[Plugin] Trilateration (Update)
Postby Didier Bur » Sat May 31, 2008 5:17 pm
Hi all,
Here is a script to draw triangles when you know the 3 lengths of the sides.
Bep beta-tested it and suggested some improvements. So consider it still a beta.
PDF Doc included.
Regards,
Updated June 8th: settings to keep/erase geometry and guides available.
Please get the latest version from the PluginStore
Download
Didier Bur
Ecole Nationale Supérieure d'Architecture de Nancy (F)
Didier Bur
Re: [Plugin] Trilateration
Postby pilou » Sat May 31, 2008 5:36 pm
Seems cool :enlight: :thumb:
And the circle quadrature will be the next? :lol:
Speedy Galerie
Top SketchUcator
Postby Bep » Sat May 31, 2008 7:33 pm
Hi Didier,
Nice to see the Beta-release.
Greetings,
Bep van Malde
"History is written by the winners"
Bep
Re: [Plugin] Trilateration (Update)
Postby Didier Bur » Sun Jun 08, 2008 2:27 pm
Updated today with settings. See top.
Didier Bur
Didier Bur
Postby kwistenbiebel » Sun Jun 08, 2008 3:54 pm
Looks nifty, but could someone explain for what purposes this is to be used?
kwistenbiebel
Postby Bep » Sun Jun 08, 2008 9:11 pm
Didier Bur wrote:Updated today with settings. See top.
Hi Didier,
You must be clairvoyant.
You worked out this part of my sugestions exactly as I wished it to be.
And that far better as I described it.
I'v got the feeling we are insync on this.
Thanks, and greetings,
:thumb: :thumb:
Bep van Malde
Bep
Postby Didier Bur » Mon Jun 09, 2008 2:59 pm
All is in the name: trilateration and in the doc: "intended to draw triangles when 3 sides lengths are known".
Useful to draw non-orthogonal room plans based on telemeter triangular measures, for instance, survey, amoung other apps.
Didier Bur
Didier Bur
Postby jstanton8869 » Tue May 20, 2014 12:34 pm
I've been using this plugin for several years and it's VERY useful. How can I install it on Sketchup 2014? If it doesn't work is there an alternative plugin that does trilateration which I use for survey data
John
jstanton8869
Postby Myrillan » Mon Jun 30, 2014 2:28 pm
Please, really need an update for Sketchup 2014
/Anna
Myrillan
Postby sdmitch » Mon Jun 30, 2014 10:04 pm
I think it is the same problem as with most of Didier Bur's scrambled plugins. You need to edit the code at the end as described in this post.
viewtopic.php?f=323&t=12354&start=60#p513679
http://sdmitch.blogspot.com/
sdmitch
PluginStore Author
PluginStore Author
Postby jstanton8869 » Tue Jul 01, 2014 1:08 pm
sdmitch wrote:I think it is the same problem as with most of Didier Bur's scrambled plugins. You need to edit the code at the end as described in this post.
Excellent, Thank you so much - it worked perfectly for me. :fecstatic:
jstanton8869
i love this tool
Postby GMthompson » Fri Sep 12, 2014 7:53 pm
This plugin has been a awesome tool for me in the past, I do architectural metals, canopies, awnings, tension structures and many other miscellaneous adventures,
Is there a compatibility issue with 2014 as i cannot seem to install this wonderful tool, no complaints she still works fine in 2013
[url][/url]
you can learn something everyday by paying attention
GMthompson
Postby Dave R » Fri Sep 12, 2014 8:25 pm
As with many of Didier Bur's very useful plugins, it probably needs updating. He seems to be very busy in other areas and hasn't updated them, though. There's a little editing that might possibly make it work in SU2014. I'll see if I can find the thread where it was mentioned although someone else may beat me to it.
Global Moderator
Postby Dave R » Fri Sep 12, 2014 8:38 pm
Found it. Take a look at this post by TIG. I'll bet the same editing he recommends will fix the issue here, too. I haven't looked but that seems to be a common thing with Didier's plugins.
Or you could have just read the post above yours. :roll:
Global Moderator
Postby GMthompson » Fri Sep 19, 2014 4:11 pm
Dave R wrote:Found it. Take a look at this post by TIG. I'll bet the same editing he recommends will fix the issue here, too. I haven't looked but that seems to be a common thing with Didier's plugins.
Thanks Dave, me finding time to edit the source would be awesome, but i have 0 time on my hands and learning new things becomes a uncontrollable addiction for me......lol, it works still in 2013
This tool is a life saver if you use SU for field construction with compound overlapping scalene triangles, :thumb: this helps me bring together realistic overlapping geometry and its pretty easy to use
GMthompson
Postby Box » Fri Sep 19, 2014 4:17 pm
It takes less time to edit the rb than it would have taken you to write that you don't have the time to do it.
Postby TIG » Tue Nov 04, 2014 7:19 pm
Didier has agreed that I might update some of his Plugins in the PluginStore.
Download
It is now compatible with v2014/2015.
Global Moderator
Postby rowseeoh » Fri May 29, 2015 12:37 am
Total noob here. The instructions in this zip file ARE EVERYTHING! thank you
rowseeoh
Postby obones » Tue Mar 22, 2016 2:11 pm
Hello,
This plugin seems amazing but I could not get it to work with Sketchup 2016.
I mean, it installs properly, it shows up in the menu.
I then started using, placed the first end, then the second and finally I entered the two values separated by a semicolon as requested in the status bar.
I then pressed enter and nothing happens, the triangle does not draw. However, I can see that Sketchup is now using one CPU core fully.
Is there something I should look at to make it work with Sketchup 2016?
obones
Postby Dave R » Fri Mar 25, 2016 1:42 am
I just installed it in SU2016 and it worked for me. Are you sure you are following the prompts at the bottom of the screen?
Global Moderator
Postby obones » Fri Mar 25, 2016 1:44 pm
Yes, I do, but debugging it, I found out what's wrong:
Basically, I input values that would give a really thin triangle and so are "out of range" for the computation to work. It thus calls UI.messagebox to display an error message.
However, on my system, this dialog box is showing behind the main Sketchup GUI, meaning I can't see it.
The only way to bring it back on top is to Alt-Tab to other applications and back.
obones
Postby sally » Tue Mar 10, 2020 3:44 pm
Hello Didier, will you be updating this for SU 2020. I am lost without it!! Complement perdue!
Merci beaucoup :D
sally
Premium Member
Premium Member
Postby TIG » Tue Mar 10, 2020 4:16 pm
@sally
It isn't signed for newer SketchUp versions, but it should still work if you have your Extension Manager's > Extension Loading policy set to 'Unrestricted'...
Install it and try using it with the Ruby Console open...
If it works, fine - if it fails, then at least you'll see some error messages ??
Many older plugins are no longer being supported, and so they aren't signed for newer SketchUp 'full-compatibility' - however, many of them will still work...
Global Moderator
Postby Didier Bur » Wed Mar 11, 2020 7:03 am
I haven't SU2020 yet, but it works with my SU2019, apparently just a matter of loading policy, as TIG said.
Didier Bur
Didier Bur
Return to Plugins
Users browsing this forum: trong hoang and 12 guests
