SketchUcation Plugin Store
[Plugin] Projection toolbar update
Postby Didier Bur » Sun Nov 18, 2007 11:10 pm
Hi all,
Here is an update (major revision) of my projection toolbar.
What's new:
· More user-friendly commands: click points instead of selecting objects for plane definitions and vectors
· Better selection errors checkings
· Project faces along Z and along vector gathered in one command.
· ExtrudelineTool included
· lines2cyl and credits commands suppressed
· Construction line at intersection of faces enhanced: multiple selection supported
· New icons
· PDF doc included
Enjoy,
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: Projection toolbar update
Postby CadFather » Mon Nov 19, 2007 9:44 pm
Thank you Didier - your toolbar has been a great friend in the past - i'm looking forward to see the changes. :D
EDIT: had a look at the new script (though i still have to read the doc)
one question - how feasible to add 'project lines' along red/green?
i am thinking of using it to extrude lines and have them intersect faces - very useful/quick when working with cad files
Quarr-IT - SketchUp Training from the Master.. . ;) .
CadFather
Postby Didier Bur » Wed Nov 21, 2007 8:59 am
Hi cadFather,
I'm afraid I don't understand 'project lines along red/green' ?
Using "project lines along vector" would not do the trick ?
Please explain it to my tired brain...
Didier Bur
SketchUp version: 8
License type: Pro
Postby CadFather » Wed Nov 21, 2007 9:40 am
for some reason i can't upload an image - the tool i have in mind is the project along z
- i was thinking of a keyboard shortcut which quickly projects lines along one of the other axis. to be sure the vector one works so don't worry about it...take a good rest
(if you can).. :shock:
CadFather
Postby urs0815 » Sun Dec 09, 2007 9:57 am
hallo Didier,
I installed the "projection toolbar", it works fine, BUT now the right mouse button doesn´t work how it should: when I activate an object and klick the right mouse button (to call the context-menu), the object is not active any longer.
I use SU6free on MacOSX - I´ve tried it with a 3 button mouse and a Wacom tablett -> same problem
urs0815
Postby Edson » Sun Dec 09, 2007 2:41 pm
didier,
what can i say? u da man!!! one more fantastic script that will boost everyone's productivity.
i tried all the tools and they worked perfectly on my mac running OS 10.4.11.
regards and thank you once more.
p.s.: would it be at all possible to control the distance between the two points needed to extrude lines along a vector via VCB?
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
Edson
Global Moderator
Operating system: Mac
SketchUp version: 2013
License type: Pro
Postby Didier Bur » Sun Dec 09, 2007 6:57 pm
Hi Edson,
You can make it work this way, or did I forget something ? :shock: :shock:
Click a first point somewhere, drag the mouse in the direction you want the vector to be, then enter a number in the VCB. :)
PS: multiwalltool tuto not forgotten ;)
Regards,
Didier Bur
SketchUp version: 8
License type: Pro
Postby Edson » Sun Dec 09, 2007 8:06 pm
Didier Bur wrote:You can make it work this way, or did I forget something ? :shock: :shock:
yes, it does work. i have probably done something wrong when i tried before.
PS: multiwalltool tut not forgotten
thanks! i thought of that the other day but did not want to ask again since you have been giving us so much.
regards.
Edson
Global Moderator
License type: Pro
Re: [Plugin] Projection toolbar update
Postby Free Agent » Mon Oct 20, 2008 12:59 pm
this has become one of my many favourite scripts, but i cant assign keyboard shortcuts to the individual commands, any way of fixing this?
Free Agent
Postby xrok1 » Sat Mar 07, 2009 10:02 pm
i've been wanting this for a long time now. thanks to the new ruby search index and thankyou very much dedier. :ecstatic:
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby xrok1 » Sun Mar 15, 2009 8:07 pm
Hmmm, check this out. if i select more than one line to project perp. to plane, only 1 projects???
try the file, select all the edges then the face obove it and try project perp. to plane.
xrok1
Postby bluestone » Thu Jan 21, 2010 4:51 am
it's really good one for AV designer
bluestone
Postby ckosio » Thu Jan 21, 2010 8:32 am
thanks a lot....for sure I will it alot!
ckosio
Postby DVERGER » Thu Jan 21, 2010 2:48 pm
Bonjour/Hello
J'ai certains icones en double, en français et en anglais (en vert sur l'image).
