[Plugin] angle between planes
Postby daiku » Fri Mar 06, 2009 3:37 pm
A simple little plugin that tells you the angle between two planes. Just right click on an edge that joins two faces. If there is exactly one edge selected, and that edge bounds exactly two faces, then a menu item will appear to calculate the angle between the two face planes. The intended use is for woodworkers dealing with compound joinery: this is the angle you set your saw bevel to. But there might be some general appeal as well, so I'm posting it. CB.
Update 3/7/09:
Got a great suggestion to simply display the angle right in the context menu, and skip the message box entirely. Also added the supplement of the angle when over 90 degrees.
daiku
PluginStore Author
PluginStore Author
Re: [plugin] angle between planes
Postby Ecuadorian » Fri Mar 06, 2009 3:50 pm
Arigatou Gozaimasu, Bremer-san.
Already tested it, and works good. Trying to measure such angles with the protractor is awkward.
Ecuadorian
Postby Dave R » Fri Mar 06, 2009 8:59 pm
Thank you for that Clark.
Global Moderator
Postby boofredlay » Sat Mar 07, 2009 5:18 pm
Handy, thanks.
boofredlay
Global Moderator
Postby linea » Sat Mar 07, 2009 5:47 pm
Very useful. Thanks
linea
Re: [Plugin] angle between planes
Postby mfseeker » Wed Dec 14, 2011 3:31 pm
Many thanks. I was trying to set up a compound saw cut. I had succeeded only after spending a great deal of time drawing various perpendicular lines and extra planes. Your plugin gave me an immediate answer (the same one, thankfully) in a moment.
mfseeker
Postby amarkanda » Thu Jan 17, 2013 8:29 pm
I've installed the plugin but I can't seem to find it in google sketchup
where would i find it?
amarkanda
Postby massimo » Thu Jan 17, 2013 9:13 pm
Have you read the first post Amy? See the picture below. :)
massimo
Return to Plugins
Users browsing this forum: daica85, hamdani12 and 6 guests
