SketchUcation Premium Membership
[Plugin] FollowMe and keep (v0.04 update 20090210)
Postby wikii » Sat Feb 07, 2009 3:57 pm
FollowMe and keep the dirction of profiles.
Tip:construction point in selection will be treated as the align_point!
v0.04 20090210
1 if path started at a vertex of profile,the vertex will be treated as align point.
2 auto reverse face to get directviewing result.
v0.03 20090209
1 start at nearest vertex when path is closed
2 fix some bugs
v0.02 20090208
1 perfect ending;
2 autosmooth.
wikii
Re: [Plugin]FollowMe and keep
Postby sepo » Sat Feb 07, 2009 4:02 pm
Wow that was quick...I will give it a whirl... Thank you.
sepo
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Pilou » Sat Feb 07, 2009 4:07 pm
Terrible!!! :fro:
PS Is it only for pro version? Because I see nothing on the Plugins menus free V6, V7 :o
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby sepo » Sat Feb 07, 2009 4:16 pm
I dropped Fak.rbs into plugins folder but it does not show up.
sepo
SketchUp version: 8
License type: Pro
Postby remus » Sat Feb 07, 2009 4:16 pm
not sure if im doing something wrong but i cant see it in the plugins menu...
remus
Postby sepo » Sat Feb 07, 2009 4:21 pm
Tried on the other comp... same thing.
sepo
SketchUp version: 8
License type: Pro
Postby wikii » Sat Feb 07, 2009 4:22 pm
remus wrote:not sure if im doing something wrong but i cant see it in the plugins menu...
open fak.skp,
follow the text in the each page.
wikii
Postby Jean-Franco » Sat Feb 07, 2009 4:24 pm
could you help me ?
I don't see any FAK command in the plugins menu after extracting the FAK.rbs file in my Plugins directory.
Jean-Franco
Jean-Franco
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby sepo » Sat Feb 07, 2009 4:24 pm
It does not show in plugins.
sepo
SketchUp version: 8
License type: Pro
Postby remus » Sat Feb 07, 2009 4:32 pm
Wikii, if its any use this is what i get when i try and load it from the ruby console:
Code: Select all
load "FAK.rbs"
Error: #<SyntaxError: (eval):131:in `load': C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs:1: no .<digit> floating literal anymore; put 0 before dot
RBS1.0
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs:1: syntax error
RBS1.0
C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs:1: Invalid char `\030' in expression>
(eval):131
remus
Re: [Plugin]FollowMe and keep (Fixed)
Postby wikii » Sat Feb 07, 2009 4:37 pm
Sorry , I did't test it without Sutool.
I have posted the fixed version,please download it again.
:oops:
wikii
Postby Jean-Franco » Sat Feb 07, 2009 4:43 pm
Yes ! now it works !
thank you.
Jean-Franco
Jean-Franco
SketchUp version: 8
License type: Pro
Postby Pilou » Sat Feb 07, 2009 4:45 pm
Works! :bounce:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby remus » Sat Feb 07, 2009 4:45 pm
Works like a charm, thanks very much :thumb:
remus
Postby Jean-Franco » Sat Feb 07, 2009 4:48 pm
in scene3 we have this at the end for the smallest surface.
Jean-Franco
Jean-Franco
SketchUp version: 8
License type: Pro
Postby Pilou » Sat Feb 07, 2009 4:50 pm
Seems last at the end are false! ;)
Not a big deal than you can erase it but... perfection is needed :roll:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby wikii » Sat Feb 07, 2009 4:52 pm
Pilou wrote:Seems last at the end are false! ;)
You can add a hori line at the end of curve to avoid it.
wikii
Postby Pilou » Sat Feb 07, 2009 5:03 pm
Yes but it is some tedious ;)
Beauty is go to the end :enlight:
The curious thing is all seems good till the previous module :!:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby Jean-Franco » Sat Feb 07, 2009 5:21 pm
I do not understand exactly the difference between the two first scenes.
See below the top view when I selelect parallel projection.
Jean-Franco
Jean-Franco
SketchUp version: 8
License type: Pro
Postby wikii » Sat Feb 07, 2009 5:26 pm
Jean-Franco wrote:I do not understand exactly the difference between the two first scenes.
In the second scene,there is a construction point at start of the curve.
wikii
Postby Jean-Franco » Sat Feb 07, 2009 5:42 pm
Now I got it !
But was not easy to understand or to see your construction point because of the line style you used.
Thank you.
Jean-Franco
Jean-Franco
SketchUp version: 8
License type: Pro
Postby Ecuadorian » Sat Feb 07, 2009 6:12 pm
Wow, thank you wikii...
So many responses in so little time... This just shows how much we needed this.
Ecuadorian
SketchUp version: 8
Postby MALAISE » Sat Feb 07, 2009 6:18 pm
Thank you wikii sooo fast : incredible :thumb:
MALAISE
MALAISE
Postby Ecuadorian » Sat Feb 07, 2009 6:38 pm
Actually, it would be really cool to also have a script that orients the profile just like that final face... It could be called "FollowMe Slide", as it would not keep the profile vertical, but instead place it perpendicular to the curve, like in Playground slides, or toboggans.
Ecuadorian
SketchUp version: 8
Postby Pilou » Sat Feb 07, 2009 6:38 pm
So we must make that ;) (a vertical is more easy to draw in the space)
(bending effect on the right on the smooth view is just perspective !)
Works but curious method :mrgreen:
Another thing : measure of lengh of the "rectangle facet" must be less than the radius of the curve else auto intersections become! ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby dtrarch » Sun Feb 08, 2009 1:55 am
:berserk:Wiki Thank you Thank you :ecstatic:
WOW this is the real missing link in SU fixed at last.
This worked perfect right out of the box.
:berserk:
For Architects developing roadways on non level topography this is a must have tool and for the handrail up sweeping stairs this will be a life saver.
I have begged, offered bribes, and even bathed every day to hopefully have someone put this together with no luck until the Wizard of Code delivered.
An icon would be a helpful addition if not too troubling to add.
Just brilliant and generous.
Thanks more than I can properly express.
dtr Architect
PERFECT.png[/attachment]
dtrarch
Premium Member
Premium Member
Postby wikii » Sun Feb 08, 2009 2:56 am
0.02 provide perfect ending and autosmooth.
wikii
Postby Ecuadorian » Sun Feb 08, 2009 3:01 am
This should have been a tool in SU from the very beginning, thank you wikii!
Ecuadorian
SketchUp version: 8
Re: [Plugin]FollowMe and keep (update 20090208)
Postby Pilou » Sun Feb 08, 2009 3:14 am
0.02 is the version, I had believed that was a parameter :D
But sorry seems you have uploaded a false version! I have always the same result and not your result !
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby wikii » Sun Feb 08, 2009 3:30 am
Pilou wrote:0.02 is the version, I had believed that was a parameter :D
:oops:
I have uploaded a wrong package.
Sorry for that,please download v0.02 again.
wikii
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Next
Return to Plugins
Users browsing this forum: Adriano50, frapuano, hozakzahir, rudyarchi and 5 guests