I have duplicate icons, in french and in english (in green on picture).
DVERGER
Postby Pilou » Thu Jan 21, 2010 2:52 pm
Il y a 2 versions successives mélangées en même temps! ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby DVERGER » Thu Jan 21, 2010 3:08 pm
Pilou wrote:Il y a 2 versions successives mélangées en même temps! ;)
J'ai "fr_projection_extension" et "projection_extension". Donc je vire "projection_extension". C'est bien ça?
EDIT : C'est fait mais j'ai perdu les 4 derniers icones de la barre qui n'étaient pas en double.
DVERGER
Postby xrok1 » Thu Apr 15, 2010 7:54 pm
great set of tools, thankyou.
is there any chance to add a project along normal to the extrude lines tool? :mrgreen:
xrok1
Postby LannorMov » Fri Oct 22, 2010 8:29 am
Didier Bur wrote:Hi all,
What's new:
· New icons
· PDF doc included
Enjoy,
Gracias Didier, solo gracias
LannorMov
Postby sketcpeppe75 » Tue Nov 23, 2010 3:46 pm
recent release is projection v6 or v2? tanks to job
sketcpeppe75
SketchUp version: 8
Postby Didier Bur » Tue Nov 23, 2010 6:31 pm
Didier Bur
SketchUp version: 8
License type: Pro
Postby sketcpeppe75 » Tue Nov 23, 2010 7:58 pm
beau travail didier....merci beaucoup :)
sketcpeppe75
SketchUp version: 8
Postby Jim Smith » Tue Nov 23, 2010 8:51 pm
thanks for the update Didier :thumb: r
"Out of clutter find simplicity,
from discord find harmony,
In the middle of difficulty lies opportunity"
Albert Einstein
Jim Smith
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby ahnvtk » Tue Mar 08, 2011 10:48 pm
I posted, then thought I found the answer, then deleted, then thought I don't have the answer.. :?
Which version is newer: V6 at the first post here, or V2 found at the plugins index of the site linked from the last post here? -
http://rhin.crai.archi.fr/rld/plugin_details.php?id=671
ahnvtk
Postby Didier Bur » Wed Mar 09, 2011 6:35 pm
@ahnvtk: the latest version is to be found at the link on RLD http://rhin.crai.archi.fr/rld/plugin_details.php?id=671
Didier Bur
SketchUp version: 8
License type: Pro
Postby ahnvtk » Thu Mar 10, 2011 6:41 pm
thx
ahnvtk
Postby melkhout » Thu Aug 11, 2011 1:33 pm
This is a great plugin!
Anyway it would come extremely handy, if it were able to project multiple points at once onto a given surface.
Though I have no idea how complicated it would be to modify the script accordingly, to me this would be of great value!
Best regards!
melkhout
Postby ckflyer » Tue Feb 28, 2012 11:14 am
the plug looks so great, I would like to try and learn it
ckflyer
Postby Gaieus » Tue Feb 28, 2012 11:15 am
Go ahead,LYC and download > install it then!
Administrator
License type: Pro
SketchUp use: historical reconstruction
Postby JQL » Fri Jun 07, 2013 1:49 pm
Why is this plugin not in Sketchucation Plugin Store?
It's a really useful one!
Best regards,
JQL
JQL
SketchUp version: 8
License type: Pro
Postby Didier Bur » Sat Jun 08, 2013 6:13 pm
Didier Bur
SketchUp version: 8
License type: Pro
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Return to Plugins
Users browsing this forum: Bing [Bot], Itaia, JuanV.Soler, Litchi, llang57, sidoniop, vefo, walidos07 and 10 guests
