[Plugin] Smoothstep Animation
Postby Whaat » Mon Oct 06, 2008 7:18 pm
Sorry for the delay in releasing this plugin. I've been on holidays and working on other projects. This plugin allows you to smooth out the jerky scene transitions in a SketchUp scene-tab animation. It is not intended for object animation, only native SkechUp scene animation. It cannot be used as-is to export to a rendering engine.
Usage:
1) Copy 'smoothStepAnim.rb' to 'Plugins' folder as usual.
2) Notice two new self-explanatory items under 'Plugins' menu
3) Plugin can export single frames only. The images must be joined into a movie format using other software (eg. VirtualDub)
Issues:
- All scene delays must be set to 0.0 seconds
- likely more lurking...I have not tested very thoroughly. Please post bugs.
Enjoy!
Dale
8
Whaat
PluginStore Author
PluginStore Author
Re: [Plugin] Smoothstep Animation
Postby remus » Mon Oct 06, 2008 7:23 pm
Cheers,another interesting plugin form the great ideas factory (better known as you :) )
remus
Postby spence » Mon Oct 06, 2008 7:36 pm
Nice! I did a really quick test and it seems to work pretty good. I used Quicktime to create the image sequence.
Spence
spence
Premium Member
Premium Member
Postby princedragoncok » Tue Oct 07, 2008 12:16 am
Been looking forward to this :ecstatic: Will give it a test tomorrow. Thank you Whaat :thumb:
princedragoncok
Postby bianhai » Tue Oct 07, 2008 1:05 am
very good!
thank you , Whaat. :thumb:
bianhai
Banned
Postby solo » Tue Oct 07, 2008 1:08 am
Whaat,
Thanks mate, that works great, I may now try GSU animation again, as I stopped using it for the exact reason you felt the need to create this great plugin.
http://www.solos-art.com
solo
Global Moderator
Postby MALAISE » Tue Oct 07, 2008 9:10 am
Thanks a lot, Whaat. I've just made simple test, pretty well smooth transitions. :thumb: :thumb:
MALAISE
MALAISE
Postby matt77 » Tue Oct 07, 2008 9:49 am
thank you so much!!
this has been much needed in SU.
Many,Many Thanks
Matt
matt77
Postby pilou » Tue Oct 07, 2008 10:48 am
What is the file format of images exported?
Speedy Galerie
Top SketchUcator
Postby matt77 » Tue Oct 07, 2008 11:26 am
Either Jpeg or PNG..
matt77
Postby Ben Ritter » Tue Oct 07, 2008 1:55 pm
Whaat,
Thank you so very much,
Ben
Ben Ritter
Postby jcdb » Tue Oct 07, 2008 3:29 pm
How do you set all scene delays to 0.0 seconds? :?
jcdb
Premium Member
Premium Member
Postby spence » Tue Oct 07, 2008 4:51 pm
jcdb,
Go to Model Info, under window, and then Animation, scene delay.
Spence
spence
Premium Member
Premium Member
Postby modelhead » Tue Oct 07, 2008 5:35 pm
Thanks Whaat...much needed!!
modelhead
Postby Pixero » Tue Oct 07, 2008 6:05 pm
Thanks for a great script. :D
Would it be possible to add an attribute to all the existing scenes in the model that they are "keyframes" and then add scenes for every frame in the animation with an attibute that they are "inbetweens" and add scene transition times according to your smoothstep script.
The script should then be able to delete all the "inbetweens" if you want to change the animation but leave the "keyframes" intact.
I believe this would make it work with external renderers.
What do you think, is it doable?
Pixero
Postby jcdb » Tue Oct 07, 2008 7:12 pm
spence wrote:jcdb,
Thanks spence :thumb:
jcdb
Premium Member
Premium Member
Postby Whaat » Tue Oct 07, 2008 7:24 pm
Pixero wrote:Thanks for a great script. :D
That's a cool idea and definitely doable! :thumb: I'll do some experimenting.
