it unique. See my ComponentInstance-add_entities.rb for some ideas on how easy it is to do that...
You've done the difficult geometry/transformation stuff etc - it just needs a little tidying up so that it appears to do its stuff effortlessly in a twinkling of an eye, as if by magic...
Well done...
Global Moderator
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Postby xrok1 » Wed Apr 08, 2009 10:52 pm
1 more thing chris i was wondering if you couldn't group the line before exploding the group to be bent, then you could avoid the sticking while allowing the object to be placed directly in contact with the straight guide.
also i noticed that construction lines don't stick to geometry so maybe you could convert it to constuction lines as another option.
xrok1
Postby fredo6 » Wed Apr 08, 2009 11:12 pm
Chris,
I am really impressed by what you achieved. This is a master transformation :sketchstatic:
I played a little bit with it, and I think you got the essentials. The rest is just about adjustments in UI and options. And indeed to extend it to embedded components.
Well done!
Fredo
fredo6
Top SketchUcator
License type: Pro
SketchUp use: interior design
Postby utiler » Wed Apr 08, 2009 11:29 pm
Ditto from all said above, Chris!!!! This is fantasitc!!! :berserk:
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Phil Rader, AIA » Wed Apr 08, 2009 11:40 pm
Supercalafragelisticexpialadocious
That's one cool plugin...you are making a legacy for you children to follow.
Maybe you should change your last name to "SU"llmer...hehe.
Phil Rader, AIA
Premium Member
Premium Member
Name: Phil Rader, AIA
Postby Chris Fullmer » Thu Apr 09, 2009 1:24 am
Daniel S wrote:Chris:
Thank you!!!
Daniel S
My plugin did that? Was that in ultiple pieces??
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Daniel S » Thu Apr 09, 2009 2:18 am
Yes, your plugin do that... but not works everytime... it depends where you put the first line. It`s easy to have unexpected results.
Here i attach a working example. Just select the text, run your plugin, select firt line and then the helix. It takes some time but it works.
And i attach an example to make a double bend... In your video you make a lot of operations to get the result when you can apply directly on a 3d curve (you don´t get the exactly same result). In the model you will see that i have to move the 3d curve because you can´t use it if the endline is directly into the surface (here using Fredo´s Arc On Surface).
Daniel S
Daniel S
Postby wolfy » Thu Apr 09, 2009 3:37 am
Chris, this is a very impressive and useful new tool to your already impressive line of tools. Thanks for all the hard work, dedication and generosity...again! :enlight:
wolfy
Postby Dave R » Thu Apr 09, 2009 3:44 am
Chris, this is way cool!
One thing that may be a bug (and perhaps you know about it already) is some softening of edges at one end of the bent geometry. I did a few simple tests with a long rectangular box and a curved line for the result. The start end gets softened. Easily fixed by just tracing over the lines but maybe it shouldn't do it?
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
License type: Pro
SketchUp use: woodworking
Postby Jeff Hammond » Thu Apr 09, 2009 4:42 am
Dave R wrote:Chris, this is way cool!
yeah dave, i noticed that too.. one workaround for now is to make your straight line a little bit shorter than the object you're trying to bend (ie - if you're trying to bend a 24' long wall, make the straight line 23' with 6" in on both sides)
that's probably not the best workaround but in the little amount of time i've spent with the ruby so far, that's what i came up with to stop the edge from collapsing.
dotdotdot
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby linea » Thu Apr 09, 2009 7:10 am
Fantastic script Chris. Thanks.
linea
Postby MALAISE » Thu Apr 09, 2009 7:59 am
Let's make tests... Thanks a lot Chris :D
MALAISE
MALAISE
Postby silver_shadow » Thu Apr 09, 2009 8:32 am
they should give out awards for those rubie developers...
like the oscar rubie awards for each year !!! well done!! :ecstatic:
silver_shadow
Postby Dave R » Thu Apr 09, 2009 12:24 pm
Thanks Jeff. That'll work just fine.
Global Moderator
License type: Pro
Postby Marian » Thu Apr 09, 2009 2:04 pm
AWESOME :sketchstatic:
Thanks you Chris!!!
Marian
Postby derryatlanta » Thu Apr 09, 2009 2:17 pm
Thanks so much for all the effort and time invested into this amazing ruby, Chris.
This will save me so much time and actually raise up my level of modeling, so I am indebted.
I second the ruby Oscar awards idea!
Cheers,
Nigel
Stop your grinnin' and drop your linen
derryatlanta
Postby AcesHigh » Thu Apr 09, 2009 3:12 pm
Chris, Ive run into trouble at my first try to bend something. I have this vertical X shaped lattice of triangular beams. I am not able to bend it in no way :(
It was composed of a group with subgroups inside. I exploded everything inside, so its just meshes inside a group. Still, it doesnt work :(
AcesHigh
Postby David_H » Thu Apr 09, 2009 3:19 pm
I concur . .. however the term "Oscar" is copywrighted either by those people that make the movie awards or by the people that make the hot dogs and baloney (which are probably the same people)
so We need to come up with a different award name. . ..how about. .
oh I dunno. .. .
THE RUBY!!!
David_H
Top SketchUcator
Postby Jeff Hammond » Thu Apr 09, 2009 3:34 pm
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Thu Apr 09, 2009 3:38 pm
AcesHigh wrote:Chris, Ive run into trouble at my first try to bend something. I have this vertical X shaped lattice of triangular beams. I am not able to bend it in no way :(
Explode all of the sub-groups etc and finally the main group. Its contents remain highlighted - immediately regroup these - it should work now...
Global Moderator
License type: Pro
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Next
Return to Plugins
Users browsing this forum: Flippie123, hebh123, pujakhanna, tar85mg, versus and 14 guests
