[Plugin] SImple wood working Tools
• Page 1 of 1
[Plugin] SImple wood working ToolsI have written a few simple woodworking tools that I use in designing furniture. Most can easily be done using standard sketchup methods but since I use them so much, they save me time.
Create Board - creates a named component, with all three dimensions and oriented in space. Resize Board - One dialog box editing of all three dimensions. Drill Board - a repeating tool for drilling holes in components. Dado Board - a repeating tool for Dadoing boards. Set to front - Sets a component to the xz plane with one click. (Handy for creating cutting list scenes). Set Relative - moves a component relative to another in all three dimensions. (Handy for setting boards in space). I am working on a tool allowing one to resize a group of components, one direction at a time allowing one to resize say a drawer without resizing the widths, thicknesses etc. I am new to Ruby, but have written tons of things inside AutoCad. Joel Please, register (free) to access all the attachments on the forums.
Woodworking tools in SketchUpVery interesting set of tools.
A question on the dado tool. I select the componentin which I want the dado. The prompts at the bottom are to click the FROM edge and then the To edge. I would expect the dado would be plowed from the first edge to the second but instead, I get a dado running at 90° from the edges selected. I'm also not clear about the "Over" option in the dialog box. Any clarification would be appreciated. Thank you. Inspecting mirrors is a job I could easily see myself doing.
Re: SImple wood working ToolsVery cool, thanks! Would you mind editing your initial post title to start be "[Plugin]SImple wood working Tools" (add the [Plugin] tag). Just helps keep the forum easier to search
Chris
Re: [plugin]SImple wood working ToolsEdited the title, hope you dont mind.
Thanks for the plugins
Re: [plugin]SImple wood working Toolsit would be great if you'd show some pictures of your tools in action, so we could know (visually) what they do before we decide its worth the fight with our toolbars.
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
Re: [plugin]SImple wood working ToolsGreat script Joel
just a question with the drill board, how to you position the hole to be drilled. i tried to select a point but i keep getting invalid point Andrew
Re: [plugin]SImple wood working ToolsJoel,
Thanks for this. I posted this question in the Woodworking forum where you first posted these but I''ll ask it here, too. It concerns the Dado tool. "I select the component in which I want the dado. The prompts at the bottom are to click the FROM edge and then the To edge. I would expect the dado would be plowed from the first edge to the second but instead, I get a dado running at 90° from the edges selected. I'm also not clear about the "Over" option in the dialog box. Any clarification would be appreciated. Thank you." Inspecting mirrors is a job I could easily see myself doing.
Re: [plugin]SImple wood working ToolsI tried to post a small word document showing the dialog boxes
etc. I guess I don't understand how to do that. Drill tool needs a point already on the component face. Perhaps set by Tape Measure tool. The Dado tool "from/to" edges are not the ends. They define how you want to place the dado. The from edge and to edge define the plane and how your dimensions to the dado are placed. Hence a dimension of 1 inch is from the from edge in the direction of the to edge. What you are dimensioning to is one of three possibilities To (the nearest edge) Center (the center) or Over (to the furthest edge). That is kind of an old convention in carpentry. Thanks Joel
Re: Woodworking tools in SketchUpHey, I like those. You can even use the dado tool to make tenons quite quickly. Thanks.
Re: [plugin]SImple wood working ToolsI've tried to translate this simple component. A simple component to draw carcasses with. Maybe you could use it. And you can use it in a report ...
Well thank you for the great plugin. I know those who cannot write these plugins never seem to be satisfied. So could this plugin be made to work on groups as well as components? Again thanks Ken Government rushes to help the irresponsible and does little for the responsible.
Re: [plugin]SImple wood working ToolsJoel you did a very nice set of tools. I like them!
Any chance to have the same in the metric version for the european guys? ![]()
Re: [plugin]SImple wood working ToolsOne could in principal make them work on groups rather than components, although, the way I work a "board" (ie piece of wood) is a component. Hence, I work on components.
On Metric. It would be simple to make a metric version. Anyone could do it. One could load in the *.rb's and where ever you see .inch on a variable then change that to .mm. You could change a default .75inch to 19mm for examples. The .inch appears in two ways in these scripts 1) as an extension for declared variables (depth.inch change to depth.mm) or 2) as default values for the input box. Make them whatever you want. Thanks for the feed back. Joel
It would be simple to make a version that used the user's default units, too. Just use .to_l to convert the dialog values to Sketchup::Lengths.
Well, I can see what you mean now. Thanks.
Re: [plugin]SImple wood working ToolsOK, I'm a newbie but I cannot get your plugin to be recognized by Sketchup 7. I placed the file into the Plugins folder like I did with cutlist, re-started Sketchup, and yet nothing appears in the list I get when I click on Plugins.
Ralph, this plugin doesn't appear in the Plugins menu. It appears as several entries in the Draw menu. Inspecting mirrors is a job I could easily see myself doing.
Re: [plugin]SImple wood working ToolsYep, that's officially a "Duhh" I did find it, thanks. It would be nice if the description of a tool such as this told one where it would appear once installed.....
Re: [plugin]SImple wood working ToolsRalph, if you open the file in NotePad or another text editor, you can read where it will show up. It's typically in the last few lines of the script.
Re: [Plugin] SImple wood working Toolshi im use skechtup 8 and can't see where this plugin menu
Re: [Plugin] SImple wood working ToolsSee this link: viewtopic.php?f=323&t=17076&p=452505#p138227
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
• Page 1 of 1
