[Plugin] CenterPointAll.rb
Postby TIG » Mon Jun 23, 2008 5:08 pm
Here's an updated version that adds a centerpoint to anything that's selected - Group, ComponentInstance, Line, Circle, Face etc.
Select / filter what you want c'pointing first and then run the script. Centerpoints are added at every bounding box center. It 'undoes' in one go...
11
Reason: Split topic
Global Moderator
Re: Set centre point on multiple objects?
Postby watkins » Mon Jun 23, 2008 6:09 pm
Dear TIG,
Your script uses the same name as Todd Burch's script, centerpoint.rb.
http://www.smustard.com/script/CenterPoint
An alternative name might be cPointEntity.rb to indicate that you select the entity or entities first (line, surface etc) before running the script.
Regards,
Bob
watkins
Postby TIG » Mon Jun 23, 2008 6:13 pm
watkins wrote:Dear TIG,
Regards,
Bob
I've renamed it "CenterPointAll.rb" (see earlier post...)
Global Moderator
Postby Mr S » Tue Jun 24, 2008 8:25 am
Hi TIG,
Thanks for taking the time to create this script for me.
I will try it out today.
The name "CentrePointAll" describes exactly what is required.
Thanks again.
Mr S
Mr S
Postby juju » Tue Jun 24, 2008 12:39 pm
Sweet, thanks TIG. I'm shooting from the hip here but can someone create an icon for it so it can be placed on a toolbar? I'm using (I think) Jim's centrepoint ruby and icon as a reference.
juju
Premium Member
Premium Member
Postby david_h » Fri Jun 27, 2008 5:52 pm
Here's a problem I have. . ..If you create an ARC with the traditional Arc tool you can righ-clk on it and use the ARC CENTERPOINT rb to find the CENTER RADIUS Point of the arc. Very useful. I like that. BUT. . .and Here's the big BUT my friends . . .if you make an arc by stitching segments together via the WELD.rb and try to find the center point--you dont get teh option of using "Arc Centeroint" ruby, so I tried using the Centerpoint Rb. only finds the centroid of an implied closed figure as it were rather than the desired Radius point. Any insight you gurus could give on this would be greatly appreciated.
Thx,
Dl
If I make it look easy. . .then it probably is.
david_h
Top SketchUcator
Postby TIG » Fri Jun 27, 2008 7:26 pm
If you weld lines into a curve there's no guarantee that that 'curve' will have a 'centre' at all (draw some connected lines and weld them into a curve - where's its centre ?). So, if you have an exploded arc don't weld it back into a curve (an arc is a curve but a curve isn't an arc): just redraw the arc and then it WILL have a centre...
The following are different animals...
CenterPoint marks the 'centre of gravity' of the selection.
My CenterPointAll marks the centres of all selected objects individually.
Global Moderator
Postby Jim » Fri Jun 27, 2008 8:55 pm
Hi David,
the API supports getting the center of an ArcCurve object. Once a curve is exploded, it no longer has a center (according to the API.)
What I typically do is create a new 2-segment arc over 2 of the existing segments - in essence tracing over 2 of the existing segments. Then you can use Arc Centerpoint on that arc.
Jim
Global Moderator
Postby david_h » Fri Jun 27, 2008 9:05 pm
TIG wrote:If you weld lines into a curve there's no guarantee that that 'curve' will have a 'centre' at all (draw some connected lines and weld them into a curve - where's its centre ?). So, if you have an exploded arc don't weld it back into a curve (an arc is a curve but a curve isn't an arc): just redraw the arc and then it WILL have a centre...
Understood, hence the question. However this CenterpointALL sounds intriguing. WHere does one find this?
thx
david_h
Top SketchUcator
Postby david_h » Mon Jul 07, 2008 7:48 pm
I got the Centerpointall.rb. It's a good one , but not exactly doing what I need. It enabled me to do a workaround for my specific case, but I guess what is needed is a script that will find the Radius point of an arc even if SU doesn't recognize it as an arc per se.
david_h
Top SketchUcator
Postby plot-paris » Tue Jul 08, 2008 8:43 am
so basically you need a "geometric shape recognizer".
that would be a wonderful thing, by the way. imagine you have a complicated curved form consisting of loads of small lines and SketchUp simplifies it into (for example) three curves.
the plugin could have some correction-freedom settings too. for example if it recognizes two arcs in a shape which connecting bits are almost tangential, SU could correct the position of the connectin point slightly to match a perfect tangent...
that would be awesome! :?
plot-paris
Re: [Plugin] CenterPointAll.rb
Postby david_h » Tue Jul 08, 2008 3:08 pm
Oui! C'est Ca! Where are these RUBY GURUS when you need them? (jk) :oops:
Im sure they don't have anything else to do but respond to my whining. :D
david_h
Top SketchUcator
Postby JClements » Tue Jul 08, 2008 3:32 pm
When I have time, I often draw over "apparent" arcs and circles because I can then use Entity Info to verify radii of piping and to facilitate the extrusion of smoothed-surfaces and improve exporting .SKP's to other formats.
I think the bottom line is you'd need a basic script (using the model context or selection) to find series of contiguous segments, then analyze them to determine if they have the characteristics of an arc.
For instance: are all segments of equal length and are all of their common angles equal (there may be more conditions that I haven't thought of)? If all segments touch one another, then are they a polygon or a circle?
