[Plugin] ExtrudelineTool Update
• Page 1 of 2 • 1, 2
[Plugin] ExtrudelineTool UpdateHi,
Here is an update of my extrudelinetool: - now supports numeric entries in the VCB - annoying beep supressed - some graphic enhancements. Enjoy, Please, register (free) to access all the attachments on the forums. Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F) http://rld.crai.archi.fr/rubylibrarydepot/
Re: ExtrudelineTool UpdateFantastic, thanks a lot.
May be, to make it perfect, you could add: 1.non-orthogonal tracking, aka SU magenta line 2.forced direction (SHIFT catch) 3."from point" snapping- before final 2 clicks one could move cursor along desired direction->digital input via vcb->and finally last 2 clicks. But once again, I'm already happy with current version.
Re: ExtrudelineTool UpdateHi Didier.
I'm not trying to hijack this thread, but I have been unable to access your site for the last couple of days. I am using safari and I keep getting a warning that the server is not responding. Any idea what is up? Anyone else having this problem? Cheers, Chuck
MY BLOG Become a fan of OTB Designworks on Facebook, we'd love to have you! 3.2ghz 8 core Mac Pro. 10 gig RAM, 8800 GT GPU, dual monitors
Re: ExtrudelineTool UpdateFYI, I am using IE6 and I cannot access the site either.
Re: ExtrudelineTool Updateweird, but thanks for the confirmation that it's not my red-headed stepchild Mac causing the issue.
Cheers, Chuck
Re: ExtrudelineTool UpdateHey, watch who you call a red-headed stepchild
Re: ExtrudelineTool UpdateCheers, Chuck
Re: ExtrudelineTool UpdateIn one of his posts here Didier said his site was down for maintenance (or what) and should be online about today or so...
Re: ExtrudelineTool UpdateDidier,
thank you for this great script! I'm wondering ... Can you make it work like the follow-me tool so that you can pick the path before selecting the lines to extrude and they would follow that path? like this image: It would be great for creating low-poly roof flashing around a complex roof, or for low-poly sunshades with all those blades, so you don't have to make them with thickness, etc. here's a conversation for this a few months back
Re: [Plugin] ExtrudelineTool Updatejust a thought: It would be great to implement the ExtrudelineTool completely into SketchUp by making the push/pull tool work on selected lines. so the push/pull tool works as normal, but if some lines are selected beforehand, it works on these lines like your ExtrudelineTool.
(however, I asume that ruby doesn't give you acces to the native SketchUp tools, right? therefore this idea should be in the wish list section
Re: [Plugin] ExtrudelineTool UpdateThanks for Updates, Sir!
But I have an idea, hope your scripts have one more option. The follow me tool twisted the face along the 3d path, so can you fix it by make the line always parabel to a selected face? or more simple, the line always parabel to OXY or OXZ or OYZ of WorldXYZ. Thanks again and sorry about my terible English.
Re: [Plugin] ExtrudelineTool Updateis this most excellent tool still being developed?
i'd like to see the path follow option implemented as well ![]() “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
Re: [Plugin] ExtrudelineTool UpdateAny chance of having it select the new set of edges? Not the ones making up the extrusion, but the ones parallel to the original ones?
Re: [Plugin] ExtrudelineTool UpdateHi,
What do you mean ? Sorry but I don't understand... Didier Bur (Bytes Farmer)
Re: [Plugin] ExtrudelineTool UpdatePlease, register (free) to access all the attachments on the forums. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] ExtrudelineTool UpdateFunny I have asked the same 8 days ago
DIDIER DIDIER DIDIER sur l'air des lampions
Done. Just a matter of packaging now... Didier Bur (Bytes Farmer)
Re: [Plugin] ExtrudelineTool UpdateThomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] ExtrudelineTool UpdateThat is a tricky tool very useful
Bravo! ![]() Waiting the new update! And this will be a new hit! ![]() Curious that don't yet exist
Re: [Plugin] ExtrudelineTool UpdateHello Didier,
thanks for you share the " extrudelinetool " New update . its really nice ThankS RuturaJ Thanks,
RuturaJ
The Didier "Pakaging" for the new update of the extrude line is ready?
Well, I must be dense today, where is the newly package script? Again thanks Didier for all your scripts. Ken Government rushes to help the irresponsible and does little for the responsible.
I believe that Didier has forgotten to post it!
Re: [Plugin] ExtrudelineTool UpdateWhat has happened to Didier? He ok?
Re: [Plugin] ExtrudelineTool Updatehope so..it's been a while..
Re: [Plugin] ExtrudelineTool UpdateThanks a lot, it is just what I looking for. This tool can be updated? Sad it have no own button and can't select edges which will be extruded. Anyway this tool makes me happy=)
Sorry for my lame English =)
Re: [Plugin] ExtrudelineTool UpdateAn Extrude [Rails,Edges,Lathe etc] toolbar is in progress...
Does the Extrude Edges select the new set of edges ready to be extruded again? Thomas Thomassen — SketchUp Monkey & Coding addict
SketchUcation One-Liner AdvertsVertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