Whaat
PluginStore Author
PluginStore Author
Postby Jon » Tue Oct 07, 2008 9:13 pm
Thanks again, Whaat! :berserk:
Jon
KT Team member
Jon
Postby RickW » Tue Oct 07, 2008 10:30 pm
Unfortunately, there's currently no way to delete pages/scenes in ruby... :(
RickW
Postby Pixero » Wed Oct 08, 2008 8:17 am
Here's what Todd said at the Google Group:
Sketchup.active_model.entities.erase_entities(page) should work, but
it hangs SketchUp. It's a known and reported bug.
To get around this bug, do this:
First, make the page you want to delete the active page. Then, issue
this from Ruby:
Sketchup.send_action "pageDelete:"
That means it can be done even if its a work around.
If not we could save the model prior to using the script and then saving it after, under another name or with a "_anim" after.
Not the best way but it would still mean we could render a smooth animation.
Pixero
Postby erikB » Wed Oct 08, 2008 8:47 am
Thanks from me to Whaat, very much needed script !
greetings erikB
erikB
Postby kwistenbiebel » Wed Oct 08, 2008 9:34 am
Thank you Whaat!
I hope you get the 'to scene tabs' method working, so we can use external render software on the animation.
Great job! :thumb:
kwistenbiebel
Postby Matt666 » Wed Oct 08, 2008 12:44 pm
Pixero wrote:Sketchup.send_action "pageDelete:"
A confirmation message box opens every attempt to delete a scene...
Frenglish at its best !
My scripts
Matt666
Postby Pixero » Wed Oct 08, 2008 12:54 pm
Well...lets hope Whaat finds a trick to fool SU to delete the scenes without SU knowing what happened... :roll:
Is
Code: Select all
entities.clear!
not working either?
Pixero
Postby kwistenbiebel » Sun Feb 08, 2009 5:04 am
Hi Whaat,
Would it be a sh*tload of work for you to have this plugin make default scene tabs after smoothing the animation ? (needed for render engines)
The current method (cameralines.rb,F-Spline bezier,Flightpath (or SU-animate) is kind of tedious.
Your smoothstep animation ruby would be an easier 'out of the box solution' when it can create a scene tab animation.
If it is a lot of work...maybe commercial?
kwistenbiebel
Postby Whaat » Sun Feb 08, 2009 5:07 am
kwistenbiebel wrote:Hi Whaat,
I am curious. Which render engines are able to automatically render all scene tabs? I assume you are not manually rendering each scene tab when you are creating these types of animations.
Whaat
PluginStore Author
PluginStore Author
Postby kwistenbiebel » Sun Feb 08, 2009 5:10 am
Vray and Fryrender can render a scene tab animation.
For instance, if you have 1 scene tab per animation frame, you set the SU transition time to 1 second.
In the Vray/Fry panel, you set 1 fps.
That way, Vray/Fry will render each scene tab automatically when hitting the render button.
I thought Skindigo can do this as well? (confused)
kwistenbiebel
Postby steelers05 » Mon Feb 09, 2009 8:05 pm
yeah im with biebel on this one.. that would be great if you could make something like that
steelers05
Postby Dan » Mon Feb 09, 2009 8:16 pm
Thanks for yet another great plugin, Whaat!
Me too I did a very quick test and all seems to be ok.
I have to ask you a little change to the script, if possible: can you make it to number the exported bitmaps like "name00001.jpg", "name00002.jpg", instead of "name0.jpg", "name1.jpg", etc. to make the conversion to avi program to read them in the right order?
Thanks again!
Dan
Postby Fletch » Wed Feb 11, 2009 12:15 am
I second KB and Steeler's request, Whaat... you still thinking about this?
Fletch
Twilight Render
Next
Return to Plugins
Users browsing this forum: bengpin, Toomas and 16 guests