If such a script can be developed, then it could be used as a common routine called by other scripts such as pipe-along-path or used on intersected geometry. Once the script qualifies the segments, it could then automatically redraw them, make centerpoint guides, etc.
JClements
Premium Member
Premium Member
Postby david_h » Tue Jul 08, 2008 5:05 pm
Yeah. . .what he just said. .. uh Huh. I think
Anyway. .. I just want to find the Radius point of any curve be it arc or no. anything else, above that . . ..Gravy.
david_h
Top SketchUcator
Postby plot-paris » Tue Jul 08, 2008 5:29 pm
JClements, that would be a damn handy tool and a wonderful addition to the weld-script...
plot-paris
Postby watkins » Tue Jul 08, 2008 5:54 pm
Dear David_H
You can use the protractor to find the centre of an arc or circle. Snap the tool to the mid-point of a segment and then click on the end of that segment (you have a choice of two points). Rotate the protractor 90 degrees to create a construction line along the segment's normal (located at mid-point). Repeat for a second segment. The centre point is marked by the crossing of the construction lines.
A ruby script might work in the same way.
Activate the tool, and moving either clockwise or anticlockwise (but not both):
Click first end point, segment 1
Click second end point, segment 1
Click third end point, segment 2
Click fourth end point of segment 2
Ruby computes equations of normals at mid-points of segments 1 and 2
Ruby computes coincident point to yield x,y,z value of centre point
Variations:
Segments 1 and 2 are start and end segments of arc = redraw arc (input = number of segments)
Segments 1 and 2 are connected = redraw circle (input = number of segments)
I am not a script writer, but the above would seem do-able.
watkins
Postby david_h » Tue Jul 08, 2008 6:47 pm
Watkins. Yeah, I had been doing that. I was just hoping for a one-click solution. Cuz I ain't no Ruby Writer Neither. . .sigh! :roll: But thanks for the input.
david_h
Top SketchUcator
Postby Jim » Tue Jul 08, 2008 8:49 pm
David_H wrote:Watkins. Yeah, I had been doing that. I was just hoping for a one-click solution. Cuz I ain't no Ruby Writer Neither. . .sigh! :roll: But thanks for the input.
Dave,
You might have more luck if you start a new request thread in the Ruby forum.
Jim
Global Moderator
Postby rosbourne » Wed Sep 02, 2015 6:45 pm
Thanks.. Now more easier to make center point
rosbourne
Postby ship69 » Fri Dec 18, 2015 2:01 pm
Does this video have sound? It's coming out silent on my PC.
ship69
Postby Dave R » Sun Dec 20, 2015 2:30 pm
ship69 wrote:Does this video have sound? It's coming out silent on my PC.
No. It's a silent video.
Global Moderator
Postby Einstein » Tue Jan 02, 2018 1:07 am
Thanks TIG :D
This simple tool helps me rotating components around their centerpoints which is quite complicated in SU.
It would be even more handy if a created centerpoint was interactive, I mean: changed with scaling and moving component or group it's based on. But I realise that would be also much more complicated code.
Einstein
Postby Box » Tue Jan 02, 2018 1:20 am
Einstein wrote: rotating components around their centerpoints which is quite complicated in SU.
To rotate about the midpoint of a group or component, use the rotation handles that appear when you use the Move tool.
Postby sarkarshomit » Wed May 16, 2018 5:44 am
Can't get it working in sketchup 2018.working fine in skup16, but not in 18...any help if i am doing something wrong!!
sarkarshomit
Postby Dave R » Wed May 16, 2018 11:33 am
sarkarshomit wrote:Can't get it working in sketchup 2018.working fine in skup16, but not in 18...any help if i am doing something wrong!!
Evidently you are doing something wrong. I just installed it in SU2018 and ran it. It works fine. How did you install it? Where did you install it? Do you have Guides set to show in the View menu?
Global Moderator
Postby sarkarshomit » Wed Jun 13, 2018 10:11 am
Thanks for the help.
Strangely in skup16, the plugin shows up in plugins menu named as "set centerpoint".
And in skup18 it shows up in extensions menu as "Add centerpoint".
So finally its working for me. Thanks again.
sarkarshomit
Postby Box » Wed Jun 13, 2018 11:51 am
Sounds like you may have had a different extension installed in 2016. There is one called Set Centerpoint.
Tig's shows for me in 2016 as Add Centerpoint.
Postby Rastus » Mon Aug 27, 2018 8:47 pm
Hate to appear thick but I can't install CenterPointAll in 2018 (vs 8.0.1...). Where do I need to place the plugin?
Thanks!!
Rastus
Postby TIG » Mon Aug 27, 2018 8:54 pm
Look here
https://sketchucation.com/pluginstore?p ... erPointAll
which gives you an RBZ which can be installed in v2018 using Window > Extension Manager > Install... [red-button]
No need to find the Plugins folder etc...
Almost all Plugins which include an old RB file in their thread will have an entry in the PluginStore, giving an easily installed RBZ for use in all current versions of SketchUp...
Even the now often unsupported v8 had these RBZ capabilities in later MRs,,,
Global Moderator
Postby Rastus » Mon Aug 27, 2018 9:03 pm
Thanks!
Been a while since I've used Sketchup. You made an invaluable plugin!
Rastus
Next
Return to Plugins
Users browsing this forum: Adert, Azcko, Google Bot, NankNank and 10 guests
