[Plugin] SunTool - new Mar 2009
Postby facer » Sat Apr 04, 2009 1:20 pm
Check out free plugin that shows suns path, months, hours etc:
http://tx.technion.ac.il/~arrguedi/SunT ... Tdwnld.htm
Works on SketchUp7 and for SketchUp6 (In INSTALL process have to direct it to SketchUp 6/plugin - as noted in SunTool Help file)
Reason: Just cleaning up and organizing the Plugin forum. Correcting [Plugin] tag
facer
Premium Member
Premium Member
Re: (plugin) SunTool - new Mar 2009
Postby DonVid » Sat Apr 04, 2009 2:23 pm
Greetings:
The installation calls for a password?
DonVid
DonVid
Postby bianhai » Sat Apr 04, 2009 2:30 pm
Thanks! It's good suntools! :thumb:
DonVid,you registration after the password e-mail.
bianhai
Banned
Postby SunTools » Sun Apr 05, 2009 6:59 am
Hello ALL
Thanks for using SunTools, I'll be happy to receive your feedback and suggestions.
Enjoy,
Guedi
SunTools
Postby mattg » Sun Apr 05, 2009 7:15 am
Hey Guedi,
the tool that plots the path of the sun around an object doesn't seem to be working whilst all the other tools are.
Have you had any problems with this tool before?
Im using Sketchup 7
mattg
Postby sunlu4039 » Sun Apr 05, 2009 7:34 am
Thanks!
sunlu4039
Postby SunTools » Sun Apr 05, 2009 8:39 am
mattg (and others having problems with SunPath visualization)
(I hope) I fixed this bug....download an updated version of STbeta1.rbs and replace the existing file in Plugins/SunTools. Let me know if it worked!
http://tx.technion.ac.il/~arrguedi/SunT ... Tbeta1.rbs
Guedi
SunTools
Postby watkins » Sun Apr 05, 2009 9:01 am
Dear Guedi,
Shalom Aleichem, and thanks for making your sun tool available to the Forum.
Do you have any tutorial videos showing your plugin in action? Anything on YouTube?
Kind regards,
Bob
watkins
Postby SunTools » Sun Apr 05, 2009 9:16 am
Bob,
Sorry no videos yet. Maybe someone in the forum can prepare one? ;)
A --very short-- help file is available here:
http://tx.technion.ac.il/~arrguedi/SunT ... s_help.pdf
Guedi
SunTools
Postby MALAISE » Sun Apr 05, 2009 9:44 am
Hi Guedi
Interesting Plugin, but how to get a password ? I didn't see any link on the thread.
Regards
MALAISE
MALAISE
Postby SunTools » Sun Apr 05, 2009 9:47 am
MALAISE
Register at:
http://tx.technion.ac.il/~arrguedi/SunT ... nload.html
(make sure that you write your email correctly!!!)
You will receive an email with the password for installation.
Hope it helps,
Guedi
SunTools
Postby MALAISE » Sun Apr 05, 2009 9:56 am
Done, Thank you Guedi :D
MALAISE
MALAISE
Postby Edson » Sun Apr 05, 2009 10:39 am
another plugin that does not run on macs... :(
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby thomthom » Mon Apr 06, 2009 7:41 pm
Whenever that plugin is installed I hear a 'beep' from my speakers everytime SU loads. Are you using the Beep method in your code? If so, could you please remove it as it's rather annoying. Especially when I debug my own scripts and hear that beep every time.
PluginStore Author
PluginStore Author
Postby shirazbj » Tue Apr 07, 2009 1:42 am
"SunPath/Choose a day" is operated differently with other setting.
After click SunPath button, I only got one orange line along an axis.Nothing else happen after i click the OK button to close the pop-up setting window.
shirazbj
Postby SunTools » Tue Apr 07, 2009 7:16 am
shirazbj: see my previous post about this subject:
".....download an updated version of STbeta1.rbs and replace the existing file in Plugins/SunTools. ..."
This will fix your problem!
thomthom: sorry, yes it beeps when SunTools is loaded. I'll remove this beep in the next version.
Guedi
SunTools
Postby thomthom » Tue Apr 07, 2009 8:15 am
Thanks.
PluginStore Author
PluginStore Author
Postby rv1974 » Tue Apr 07, 2009 10:47 am
Sorry for dumb question but what exactly "target tool" does?
