by Didier Bur » Sun Aug 31, 2008 10:17 pm
Hi all, Here is an update of my former script "line2cyl.rb". Intended to create renderable wire frame models. Some bug fixes and enhancements: - Make group of all tubes or not, - Each tube is a group or not, - Paint tubes with a material, - Quick doc included. Have fun, 09.12.08: french version available Please get the latest version from the PluginStore Download
Didier Bur
- Name: Didier Bur
- Operating system: Windows
- SketchUp version: 2018
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by pilou » Sun Aug 31, 2008 10:25 pm
A new "hit" for sure PS In french "Hit" = tube
- Top SketchUcator
- Name: Pilou
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: hobby
by johnsenior1973 » Sun Aug 31, 2008 10:28 pm
Thanks a lot for this great new plugin.
One thing though, the PDF says that the tool can be selected in the Tools menu. That wasn't the case for me. It was in the Plugins menu.
EDIT: I was wrong. I was using the Lines2Cylinders ruby from the Plugins. I cannot find the Line2Tube ruby at all.
johnsenior1973
by solo » Sun Aug 31, 2008 10:53 pm
Thanks mate, works great.
solo
- Global Moderator
- Name: Pete Stoppel
- License type: Pro
- SketchUp use: other
by pilou » Mon Sep 01, 2008 12:10 am
Menu Tool/ Convert arcs, circles, curves, lines to cylinders  dome.jpg
- Top SketchUcator
- Name: Pilou
by utiler » Mon Sep 01, 2008 12:18 am
thank didier, just what i need this week.....!!!!
utiler
- Top SketchUcator
- Name: Andrew
- SketchUp version: 2013
- License type: Pro
by johnsenior1973 » Mon Sep 01, 2008 12:51 am
Pilou wrote:I cannot find the Line2Tube ruby at all.
johnsenior1973
by pilou » Mon Sep 01, 2008 1:11 am
I don't know what I can say more  Maybe for any reason the plug is not installed in the good place? what_can_isay.jpg
- Top SketchUcator
- Name: Pilou
by boofredlay » Mon Sep 01, 2008 2:16 am
Didier, I am getting the same result as johnsenior1973. I have placed the ruby in the Plugins folder but does not show up in the Tools menu. Lines2_2.jpg Lines2_1.jpg
boofredlay
- Global Moderator
- Name: Eric Lay
- License type: Pro
by CameronVan » Mon Sep 01, 2008 2:20 am
It is not showing up for me either.
CameronVan
- Name: Cameron Van
by utiler » Mon Sep 01, 2008 2:40 am
look under plugins..... [to the left of HELP!!!!] sorry, had a little moment there...
utiler
- Top SketchUcator
- Name: Andrew
- License type: Pro
by boofredlay » Mon Sep 01, 2008 2:51 am
Is that where it shows up for you because it is not there for me? Lines2_3.jpg Furthermore the pdf file Didier attached said it would be located under Tools, not Plugins. Edit: Here is part of the pdf just in case you did not read it. Lines2_4.jpg And yes... I restarted SU.
boofredlay
- Global Moderator
- Name: Eric Lay
- License type: Pro
by utiler » Mon Sep 01, 2008 5:04 am
You'r right Boo, Tools is where it is.....
now have a little moment at my expense!!!
utiler
- Top SketchUcator
- Name: Andrew
- License type: Pro
by Chris Fullmer » Mon Sep 01, 2008 5:59 am
It was listed just fine for me on Vista 64bit in the tools menu. Great plugin! Here's a helix, triple helix, double helix, something that isn't a helix, but sort of close, then another 10x helix or something. I'm sure most of those names are wrong, so just look at the picture  Chris
- SketchUp Team
- Name: Chris Fullmer
- License type: Pro
- SketchUp use: landscape architecture
by pilou » Mon Sep 01, 2008 8:12 am
for the problems, maybe you must disable the old "line2cyl.rb"?  maybe...
- Top SketchUcator
- Name: Pilou
by gaucho » Mon Sep 01, 2008 9:16 am
Thanks didier! It works great! I've already used...  One single possible request... would be possible to modify so we could extrude along square shapes as well? So in Solo's image above for example, i could quickly build beans, columns.. etc etc.. all square? Thanks again! PS: i've just donwloaded your all in one file... i'm feeling it'll take me ages to check them all...
