[Plugin] Double line
Postby Didier Bur » Sat Sep 20, 2008 8:23 pm
Hi all,
Remember good ol' dline.lsp in Autocad ?
Here is a similar plugin to draw these kind of things:
Available options (on TAB press):
-justification
-caps
-draw axis
-draw face
-make group
-width and height
-close
Enjoy !
EDIT 21.09.08: "close" option added, options selection persistent.
EDIT 23.09.08: changed the shortcut for "close" option: "x" instead of "c" which is a default shortcut for "circle".
EDIT 25.09.08: changed the shortcut for "close" option: double-click.
EDIT 26.09.08: changed the "undo": one wall at a time.
EDIT: 10.04.10 file_loaded? bug fixed
EDIT: 11.04.10 file_loaded? call removed
EDIT: TIG
Please download the latest RB [in RBZ format] from the SketchUcation PluginStore
Download
It is now recoded for compatibility with MAC & PC and suitable for v8 to >=v2015.
TAB (up) now opens the dialog on MAC and PC.
Its lines are forced 'flat' - constrained to the first picked point's Z.
If it's grouped it is given a unique name ["DLINE#n"].
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: [Plugin] Double line
Postby Edson » Sat Sep 20, 2008 8:24 pm
fantastic gift, didier! thanks!
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby Marian » Sat Sep 20, 2008 8:50 pm
All hail the WISE and KIND DIDIER. :berserk:
Marian
Postby rv1974 » Sun Sep 21, 2008 8:05 am
I was missing this tool. Many thanks indeed!
Some minor problems:
1/ Sometimes it refuses to make "walls" after tracing over existing lines.
2/ Sometimes it it makes negative Z height.
3/ Could the last parameters input be remembered?
Could there be option to get vertical (along world z axis) not perpendicular "wall" to sloped face?...with sloped\terraced
upper cap to keep average height? :o
rv1974
Postby Didier Bur » Sun Sep 21, 2008 11:59 am
1/I know how to fix this. wait next release
2/This happens when you draw a wall on an existing face. this is normal, the workaround is to ask for making a group in the dialog box, or create a group with the existing face you want to draw on.
3/Yes. For now the tool only remembers prameters if you draw several walls without exiting it.
P.S.: I guess a "close" option to come back to the very first point would be nice ?
Didier Bur
Didier Bur
Postby Matt666 » Sun Sep 21, 2008 12:13 pm
Hi Didier !
Thank you for this another great plugin !!
J'ai juste un petite question : Tu dois connaitre archicad ! L'outil de dessin de mur permet de modifier la justification du pan de mur que l'on va dessiner...
I have a question for you : I suppose you know Archicad... In archicad, we have possibility of changing the justification while you are drawing the 2d wall...
For example :
Wall 1 = Justification "center"
Wall 2 = Justification "Left"
etc..
In just one command !
Is it possible to do that ?
Frenglish at its best !
My scripts
Matt666
Postby marcosrodrigues » Sun Sep 21, 2008 12:43 pm
Thank you, Didier!
| menos é mais
marcosrodrigues
Postby sepo » Sun Sep 21, 2008 2:11 pm
Very useful...looking forward to next update. Thanks Didier.
sepo
Postby arqpadao » Sun Sep 21, 2008 6:06 pm
Hi Didier
thanks, this is great.
fernando padão
arquiteto
porto alegre - brasil
http://arqpadao.blogspot.com
arqpadao
Postby free agent » Sun Sep 21, 2008 6:59 pm
very handy, thanx!
free agent
Postby Didier Bur » Sun Sep 21, 2008 10:11 pm
Some enhancemments added today. See top of post.
Didier Bur
Didier Bur
Postby TIG » Sun Sep 21, 2008 10:51 pm
Didier
Excellent idea - I was working on something similar, mine was called 'mline' - you beat me to it ! Well done.
I can't get 'C' to work closing the loop - I have a short cut for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
Global Moderator
Postby pilou » Mon Sep 22, 2008 12:39 am
@ Tig Same problem but ...
Just enter any number then backspace for erase it then write c then Enter ;)
And you can keep your C shortcut :)
Speedy Galerie
Top SketchUcator
Postby honoluludesktop » Mon Sep 22, 2008 1:57 am
Are any other script.rb required to be installed in the plugin folder?
honoluludesktop
In Remembrance
Postby Matt666 » Mon Sep 22, 2008 8:10 am
Hi Didier !!
One question : Is it possible to add an "undo" key inside the command ?
Thank you !
My scripts
Matt666
Postby Hazza » Mon Sep 22, 2008 9:49 am
Do you know how easy this tool makes it to create pieces of wood for my models!!!! Hit D, enter 2 of the dimensions, click click, done.
