[Plugin] ConsDeleteContext
Postby TIG » Sun Oct 19, 2008 9:29 pm
Author : TIG
Usage : Deletes or Layers Guide-Lines or Guide-Points or Both:
accessed through the Context-menu/submenu:
it either deletes/layers 'All Active' or 'All in Selection/ALL' -
mining down into any selected groups/components...
If you pick a 'Selection' option BUT without anything selected then
ALL 'model entities' are processed! [Note: a context-menu will still
appear with NO selection, if the cursor is over an axis etc...]
It's one step un-doable [or two steps if Both Lines/Points option]...
Download
Global Moderator
Re: [Plugin] ConsDeleteContext.rb
Postby CadFather » Mon Oct 20, 2008 4:59 pm
..just to say thanks TIG! :)
CadFather
PluginStore Author
PluginStore Author
Postby JClements » Mon Oct 20, 2008 6:10 pm
My thanks as well.
JClements
Premium Member
Premium Member
Re: [Plugin] ConsDeleteContext.rb v2.0 20110710
Postby TIG » Sun Jul 10, 2011 1:44 pm
Global Moderator
Postby designerbursa » Wed May 22, 2019 8:32 pm
Moving points to layer did not work. The plugin's code needs to be edited as follows! ..
old code
def self.layerAllGpoints()
model = Sketchup.active_model
entities = model.active_entities
model.start_operation("layer active Gpoints")
model.layers.add("CPOINTS")
entities.to_a.each{|entity|e.layer="CPOINTS" if e.valid? and e.class==Sketchup::ConstructionPoint}
model.commit_operation
new code
entities.to_a.each{|e|e.layer="CPOINTS" if e.valid? and e.class==Sketchup::ConstructionPoint}
designerbursa
Postby TIG » Thu May 23, 2019 4:38 pm
Thanks, this code is almost 8 years old !
No one has spotted that typo before - well done...
A more 'modern' fix for the wayward line might be:
Code: Select all
entities.grep(Sketchup::ConstructionPoint).each{|e|e.layer=model.layers.add("CPOINTS")}
Avoiding the need to first make the layer at all !
Global Moderator
Postby designerbursa » Fri May 24, 2019 11:34 am
I was very happy if I could help. I'm waiting for you to update the plugin :) thanks TIG :thumb:
designerbursa
Postby TIG » Fri May 24, 2019 1:58 pm
I've corrected the RB file previously found in the first post - viewtopic.php?p=100581#p100581
I've republished its RBZ in the PluginStore as v2.1
Download
Global Moderator
Return to Plugins
Users browsing this forum: and61, beiyangduan, bskbali, dakotaphu, Valters09 and 13 guests
