[Plugin] Soften/Unsoften
Postby CadFather » Thu Oct 23, 2008 10:15 am
is it possible to define an action (by icon or shortcut key) which unsoftens a selection in one go without having to go to smooth/soften and move the slider all the way down?
and is the reverse (one click soften)?
SOLVED - PLUGIN CREATED BY MATT
PLEASE USE THIS LINK FOR THE MOST RECENT VERSION
[file contains script and folder with icons - drop both into the plugins directory]
CadFather
PluginStore Author
PluginStore Author
Re: [Idea]
Postby Pixero » Thu Oct 23, 2008 11:53 am
If I remember correct this free plugin has it: http://www.cadspan.com/tools
Pixero
Re: [Idea]
Postby Matt666 » Thu Oct 23, 2008 12:06 pm
A script was created to do what you want, here !
Frenglish at its best !
My scripts
Matt666
Re: [Idea]
Postby CadFather » Thu Oct 23, 2008 12:22 pm
THANKS GUYS!!! :berserk:
Pixero for a new interesting plugin
Matt for a genius 'back to the future plugin' - works just great even for groups and all!
(and it's much easier for quick smooth/unsmooth)
will see if i can create a toolbar to the commands..
CadFather
PluginStore Author
PluginStore Author
Re: [Plugin] Soften/Unsoften
Postby CadFather » Thu Oct 23, 2008 2:25 pm
small update for whoever likes this idea:
tweaked Matt's plugin so i get 2 icons (if you ever needed) enable in view > toolbars > soften
(i removed menus in plugins)
now it is a quick step!
Thanks Matt! :thumb:
CadFather
PluginStore Author
PluginStore Author
Postby Matt666 » Thu Oct 23, 2008 3:09 pm
This plugin will help someone, finally... :D
As always, great icons CadFather !
My scripts
Matt666
Postby CadFather » Thu Oct 23, 2008 3:50 pm
Thanks Matt - and i even learned how to create toolbar items (by copying Jim's scripts).. :D
CadFather
PluginStore Author
PluginStore Author
Postby ___olo » Fri Oct 24, 2008 6:36 am
CadFather, can you post this Ruby again. Because, I did down it , but it may has a mistake.
Xin chào nhau giữa con đường
Mùa xuân phía trước, miên trường phía sau
___olo
Postby CadFather » Fri Oct 24, 2008 8:14 am
done - look up for new download
CadFather
PluginStore Author
PluginStore Author
Postby Matt666 » Fri Oct 24, 2008 1:00 pm
Hi CadFather !
I updated the code, with another tool. It softens edges whose angle normal faces is below 20 degrees.
So now you've got three tools :
    Mildly Soft edges
    Completely Soft edges
    Unsoft edges
You forgot a bit of code at the end...
Code: Select all
if (not file_loaded?("Soften.rb"))
Now the tool will be loaded just one time !
and the code is also changed following the RickW notices (I hope ;) )
Good luck for the next icon :D
EDIT : Version 1.1
My scripts
Matt666
Postby CadFather » Fri Oct 24, 2008 1:43 pm
:shock: :o :? :evil: :roll: :fro:
CadFather
PluginStore Author
PluginStore Author
Postby chango70 » Fri Oct 24, 2008 2:36 pm
Wow this answered my prayers!
chango70
Postby watkins » Fri Oct 24, 2008 3:57 pm
Dear Matthieu,
I have downloaded and installed the plugin. When I open SU I find a toolbar but no Icons. Is this an oversight?
Kind regards,
Bob
watkins
Postby CadFather » Fri Oct 24, 2008 3:59 pm
Hi Matt, i have a problem with the new version: nothing happens :?
still works with the old one
i have updated the script with the 3 icons (changed the name for the new command icon)
CadFather
PluginStore Author
PluginStore Author
Postby CadFather » Fri Oct 24, 2008 4:01 pm
Bob, you need both the plug in and the folder called smooze (with the icons)
CadFather
PluginStore Author
PluginStore Author
Postby watkins » Fri Oct 24, 2008 4:16 pm
Dear CadFather,
Many thanks for that. As an aside, are you Italian? I ask because I spent a very happy year at the University of Trento.
Kind regards,
Bob
watkins
Postby watkins » Fri Oct 24, 2008 4:29 pm
Dear Matthieu and Cadfather,
I am a little confused about what to download. I have the icons showing, but nothing works. The last thing I downloaded and tried is the very last .zip file posted by Cadfather.
Regards,
Bob
watkins
Postby CadFather » Fri Oct 24, 2008 4:45 pm
will post a working final version from Matt very soon - need to finish a couple of things first.
Bob, yes one of those... ;)
CadFather
PluginStore Author
PluginStore Author
Postby watkins » Fri Oct 24, 2008 5:48 pm
Thanks!
watkins
Postby publied » Fri Apr 13, 2012 4:06 pm
oh my hero, my savior! this plugin is very useful for me! thanks!
publied
Postby tedvitale » Tue Mar 05, 2013 6:11 pm
Does anybody know of a plugin that allows me to soften multiple grouped objects? I have a lot of 3DS models that i import that need to be smoothed and cleaned up, but I have to open each group and soften them individually, which is quite painstaking. Any Suggestions?
Ted Vitale
3D Artist and designer
Sketchup 2013 Pro
tedvitale
Postby massimo » Tue Mar 05, 2013 8:43 pm
massimo
Postby shri » Thu Feb 26, 2015 9:28 am
very handy tool..thanks alot
shri
Postby rv1974 » Mon Jan 29, 2018 11:26 am
I can't find a way to assign shortcuts for these tools. Does the needs to be updated, or it's me missing something?
rv1974
Postby TIG » Mon Jan 29, 2018 2:16 pm
Remember that this script is ~10 years old !
Because it only makes a toolbar there are no menu items to shortcut onto !
However, the native smooth/soften toolset is easily accessed via a shortcut, as that has context and menu items...
Why do you need this tool in preference to the built-in native one - the old code uses the very slow 'typename' entity checker, the native one also has more controls over what is changed... ?
Global Moderator
Return to Plugins
Users browsing this forum: giliwko262730, k1w, kaosho, nahchetay and 8 guests
