by Jim » Mon Nov 19, 2007 6:04 am
Ruby ToolbarAboutRuby Toolbar provides some controls over SketchUp's Ruby Panel (or Console.) It is most useful to people who are writing Ruby plugins. This is a Windows-only plugin. The 5 toolbar buttons are shown below.
They are: [ Show/Hide Ruby Console | Clear Console | Load a .rb | Reload last .rb | Browse Plugins Folder ] If someone wanted to contribute some good, meaningful icons I'd be grateful. The position and size of the console is saved to the Windows Registry when the console is hidden using the toolbar, and restored between sessions. Requirements- Sketchup
- Windows
- Win32API.so (if not already installed.)
InstallationDownload the .zip file, extact the files, and move them into your Plugins directory. Didier, this is actually an update of the RubyPanelToolbar you have archived on your site. Download and info here
Jim
- Global Moderator
- Name: Jim
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: other
by Didier Bur » Mon Nov 19, 2007 6:05 am
Cool very VERY VERY useful tool, Thanks a lot from all the developers ! hem hem  where's the gem ? (didn't find it at Sketchy Endeavors  )
Didier Bur
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by modelhead » Mon Nov 19, 2007 6:06 am
Yikes!! is that ever a cool thing to have around...thanks...very useful.
modelhead
by tomasz » Mon Nov 19, 2007 6:07 am
Jim, Am I blind already? Description of your tool is so interesting ... but where is the link Thanks a lot! Tomasz
tomasz
- SU2TH & SU2KT Developer
- Name: Tomasz
- License type: Pro
by Jim » Mon Nov 19, 2007 6:08 am
Oops, that was a major omission. I've added the attachment to the original post.
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by not registered yet » Mon Nov 19, 2007 6:10 am
When I extracted your .zip file, KI restarted SketchUp and I`can't find it!!! Will you please Bugfix it?
[Invader ZIM]
not registered yet
by Juju » Mon Nov 19, 2007 6:10 am
ZIM - some toolbars need to be activated under the "view" menu. Have a look to see if this is the case.
Save the Earth, it's the only planet with chocolate. Keeping things organised is not a sin.
Juju
- Name: Julian Smith
by Didier Bur » Mon Nov 19, 2007 6:11 am
Jim, I'm having the "blank icons syndrom" (all png's are in Plugins folder) The line that seems to cause the problem is: imgdir = File.join(File.dirname(__FILE__), File.basename(__FILE__, ".rb")) It returns: ./(eval) then the icon file location File.join(imgdir, "rubypanel.png") returns: ./(eval)/rubypanel.png Please help ! The 'toggle' method doesn't work also.  At least in V5. Question: Is findWindow.call(0,"Ruby Console") rely on language settings of SU ? I mean is "Ruby Console" available just for english versions of SU ? In this case the win32api call will not work with other platforms. P.S.: - Code: Select all
UI.openURL("c:\\program files\\google\\google sketchup 6\\plugins")
A non hard-coded command would be handy. Why not get this path from the registry ? Or something like: su_ver = Sketchup.version.split(".")[0].to_i if su_ver < 6 devdir = File.dirname(Sketchup.find_support_file("sketchup.exe")) + "\\Plugins" else devdir = ... end This makes the command compatible for SU5 and 6 (I guess), no matter where the user has installed SU. Regards,
Didier Bur
- License type: Pro
by Jim » Mon Nov 19, 2007 6:12 am
Didier Bur wrote:Jim, I'm having the "blank icons syndrom" (all png's are in Plugins folder) The line that seems to cause the problem is:
Please help !
Didier, I'm, not sure why it works on my computer but not yours. I have updated the script to use a method that will hopefully be more robust. There should be a rubytoolbar folder in which the images are located. Didier Bur wrote:The 'toggle' method doesn't work also.  At least in V5. Question: Is findWindow.call(0,"Ruby Console") rely on language settings of SU ? I mean is "Ruby Console" available just for english versions of SU ? In this case the win32api call will not work with other platforms. This could very well be the case. If you have Ruby installed, you could try your local verion of Win32API.so located in C:\ruby\lib\ruby\1.8\i386-mswin32\Win32API.so. What is the title text of your Ruby Console window? Is it English "Ruby Console", or maybe French? I think findWindow is using the name of the window. Didier Bur wrote:P.S.: - Code: Select all
A non hard-coded command would be handy. Why not get this path from the registry ? Or something like: su_ver = Sketchup.version.split(".")[0].to_i if su_ver < 6 devdir = File.dirname(Sketchup.find_support_file("sketchup.exe")) + "\\Plugins" else devdir = ... end This makes the command compatible for SU5 and 6 (I guess), no matter where the user has installed SU. I use the find_support_file method; good idea. Thank you for the report, and your patience. Please download and try the updates.
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by Didier Bur » Mon Nov 19, 2007 6:13 am
Hi Jim, Thanks for the update: icons are there now Show/Hide console doesn't work  (not very important) Clear console only moves the text in the console 1 line up 8O The title of the Ruby console window in french is "Console Ruby". This could cause the problem... But the most important command "Reload script" works OK since the first version Thanks again for this very useful tool, Regards,
Didier Bur
- License type: Pro
by Gaieus » Mon Nov 19, 2007 6:13 am
Didier Bur wrote:...The title of the Ruby console window in french is "Console Ruby". This could cause the problem...
Thank God I don't need to deal with a "native" version of SU!