That is awesome, thank you...
See all of my SketchUp models here.
Hazza
Postby Didier Bur » Mon Sep 22, 2008 10:43 am
I can't get 'C' to work closing the loop - I have a short cur for circle that's 'c' so it dumps into that. Perhaps having something like shift+enter to close might do it ?
I noticed that also at the office on a standard install of SU, at home my PC doesn't have the "c" shortcut...
BTW, how to detect the Shift+enter keys pressed ?
I was thinking of a "x" shortcut instead but Shift+enter is more intuitive.
@honolulu: no, no additionnal files required. Maybe a glitch with the pushpull if you are on Mac ?
@Pilou: want always more, hey ? i'll try to do it...
Didier Bur
Didier Bur
Postby mike d » Mon Sep 22, 2008 12:32 pm
thanks
The grass is always GREENER on the roof.
mike d
Postby daiku » Mon Sep 22, 2008 1:25 pm
This is fantastic, Didier. I have one suggestion (for now :) ): Each time the user hits the enter key to draw the walls so far, commit the operation so the wall sections can be undone one at a time. Thanks again, this is really useful. CB.
daiku
PluginStore Author
PluginStore Author
Postby pilou » Mon Sep 22, 2008 3:13 pm
With some arcs now? :mrgreen:
Speedy Galerie
Top SketchUcator
Postby Didier Bur » Mon Sep 22, 2008 5:06 pm
With some arcs now?
No no no. Ask TIG! :roflmao:
BTW, you can draw walls that include arcs with the "line2wall*.rb" scripts.
Didier Bur
Didier Bur
Postby TIG » Mon Sep 22, 2008 5:29 pm
Didier Bur wrote:Hi,
The code is basically "if key1== enter AND key2== shift then..." For example
Code: Select all
def onKeyDown(key,repeat,flags,view)
  @key="shift" if key==CONSTRAIN_MODIFIER_KEY
end#def
Global Moderator
Postby Didier Bur » Tue Sep 23, 2008 8:13 am
Patch published today. Shortcut for "close" changed to "x" instead of "c".
Didier Bur
Didier Bur
Postby pilou » Tue Sep 23, 2008 9:10 am
Damned I have x for X-Ray :mrgreen:
So my previous trick will work fine again :D
Just write any number like 1
then write x
then Enter
It's like Glen Gould but works :mrgreen:
Speedy Galerie
Top SketchUcator
Postby TIG » Tue Sep 23, 2008 9:23 am
Didier Bur wrote:Patch published today. Shortcut for "close" changed to "x" instead of "c".
Didier
Using "X" is a good choice: x is usually reserved for copying - e.g. x3 to make copies within other commands and isn't a shortcut... If like Pilou you want to use 'X' as a shortcut for something like X-ray you need to remember to use 3x for copies rather than x3, as the latter will invoke X-ray rather than make copies ! Persoanlly I use Alt+X for X-ray mode...
Global Moderator
Postby pilou » Tue Sep 23, 2008 10:01 am
cool little trick :ugeek:
Speedy Galerie
Top SketchUcator
Postby Fletch » Tue Sep 23, 2008 3:03 pm
Great work, Didier! Thanks so much for sharing!
a couple little things:
when I choose "show axis"... it does not show... whether or not I have it pop the wall up.
After drawing a wall, I exit the tool, then I want to draw a double line vertically on a face, so I choose to use the tool again... set width to 12", no face, no close. I draw a vertical line from top edge to bottom edge of the wall face. I hit enter for it to draw the double line. I get this.
Fletch
Twilight Render
Postby Ben Ritter » Tue Sep 23, 2008 3:59 pm
Thank you very much Didier.
Ben Ritter
Postby lapx » Tue Sep 23, 2008 6:32 pm
Thanks D! I'll have to try it out sometime.
lapx
Postby Didier Bur » Tue Sep 23, 2008 6:37 pm
Axis is drawn with guide lines (construction lines). Do you have them visible ?
Remember axis will only be visible if justification is "Center".
Oh yes, I noticed that here too. The part of line up the wall is always exactly half the width of the wall :shock:
As a matter of fact, this is normal: for the script to work in 3D, I had to compute the geometric plane on which the first two segments are drawn. Thus if you click only one segment, two points aren't enough to define the plane of the base. In this case the script considers that the plane is the red-green plane. And your points have the same projection on the red-green plane. So an error occurs. Hope I'm clear, hem,hem...
But I'll try to fix that if I can.
Didier Bur
Didier Bur
Next
Return to Plugins
Users browsing this forum: areyou, auroramahira, Ezio13, haydersatar31, LM Interior design and 14 guests
