by wikii » Mon Sep 15, 2008 7:45 am
Pilou wrote:Plugin added below under this link.
Does exist a ruby script for kill the internal surfaces but not the edges of these surfaces (after a Pushpull + Ctrl for example)? Why? Because when you export a Su file in OBJ to Zbrush for example, these intenal faces were not erased and make some disturb!
Resolved see here Thx Wikii & Matt666  face.jpg remove_inner_faces.zip
Reason: Attributed post to Wikii
wikii
by Gaieus » Mon Sep 15, 2008 8:21 am
It's not very difficult to do it manually either; viewtopic.php?f=22&t=905
- Administrator
- Name: Csaba Pozsárkó
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: historical reconstruction
- Level of SketchUp: Advanced
by Pilou » Mon Sep 15, 2008 8:45 am
Yes I have seen this very useful tut, but for complex objects with thousand of internal faces, it's some painful  No possibility to test a surface'state in Ruby + SU? Select visibles face + Inverse Selection delete ?
Pilou
- Top SketchUcator
- SketchUp version: 6
- License type: Free
- SketchUp use: hobby
by Free Agent » Mon Sep 15, 2008 9:31 am
the subdive and smooth plugin set has a tool that does what ur asking for however u cant control how much it extrudes (which is a bit silly really) it just extrudes a bit to give you those extra faces then u have to manually drag it to the legth u want
Free Agent
- Name: Sean
by Pixero » Mon Sep 15, 2008 2:42 pm
Free Agent wrote:the subdive and smooth plugin set has a tool that does what ur asking for however u cant control how much it extrudes (which is a bit silly really) it just extrudes a bit to give you those extra faces then u have to manually drag it to the legth u want
Yeah, that tool would be great to have as a standalone script as an alternative to the normal pushpull tool.
Pixero
- Premium Member
- Name: Jan Sandström
- License type: Pro
- SketchUp use: architecture
by wikii » Tue Sep 16, 2008 3:19 pm
- Code: Select all
module Wikii def Wikii.remove_inner_faces fs=[] Sketchup.active_model.selection.each{|x| if x.typename=="Face" to_be_delete=true x.outer_loop.edges.each{|y| if y.faces.length<=2 to_be_delete=nil break end } fs << x if to_be_delete end } Sketchup.active_model.start_operation "remove_inner_faces" fs.each{|x| x.erase!} puts fs.length.to_s+" faces removed !" Sketchup.active_model.commit_operation end end #Wikii.remove_inner_faces
wikii
by Pilou » Tue Sep 16, 2008 3:26 pm
@WiKii How use that? With the ruby console? I am not ruby expert
Pilou
- Top SketchUcator
by Matt666 » Tue Sep 16, 2008 7:15 pm
Hi Pilou ! 1- Copy the code in a a new notepad file. 2- Copy this code below, in the file - Code: Select all
if not file_loaded?("remove_inner_faces.rb") UI.menu("Plugins").add_item("Remove inner faces"){Wikii.remove_inner_faces} end file_loaded("remove_inner_faces.rb")
2- Save it as "remove_inner_faces.rb". 3- Move the file in plugins folder. 4- Restart SU.
Matt666
- Name: Matt
by Pilou » Tue Sep 16, 2008 9:19 pm
Ok I have made the steps above 1 2, 2(?) 3 4 but "syntax error line 16" (last line) Error Loading File remove_inner_faces.rb C:/Program Files/Google/Google SketchUp 6/Plugins/remove_inner_faces.rb:16: syntax error Edit  : I only forgotten to scroll the first code of Wikii so some lines are missing All works fine! You are genious!!!  Ruby linked by Wiiki
Pilou
- Top SketchUcator
by Gaieus » Wed Sep 17, 2008 7:22 am
Pilou wrote:... only forgotten to scroll the first code of Wikii so some lines are missing  ...
There is a "Select all" link on the top of the code snipplet - if you use that, you can make sure not to leave anything out in the future (or click in the code field and hit Ctrl+A then Ctrl+C)
- Administrator
- License type: Pro
by Pilou » Wed Sep 17, 2008 7:31 am
Yes for the next time it will be more easy!
Pilou
- Top SketchUcator
by EA-d » Sat May 08, 2010 2:43 pm
Pilou wrote:Does exist a ruby script for kill the internal surfaces but not the edges of these surfaces (after a Pushpull + Ctrl for example)? [/attachment]
How about one for killing external surfaces, after an intersection of multiple groups, when forming internal models only (eg for export for light or acoustic modelling)? I'd like to place a marker (or the camera) inside my room and have a plugin automatically trim and delete any surfaces not reachable from that point. Sort of like doing a blow-mould! Would be very handy!
EA-d
- Name: Paul Malpas
by irwanwr » Mon Apr 30, 2012 3:37 pm
merci monsieur Pilou  and wikii of course
irwanwr
- Name: irwanwr
- Level of SketchUp: Beginner
Return to Plugins