"eat well, stay fit, die anyway..."
gaucho
- Name: Giovani Cervo
by sepo » Mon Sep 01, 2008 12:07 pm
for me it works with old tool.... Thanks Didier for a very usefull plugin... I was wondering if there is way to clean up intersection...
sepo
- Name: sepo
- License type: Pro
by urgen » Mon Sep 01, 2008 12:17 pm
...thanks,Didier!...I expected it for a long time!
--pupil forever...------
urgen
by rv1974 » Mon Sep 01, 2008 12:30 pm
Very nice Didier, thanks Additionally may be you could: 1/ add a rotation parameter (when precision is 4 one would get square section (rotation 45)) 2/now I weld lines to get continuous result. Any chance to get it automatically? 3/conjunctions?
rv1974
- Name: rv1974
- License type: Pro
by urgen » Mon Sep 01, 2008 1:32 pm
Pilou wrote:for the problems, maybe you must disable the old "line2cyl.rb"?  maybe...
...yes! "line2cyl.rb" should be deleted  ...Didier, please restore this function in "projection_extension.rb"
urgen
by johnsenior1973 » Mon Sep 01, 2008 2:04 pm
Deleting the lines2cyl ruby did sort out the problem.
johnsenior1973
by Didier Bur » Mon Sep 01, 2008 4:54 pm
Hi all, Sorry for the inconvenience of the "not showing plugin" problem. My fault. You must delete old "line2cyl.rb" of your plugins folder OR I must correct the name of the plugin in the code (I forgot to change it). If line2cyl is loaded first, SU doesn't create another menu item in the tools menu for the new version. would be possible to modify so we could extrude along square shapes as well?
Use a precision of 4 and you'll get square section prisms.(RTFM) please restore this function in "projection_extension.rb
Does this make sense ? This function has nothing to do with projection IMHO... I was wondering if there is way to clean up intersection...
The script can't do it (I mean, quite difficult to code). A workaround is to draw as much curves as you can, and select "Yes" in the "follow-me on curves" option. But it cannot clean intersections on T or Y or X branching edges. Maybe next version will do it ?
Didier Bur
- Name: Didier Bur
- License type: Pro
by Frederik » Mon Sep 01, 2008 7:53 pm
THANKS A LOT, Didier..!!
Cheers Kim Frederik
Frederik
- Thea Render Support
- Name: Kim Frederik
- SketchUp version: 2019
- License type: Pro
- SketchUp use: interior design
by dylan » Mon Sep 01, 2008 8:14 pm
Thanks Didier.
Could this be adapted to use a semi-circle with thickness? I am thinking of use for ridge tiles on a roof.
dylan
- Name: Dylan
- Operating system: Mac
- SketchUp version: 2016
- License type: Pro
- Level of SketchUp: Beginner
by urgen » Mon Sep 01, 2008 10:24 pm
Dylan wrote:Could this be adapted to use a semi-circle with thickness? I am thinking of use for ridge tiles on a roof.
...HA!...good idea,Dylan!
urgen
by ely862me » Tue Sep 02, 2008 12:45 am
Another piece of....what????...let*s say Pandora*s box!! This will help me to make tubular chassis instead of what i was making before.  Thank you Mr. Didier!! Elisei
Elisei (sketchupper) ____________________________________________________________ Before no life was done on Earth it was THE LIFE ITSELF... GOD Come and See EliseiDesign
ely862me
- Top SketchUcator
- Name: Elisei
- License type: Pro
by utiler » Tue Sep 02, 2008 2:05 am
sepo wrote:for the problems, maybe you must disable the old "line2cyl.rb"? maybe...
Ditto Sepo, I found the same thing...
utiler
- Top SketchUcator
- Name: Andrew
- License type: Pro
by 2myChaGrin » Tue Sep 02, 2008 2:22 am
Thanks so much Didier! You just made my life so much easier!
2myChaGrin
by boofredlay » Tue Sep 02, 2008 2:42 pm
I did not have a chance to look at this until now on my work machine. I had line2cyl.rb here as well. I installed Lines to tubes and got the same results... not showing up. So I then tried as you suggested Pilou, deleting line2cyl.rb and now it is showing up. Thanks.
boofredlay
- Global Moderator
- Name: Eric Lay
- License type: Pro
by Marian » Tue Sep 02, 2008 4:49 pm
i think there should also be an option to make not round tubes but square hexagonal triangular ones.
Marian
- Name: Marian
- SketchUp version: 8
- Robot
Return to Plugins
