SketchUcation Plugin Store
[Plugin] Align tool 3D (bug fix)
Postby Didier Bur » Sat Jul 12, 2008 6:47 pm
Here is an updated version of my align tool with a bug fix (components were deformed when non orthogonal axis were clicked). User guide also added.
Regards,
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] Align tool 3D (bug fix)
Postby bianhai » Sat Jul 12, 2008 6:53 pm
Thank you very mach! :thumb:
bianhai
Banned
Postby watkins » Sat Jul 12, 2008 8:25 pm
Dear Didier,
I cannot seem to get the "Align Group/Component" option to work properly from the right-click context menu. The "Align" option works fine. When I try the "Align Group/Component" option the script first toggles on the group/component axes and then sets the starting co-ordinate system co-incident with the axes of the selected group/component(no choice given). It then asks one to define the end co-ordinate system. I was expecting to define the start co-ordinate system, as per your user guide. Also, in this mode I have to toggle off the group/component axes by going to Model Info and then deselecting the component axes option.
Is this how you intended the script to work?
Regards,
Bob
watkins
Postby watkins » Thu Jul 17, 2008 10:43 am
Dear Didier,
Have you had time to look at this?
Regards,
Bob
watkins
Postby Edson » Thu Jul 17, 2008 12:34 pm
watkins wrote:Dear Didier,
Regards,
Bob
bob,
i also wondered about that but later realized i was not 'working properly'. in many cases all you need is to set the ending system; in this cases go for align group/component (as it takes the axis alignment of the group/component as the origin system); it saves you half of the work involved in the process. in cases when you do need to set the origin, then choose align and set both systems. does it make sense to you?
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby watkins » Thu Jul 17, 2008 3:11 pm
Dear Edson,
Yes, that does make sense. It also makes me think more carefully about the axes when creating a component.
Thanks for your interest.
Kind regards,
Bob
watkins
Postby Didier Bur » Thu Jul 17, 2008 6:02 pm
Edson,
You've understand ALL (and explained it clearly too).
Didier Bur
SketchUp version: 8
License type: Pro
Postby Magnus123 » Sat May 15, 2010 9:25 am
Ohh Thanks Didier this will come veeeery handy for me! :berserk:
Magnus123
Postby SU Reviewer » Sun May 30, 2010 8:18 pm
Great plugin! I have been l;ooking for something like this :berserk:
At first it was tough to use but I got used to it. I made a little instructional animation enjoy..
Living Einstein's dream through SketchUp.
"Imagination is a preview of life's coming attractions" - Albert Einstein
Joe Simhon ~ SketchUp Plugin Reviews
SU Reviewer
Postby Design Tech » Fri Sep 03, 2010 2:28 pm
I am trying to install the Align tool in sketchup pro 7 on a mac. I followed the simple instruction in the PDF file but still cant seem to get it to work.
What am i missing here, or what am i doing wrong?
I put the file in my plugins folder and restarted sketchup, but dont see where the tool shows up to use?
please help
Design Tech
Postby Didier Bur » Sat Sep 04, 2010 10:05 am
Doc says: "...you'll find a menu item under the "Tools" menu",..."if you select some entities and right-click, you'll find an "Align" option in the context menu, "if you select a group or a component and right-click, you'll find an "Align group/component" option in the context menu".
So if you don't have any of these opttions in your menus, there is something wrong.
Please open the Ruby Console and type: $align_loaded (Enter)
Please report what it says then.
Regards,
Didier Bur
SketchUp version: 8
License type: Pro
Postby Panoplos » Wed Nov 10, 2010 4:14 am
Hello Didier,
I am also trying to install this on the Mac Version of Sketchup Pro 7. The plugins folder contains files with extensions of .plugin, not .rb. I tried both using the .rb and .plugin extensions with no luck.
When typing $align_loaded in the Ruby Console, the variable is nil.
Perhaps there has been some change the to plugin format in version 7?
I am looking forward to using this tool, so your support is much appreciated!
Panoplos
Postby Jeff Hammond » Wed Nov 10, 2010 4:22 am
Panoplos wrote:Hello Didier,
yikes panoplos, you're in the wrong spot..
if your 'plugins' folder is showing .plugin files then you're at
applications folder > sketchup.app > (show package contents) > contents > plugins..
that's the actual app and those 'plugins' are the file importer/exporters..
ruby plugins go here:
Macintosh HD> Library> Application Support> Google SketchUp (#)> SketchUp> plugins
try that out instead.
