[Plugin] Scaling to_cm
• Page 1 of 1
[Plugin] Scaling to_cmA bit changed the tools of Scalin
Re: Scaling to_cmsorry i'm confused, is this a scaling ruby?
pav Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
Re: Scaling to_cmchanges a model size.
Re: Scaling to_cmah i see! i shall have a tinkle and see how i get on.
Re: Scaling to_cm--pupil forever...------
Re: Scaling to_cmhi sahi thanks for this ruby!
is there anyway to change it to meters?
Re: Scaling to_cm
meters Please, register (free) to access all the attachments on the forums.
Re: Scaling to_cmHi,
This doesn't work here: it gives weird results, out of range, entities are moved elsewhere. If entities are not grouped at start, there are grouped at the end. Am I missing something ??? Before/After a scale of 2: Please, register (free) to access all the attachments on the forums. Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F) http://rld.crai.archi.fr/rubylibrarydepot/
Re: Scaling to_cmchanged the names in a script
Menu > Plugins > Resizer Please, register (free) to access all the attachments on the forums.
Re: Scaling to_cmOn Mac I did not see the scaling tool palette. Is it Menu > Plugins > Scale?
Dialog is ambiguous: "on all of axes" is not a target size but adds entered size to actual size. The final size would be better IMHO ? Why choosing the bounds center as the center of transformation ? I suggest not to use "to_cm" or "to_m" in the code, but to use only Length type variables. Thus you will suit everyone's unit, no matter what it is. Useful script, though. Didier Bur (Bytes Farmer)
Re: Scaling to_cm
"on all of axes" ---How to name??? corrected all of other as you specified Please, register (free) to access all the attachments on the forums.
Re: Scaling to_cmCorrect me if I'm wrong, but the resize operation works only for faces in XY,XZ and YZ planes (red,green,blue) ?
"On all of axes" -> "In every direction" ? English speaking people please help ! Another enhancement is to encapsulate in an operation for one step undo:
Re: Scaling to_cm
Thank you! Corrected a code. Added an icon. Please, register (free) to access all the attachments on the forums.
Re: Scaling to_cm..growing into a nice little ruby.
Re: Scaling to_cm
Equal "In every direction" is global settings for object of selection(world scaling system in most graphic packages...in attached pic, like cinema4d) or about directions of red,green,blue, Didier, you are right/something like object system/ Please, register (free) to access all the attachments on the forums.
Re: Scaling to_cmI would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
Re: Scaling to_cm
Re: [Plugin] Scaling to_cmI don't get what should I input in the Lock aspect ratio box in order to get the selection scaled proportionally to exact dimension input in one axis?
SketchUcation One-Liner AdvertsVertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
• Page 1 of 1
