[Plugin] follow me rotate
• Page 1 of 5 • 1, 2, 3, 4, 5
[Plugin] follow me rotateIt is still in developing, here is the current version.
Re: [REQ] follow me rotateWikii
I get a error on the ruby console I attach a image. Daniel S Please, register (free) to access all the attachments on the forums.
Select welded edges as path and a face before using this script.
Re: [REQ] follow me rotateA curve path
I attach a video showing what i´m doing... still I get a error in the ruby console. Daniel S Please, register (free) to access all the attachments on the forums.
Re: [REQ] follow me rotateSorry , I modified two classes.
Please download again Please, register (free) to access all the attachments on the forums.
Re: [REQ] follow me rotateI cannot seem to get it to work, I see it in the plugin drop down menu, but when I select it it does nada, does it work like follow me tool? if yes then I cannot seem to figure it out.
Re: [REQ] follow me rotateSelect welded edges as path and a face before using this script.
Re: [REQ] follow me rotateNow works..
thank you Wikii!! Solo... install the latest version, and under Plugins you will see "FollowAndRotate". Select first a curve and a face. Daniel S
Re: [REQ] follow me rotateI have tried that without anything happening.
Re: [REQ] follow me rotateSolo...
try with the ruby console open like in the video i attach here: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12965&start=15#p94900 And if it gives error send the error to wikii. For me is working now. Daniel S
Re: [REQ] follow me rotateIt's working for me also. Thanks sooo much wikii!!
![]() A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
Re: [REQ] follow me rotateWheeee, thanx a million !!!
Re: [REQ] follow me rotateThis is fantastic! Thanks a lot wikii!
Re: [Plugin] follow me rotatephantastic plugin Wikii! thanks for sharing
however, when I use a welded curve, I get very unexpected results. something doesn't seem to be working with welded paths. everything works fine if I use a bezier curve (no matter how complicated) and I have a suggestion for a future update: if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point. would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance. or even better, could you change the script to allow the use of several seperate faces?
Re: [Plugin] follow me rotateAny chance of making this available as a .zip file? I have problems with files with .rar extensions.
Re: [Plugin] follow me rotateFunny
Done Please, register (free) to access all the attachments on the forums.
Try to select one curve , one face and one construction point , then , using FAR. The construction point will be treated as the center of the face. Please, register (free) to access all the attachments on the forums.
Re: [Plugin] follow me rotateweird. it only works for me, if I have a curve as a path. it doesn't work with a straight line like in your example (not even the dialog box for rotation/scale input appears)...
but arround a curve it looks really cool!
Your are not alone And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no Please, register (free) to access all the attachments on the forums.
Re: [Plugin] follow me rotateInspecting mirrors is a job I could easily see myself doing.
select a face without it's border
Re: [Plugin] follow me rotatethank you. that works.
Re: [Plugin] follow me rotateDear Pilou,
Thanks for posting the .zip file. Regards, Bob
Re: [Plugin] follow me rotatehey wow awsome plugin, thanx for posting, is there any way to reverse the triangulation of the faces, i noticed that once smoothed the and as you rotate the form it gets very jaggy at the edges and you have to go in there with the flip edge tool to smooth it out... any way around this within the coding?
Re: [Plugin] follow me rotateWe have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
SketchUcation One-Liner AdvertsAre you a Premium Member? Get your freebies here. Are you not> a Premium Member yet? Upgrade your account to grab these freebies instantly.