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby irsa » Sun Apr 24, 2011 7:37 am
thank you so much, its so useful
irsa
Postby simon le bon » Thu Apr 28, 2011 10:55 pm
Hi!
until Joe Simhon showed how "Align Tool 3D" was working I hadn't noticed its interest..
Playtime:
A rhombic triacontahedron consists of 30 golden rhombus perfectly identical. This Quasicrystal (Quasicrystals discovered in 1984) has been many fears for crystallographers because some had seen as a crystal with a symmetry of order 5, which is not like any self-respecting crystallographer knows!
http://en.wikipedia.org/wiki/Quasicrystal
http://en.wikipedia.org/wiki/Golden_rhombus
http://en.wikipedia.org/wiki/Rhombic_triacontahedron
++ simonlebon
simon le bon
Postby Pilou » Thu Apr 28, 2011 11:57 pm
Indispensable as soon as you have some objects who are not regulary oriented! ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby alexdobras » Thu May 12, 2011 9:33 pm
thank you !
alexdobras
Postby jbrfrk » Sat Sep 10, 2011 8:51 am
really useful.... thanks
:thumb:
J=K
jbrfrk
Postby archman212 » Wed Oct 12, 2011 3:52 am
fantastic..i have been looking for this one... :thumb:
archman212
Postby Omez » Mon Nov 28, 2011 1:51 pm
THANK YOU! :thumb: :thumb: :thumb:
I even not trying it yet, but i believe its very useful... once again, Thanks! :)
Omez
Postby john2 » Thu Jan 05, 2012 3:50 pm
couldn't understand 4m the pdf. :( is there any video tutorial :roll:
Google SketchUp Pro 8, Vray 1.49, Windows 7 – 32 bit
john2
Postby Didier Bur » Thu Jan 05, 2012 6:18 pm
Didier Bur
SketchUp version: 8
License type: Pro
Postby Ken » Thu Jan 05, 2012 6:36 pm
Didier
Not asking anything to be changed, however it took me some time to determine that what you call the "X axis" and "Y axis" can be any particular orientation. I was always trying to determine what the "X and Y axis" were while using the plugin. Lead to much frustration.
I always wanted to be able to get inside the plugin and change the "X" to "1" and the "Y" to "2". To me that would have been more logical to remember, I wanted the "1's" and "2's" to align with each other.
Thank you for your contribution.
Ken
Government rushes to help the irresponsible and does little for the responsible.
Ken
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby Didier Bur » Fri Jan 06, 2012 9:22 am
Hi Ken,
You can also think that X represent the red axis, Y the green axis, just as when you locate/translate/rotate the SU axis system.
Didier Bur
SketchUp version: 8
License type: Pro
Postby raineysky » Sat Jan 07, 2012 2:20 am
Ken,
:thumb:
I really like your idea too because I'm not use to the "x,y,z" language yet. Just now getting orientated in the 3d space :)
Thank You for the plugin Mr. Didier Bur.
raineysky
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby kevinbearshu » Wed Feb 08, 2012 3:33 am
kevinbearshu
Name: shu ying hsiung
Postby wodur » Tue Mar 20, 2012 7:25 pm
it's an impressive plugin, almost equal to the Autocad's align tool. Autocad can scale the objet as it aligns, is it possible to do that with this plugin?
Thanks for your work, all of you are making sketchup a very advanced tool.
wodur
Postby seebe » Thu Apr 26, 2012 2:33 pm
Thank you so much for this tool. You have saved me so much time.
seebe
Postby Didier Bur » Thu Apr 26, 2012 3:33 pm
@seebe: you're welcome :sketchstatic:
Didier Bur
SketchUp version: 8
License type: Pro
Postby Trogluddite » Fri Apr 27, 2012 9:06 am
D'oh moment for me! :oops:
I spent so long trying to align things using the rotate/protractor tools - when all I needed to do was type "Align" into the search box and intall this super plugin!
Many thanks Didier, you have made my Sketchuping so much easier!
Trogluddite
SketchUp version: 8
License type: Pro
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
Next
Return to Plugins
Users browsing this forum: d12dozr, Jean-Franco, nukit, Paul Russam, skuxxy1 and 10 guests
