by Matt666 » Wed Jul 16, 2008 12:32 pm
Hi all ! Sorry for my poor english  !! Here is a script can soft/smooth (like ctrl+erase tool) 2-face-edges of a selection. And another show all soften edges of a selection. They both work on all entities in the drawing if nothing's selected. soft_2f_edges.JPG I don't know if a similar script exists... ?? All improvements or suggestions are welcome ! EDIT: Now this tool is used in plugin Soften/Unsoften.
Matt666
- Name: Matt
by juju » Wed Jul 16, 2008 2:05 pm
Hi Matt, please explain how this is different from the functionality we already have.
juju
- Premium Member
- Name: Juju
- Operating system: Windows
- SketchUp version: 2019
- License type: Pro
- SketchUp use: architecture
by Matt666 » Wed Jul 16, 2008 2:50 pm
Hi Juju. The procedure is different. I'll try to explain with the example above I've made. This script softened and smooth (like Ctrl + eraser) all edges with at least 2 sides connected. Thus, when we created a curved surface, this plugin softened and smooth all the edges except outer edges. Like the example. With native functionality (ctrl+eraser), you have to click on all edges to smooth and soften... I decided to make this plugin due to another, SSB. It created curved surfaces without smoothing or softening. Is it more clear now? And sorry for all the faults
Matt666
- Name: Matt
by Baker518 » Thu Jul 17, 2008 3:07 am
If I understand what you are saying, the ruby softens all surfaces leaving the edges hard. If that is correct, then you can still have points along the way to attach and work to or from. If memory serves me, I can remember softening/smoothing an object only to loose any distinguishable point to work from. Help me understand if I have missed it
Mike
Don't worry about things you have no control over. Worry is a lack of Faith!
Baker518
- Name: Mike
by juju » Thu Jul 17, 2008 10:12 am
Matt666 wrote:Hi Juju. The procedure is different. I'll try to explain with the example above I've made. This script softened and smooth (like Ctrl + eraser) all edges with at least 2 sides connected. Thus, when we created a curved surface, this plugin softened and smooth all the edges except outer edges. Like the example. With native functionality (ctrl+eraser), you have to click on all edges to smooth and soften... I decided to make this plugin due to another, SSB. It created curved surfaces without smoothing or softening. Is it more clear now? And sorry for all the faults
O I C. Thanks for the explanation.
juju
- Premium Member
- Name: Juju
- License type: Pro
by juju » Thu Jul 17, 2008 11:37 am
You mean by using the soften slider? Think so hey...
juju
- Premium Member
- Name: Juju
- License type: Pro
by rv1974 » Thu Jul 17, 2008 11:56 am
Coen Naninck wrote:Doesn't the Soften Edges panel already do this? Or am I missing something?
It appears Mat6666 is missing Soften Edges panel
rv1974
- Name: rv1974
- SketchUp version: 2017
- License type: Pro
- Level of SketchUp: Advanced
by RickW » Thu Jul 17, 2008 10:49 pm
I think most SU ruby authors at one point or another end up writing something that duplicates an internal function, either from forgetting (or not knowing) it's native, or from trying to remove a step or two in the workflow process (with varying degrees of success).
We all have our moments...
RickW
- Name: Rick Wilson
by Matt666 » Fri Jul 18, 2008 6:45 am
Soften Edges panel  Yes, I've forgotten it...  I look forward to the holidays!
Matt666
- Name: Matt
- Robot
Return to Plugins