- Administrator
- Name: Csaba Pozsárkó
- License type: Pro
- SketchUp use: historical reconstruction
by Didier Bur » Mon Nov 19, 2007 6:14 am
Everything's OK with the french version now, including toggle Only minor tweaks were necessary
Didier Bur
- License type: Pro
by Jim » Mon Nov 19, 2007 6:15 am
Didier Bur wrote:Everything's OK with the french version now, including toggle Only minor tweaks were necessary  Great! But would you mind sharing the minor tweaks so maybe I can make the toolbar more international?
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by Didier Bur » Mon Nov 19, 2007 6:15 am
Hi Jim, would you mind sharing the minor tweaks
I'm afraid it would be useless because I simply replaced all the calls to "Ruby Console" by "Console Ruby", but that's only for french. Each version of SU does have a particular name for the Ruby Console, so... Even a call to langhandler.rb (with 'getstring') will not work since this deals with a window name, not a message string or such. Regards,
Didier Bur
- License type: Pro
by Jim » Mon Nov 19, 2007 6:16 am
Didier Bur wrote:Hi Jim, would you mind sharing the minor tweaks
I'm afraid it would be useless because I simply replaced all the calls to "Ruby Console" by "Console Ruby", but that's only for french. Each version of SU does have a particular name for the Ruby Console, so... Even a call to langhandler.rb (with 'getstring') will not work since this deals with a window name, not a message string or such. Regards, Didier, GetString would work, but since it's only one string, I won't use LangHandler. I've updated the plugin to support FR.
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by CPhillips » Mon Nov 19, 2007 6:17 am
Hi Jim,
I love this toolbar. I use it constantly.
Feature request: How about saving the state and position of the console in the registry? So if I close and reopen Sketchup it remembers if the console was open and where it was.
Also If you want I could give you the code to read the console log window. Saving is the only use I can think of. But maybe it could be parsed to some effect.
Chris
CPhillips
by Jim » Mon Nov 19, 2007 6:18 am
Thanks Chris,
The version I posted on SketchyUtils isn't up-to-date, I'll remove it. Download the version available in this thread.
The position and size are saved in the registry, but only if the console is closed using the toolbar. Is it possible to save these settings if the console is closed using the X widget?
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by CPhillips » Mon Nov 19, 2007 6:18 am
Ah, much better. Yeah I was still using the old one.
I didn't even know this subsection of the forums was here until yesterday.
As far as detecting the window close message. It wouldn't be easy. One thing you could do is just check the position of the window ever 10 sec or so and see if it has moved/closed.
Regards Chris
CPhillips
by Pilou » Sat Jul 04, 2009 3:31 pm
Why put the "ruby console" and not the "Web Console" of Jim Foltz? Seems it is more easy using? (but I am totally new beginner in Ruby script PS With the Webconsole seems you can't save (bug ?)
Pilou
- Top SketchUcator
- SketchUp version: 6
- License type: Free
- SketchUp use: hobby
by •BTM » Sat Jul 04, 2009 3:57 pm
Pilou wrote:Why put the "ruby console" and not the "Web Console" of Jim Foltz? Seems it is more easy using? (but I am totally new beginner in Ruby script PS With the Webconsole seems you can't save (bug ?)
You can save, it just doesn't say that you have the same file open after that. it's weird.
•BTM
by Jim » Sat Jul 04, 2009 5:37 pm
Maybe I should combine the 2 plugins into 1?
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by tomasz » Sat Jul 04, 2009 7:58 pm
Jim wrote:Maybe I should combine the 2 plugins into 1?
Jim, I use your plugin always when I deal with SU Ruby. Ability to run snippets would be the good addition. I have also noticed that your plugin doesn't work in Polish version of SU. In PL the console is called "Konsola Ruby". Is there a way to recognise the language of SU instead of the OS? I have SU6PL installed in Vista EN.  Thanks Tomasz
tomasz
- Name: Tomasz
- License type: Pro
by tomasz » Sun Jul 05, 2009 12:15 pm
I have checked and - Code: Select all
Sketchup.get_locale
returns 'pl' string which is correct language for SU Version (SU6 PL). Tomasz EDIT Substituted os_language with get_locale
tomasz
- Name: Tomasz
- License type: Pro
by Pilou » Sun Jul 05, 2009 1:21 pm
@btm Thx Indeed that's save and load but not in .rb in the Snippets apparently  That was my error
Pilou
- Top SketchUcator
by thomthom » Wed Aug 18, 2010 8:26 am
I'm getting this error for the Clear Console button: Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:94:in `call' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:94:in `moveConsole' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:66:in `clearConsole' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:167 C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/rubytoolbar.rb:167:in `call'
- Global Moderator
- Name: thomthom
- License type: Pro
by Jim » Wed Aug 18, 2010 12:46 pm
What is the name of your Ruby Console in the title bar?
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by thomthom » Wed Aug 18, 2010 12:51 pm
"Ruby Console"
- Global Moderator
- Name: thomthom
- License type: Pro
by Jim » Wed Aug 18, 2010 1:13 pm
I don't understand the error, then. Does WIn32API work on 64 bit machines? Can you try this version?
Jim
- Global Moderator
- Name: Jim
- License type: Pro
by thomthom » Wed Aug 18, 2010 1:32 pm
Jim wrote:Does WIn32API work on 64 bit machines?
Yes. I have a working version of a snippet that clears the console. I can compare it against the one in your plugin. Jim wrote:Can you try this version?
I'll try.
- Global Moderator
- Name: thomthom
- License type: Pro
by everywinter » Wed Aug 18, 2010 4:02 pm
Hi! Im a new user to ruby and i have just downloaded the file from your post but i cant seem to activate anything. I have the 'ruby console' under sketchup 'windows' but nothing's in there... Can you teach me what should i do? How should i start?
everywinter
- Name: Geraldine
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
- Robot
Return to Plugins