In my case the viewer position jumps under the ground (at the same time I get a lot of "Error: #<ArgumentError: Cannot convert argument to Sketchup::Point3d>" in the ruby panel). May be something is wrong?
rv1974
Postby SunTools » Tue Apr 07, 2009 11:53 am
rv1974:
Not a dumb question at all!
This tools allows the analysis of solar access in one point (inside or outside buildings).
It presents a view of how your point sees the sky (and the sun), in a way that you can asses in one unique view when that point is lighted (directly) by the sun during the whole year.
First, draw the path of the sun using the SunPath Tools.
Second choose Target Tool:
--Look at >> will define the point on the sky that you are looking at. It will be the center of the screen. To start just leave the default [December 12:00], you can rotate your view afterward to see different parts of the sky (see help file).
--Select the point for analysis >> just prepare in advance a point in the space that you would like to check. Inside a building it can be a seating position, if you want to check glare sources; outside buildings it can be an open space, or a solar system....
That's it. Let me know if it was clear enough.
Guedi
SunTools
Postby rv1974 » Tue Apr 07, 2009 12:03 pm
Ooops I accidentally skipped the help file on the download page . that's why.. May be you should integrate it into setup.exe?
rv1974
Postby SunTools » Tue Apr 07, 2009 1:01 pm
IT IS integrated in the setup.exe. Look at Plugins/SunTools.
Guedi
SunTools
Postby rv1974 » Tue Apr 07, 2009 1:40 pm
I meant may be it should pop up after installation (or I missed it :)Anyway many thanks!
Another thing. Guedi do you have plans to make the interactive sun (ie moving sun dummy would affect su shadows, thomething like in 3ds max ?)
rv1974
SunTools V2.0 available
Postby SunTools » Tue Sep 22, 2009 10:33 am
A new version of SunTools Plugin (V2.0) for SketchUp is available now.
The new version incorporates the calculation and visualization of Visible / Obstructed Sky from any point in a project (exterior/interior), and improvements of existing features as suggested by users.
Plug-in Features
- SunPATH: visualization (month and year)
- SunPOS: Sun Position for a date and time
- SunVIEW: Axonometric views from the Sun
- SunPENETRATION: Analyze Sun Penetration/Access in any specific analysis point.
New!
- SkyVIEW: Calculate Sky Solid Angle (SSA) and % of visible sky / Visualize Visible/Obstructed sky from any point in your project
V2.0 of the plug-in can be downloaded after registration from: http://tx.technion.ac.il/~arrguedi/SunT ... nload.html
A short documentation file can be viewed at: http://tx.technion.ac.il/~arrguedi/SunT ... helpV2.pdf
** A Mac version of the plug-in will be available next. :thumb:
Enjoy.
Guedi Capeluto
arrguedi@technion.ac.il
SunTools
Postby ken » Tue Sep 22, 2009 12:32 pm
Hello
Well I installed the new version of SunTool 2.0 and I get the following plugin starting each time I start Sketchup. Anyone else with this problem.
Ken
ken
Premium Member
Premium Member
Postby TIG » Tue Sep 22, 2009 12:55 pm
Me too. Disabled it till it's fixed... Tried to limit it loading via an enclosing ruby but that fails - it's a compiled rbs...
Global Moderator
Postby SunTools » Tue Sep 22, 2009 2:26 pm
Ken and TIG (maybe others with the same issue).
Thanks for the feedback,
It seems like a conflict of names, I'll fix it today, and put an updated version for download.
Guedi
SunTools
SunTools v.2.0 - update
Postby SunTools » Tue Sep 22, 2009 7:00 pm
an updated version of the installer can be downloaded now.
Hope this solve the problem. Please let me know.
Guedi
SunTools
Re: SunTools v.2.0 - update
Postby ken » Tue Sep 22, 2009 10:36 pm
SunTools wrote:Hi,
Guedi
New version did the trick, no more loading another script during start up.
Ken
ken
Premium Member
Premium Member
SunTools v.2.0 - MAC version available
Postby SunTools » Tue Sep 29, 2009 12:21 pm
Hello Mac Users,
Following the previous announcement, SunTools Plugin for SketchUp is available now also for MAC !!
It can be downloaded after registration from: http://tx.technion.ac.il/~arrguedi/SunT ... nload.html
Enjoy!!!
Guedi
SunTools
Re: [Plugin] SunTool - new Mar 2009
Postby vinh » Mon Sep 06, 2010 9:35 am
Does any one have this password? please seng to me:phieuluu1985@yhaoo.com.vn
vinh
Next
Return to Plugins
Users browsing this forum: liuweilw, Suphattra and 14 guests
