[Plugin] AddFaces
[Plugin] AddFaces
Postby TIG » Fri Mar 27, 2009 1:57 pm
This script simply adds faces to selected edges if it can.
Read the start of the rb file for guidance.
Select some edges and use the Plugins-Menu or Context-Menu item.
In the Ruby Console you can type TIG.addfaces [note this was changed in v2.0]
Download
Global Moderator
Re: [Plugin] AddFaces
Postby Dan » Fri Mar 27, 2009 2:02 pm
Thanks a lot, Tig!
Useful as always :thumb:
Dan
Postby pilou » Fri Mar 27, 2009 2:21 pm
Mysterious :)
Speedy Galerie
Top SketchUcator
Postby Jim » Fri Mar 27, 2009 2:29 pm
I like this idea of command line access to infrequently used scripts. All it needs is a little auto-completion and input area...
Jim
Global Moderator
Postby pilou » Fri Mar 27, 2009 2:40 pm
Ah ok I understand now :enlight:
Speedy Galerie
Top SketchUcator
Postby Chris Fullmer » Fri Mar 27, 2009 4:07 pm
Cool, thanks TIG!
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby Matt666 » Sat Mar 28, 2009 12:12 pm
+1, Jim! Like command line in Acad...
Frenglish at its best !
My scripts
Matt666
Postby gavvy » Mon Jul 13, 2009 10:49 am
:shock: TiG ! what is the difference form the makeFaces.rb ?? :?:
gavvy
PluginStore Author
PluginStore Author
Postby remus » Mon Jul 13, 2009 11:28 am
makefaces works on the whole model, this works on a seection.
remus
Postby EarthMover » Mon Jul 13, 2009 2:48 pm
I use Rick's make faces script on a selection all the time. It works well, although it can take a long time if there is a big selection. I wonder if TIG's script is perhaps a little faster?
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby iborov » Sat Mar 10, 2012 6:17 pm
I RESPECT YOU TIG!
!B
iborov
Postby brookefox » Wed Mar 14, 2012 9:42 pm
Thank you, TIG.
Since I often find myself having to draw and erase edges so as to get SU to face things it 'normally' does without 'instruction' (esp. within 'curves') I like the menu/context selection for this. I hope it will save me such time spent.
~ Brooke
brookefox
Postby Bob James » Fri Apr 18, 2014 10:19 pm
Simple curve: get error
Bob James
Premium Member
Premium Member
Postby TIG » Sat Apr 19, 2014 2:03 pm
@Bob
It appears under the Plugins-Menu or the Context-Menu.
Used from the Ruby Console v2 command is now:
TIG.addfaces
[the thread IS 5 years OLD for v1...]
Global Moderator
Postby Bob James » Sat Apr 19, 2014 5:19 pm
Being graphically oriented I just watched the video and didn't read the words under it.
Well, at least I present problems that are easy to solve :D
Thank you for taking the time, yet again, to help.
Bob James
Premium Member
Premium Member
Postby tillar » Fri Jun 06, 2014 4:59 pm
Any chance a progress bar can be added?
The "Simplify Contours" extension has a really basic one, down in the statusbar that gets the job done.
Simplify Contours (sketchup.com)
tillar
Postby TIG » Sat Jun 07, 2014 10:27 am
The PluginStore now contains v2.1 http://sketchucation.com/pluginstore?pln=addfaces
It now has a progress-indicator on the status-bar ...666/1234 etc...
Global Moderator
Postby a4jp.com » Fri Feb 14, 2020 4:51 am
Thank you so much. This plugin is wonderful. Will there be any updates for it later on?
a4jp.com
Return to Plugins
cron
Users browsing this forum: Andhikasaman, bsarms, frank0490, Google Bot, mmiklaszewska, trachthung and 6 guests
