[Plugin] Cloud (update)
Postby Didier Bur » Fri Jan 16, 2009 9:07 pm
Below is an update of my script to import 3D "points cloud".
It now skips blank lines, wrong lines (not returning 3 valid coordinates) and invalid data (non-digit data).
Enjoy,
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: [PLUGIN] Cloud (update)
Postby Gaieus » Fri Jan 16, 2009 10:21 pm
Cool update, thanks! Spares a lot of manual editing of messy data files. :thumb:
Postby sepo » Sat Jan 17, 2009 1:50 pm
Thanks very much.
sepo
Postby MALAISE » Sat Jan 24, 2009 8:59 am
:thumb: :thumb:
MALAISE
MALAISE
Postby ilay7k » Sun Jan 25, 2009 11:40 am
Didier, thank you!
ilay7k
Re: [Plugin] Cloud (update)
Postby Matt » Tue Dec 15, 2009 3:03 pm
Dear Didier,
Just wanted to say thank you so much for your revised script - I had the same problem described - but your enhanced '09 version solves it and is much improved - the auto line drawing is particularly good. I'm using your script to allow me to work with complex geometry within Sketch-up which I've calculated within Excel.
Sterling work old chap!
Matt :thumb:
Matt
Postby SAnderka » Wed Feb 10, 2010 6:59 pm
Thanks for the update!
Also, this observation might help people with unexplainable "nothing happens"-errors:
http://forums.sketchucation.com/viewtopic.php?f=323&t=1537&p=223655#p223655
SAnderka
Postby cj4195 » Fri Feb 18, 2011 8:21 pm
Hi I am currently trying to open point cloud data using this plug-in, however, the data I am using is in .ptsb format which will not work, any ideas how I can convert it to .csv?
cj4195
Postby Didier Bur » Sun Feb 20, 2011 3:58 pm
No need to convert it to CSV.
Here is what Autode$k says about ptsb format:
Pointcount
X Y Z Intensity R G B
(Intensity is a float value 0-1)
Example:
0 0 0 .5 128 128 128
1 1 0 .5 128 128 128
Quite simple isn't it :D
So open your file in a text editor, erase first line (number of points), save it to 'somefilename.txt' and it should work. Just set the points cloud reader first dialog to use a space delimiter, and second dialog to set X,Y,and Z coordinates as the first, second and third datum of each line (see below).
I've tried this example and it works.
Regards,
Didier Bur
Didier Bur
Return to Plugins
Users browsing this forum: Synendra, xanhxam and 11 guests
