SketchUcation Premium Membership
is disabling menu items and or tools possible?
Postby Maggy » Tue Nov 27, 2007 5:20 am
I know that it's very easy to add menu items, tool bars, context menu items with Ruby in Sketchup, but I tried to disable/hide/remove and as far as I can see that's not possible.
Any suggestions?
[Maggy]
Maggy
Re: is disabling menu items and or tools possible?
Postby azuby » Tue Nov 27, 2007 5:21 am
Remove/Hide: Not on the running process
Grey=Disable: Depends on the script
azuby
error initus :: Blocks | CurrentDate | d/Code | extensionmanager | FFlipper | HideEdges | MeasuredArea | ModelHistory* | PluginsHelp | PronButton | SAWSO | SCP | SU²CATT
Bad English? PM me, correct me. :)
azuby
Postby Maggy » Tue Nov 27, 2007 5:22 am
Thanks.
Grey sounds good enough. But the only grey I can find is in the class Color document.
Can you tell me where to find more information?
[Maggy]
Maggy
Postby azuby » Tue Nov 27, 2007 5:30 am
Yes, in the sketchup Ruby API documentation,
http://download.sketchup.com/sketchuphe ... ation_proc
But the example is a shame. So have a look on these few lines of code:
Code: Select all
grayed_proc = Proc.new { @active_model.path.empty? ? MF_GRAYED : MF_ENABLED }
azubymenu = UI.menu("Plugins").add_submenu "Cornflakes"
azuby_menu_item = azubymenu.add_item "Add milk" do
  UI.messagebox "Adding milk to your cornflakes"
azubymenu.set_validation_proc azuby_menu_item, &grayed_proc
# take care for the "&" or write the line:
azubymenu.set_validation_proc azuby_menu_item do
An equal usage is possible for toolbar items.
azuby
azuby
Postby Maggy » Tue Nov 27, 2007 5:31 am
Why didn't I get Ruby in school, when I was 10 years old or so? Now, 40 years later it's very hard to grasp. The most frustrating part it that it looks so easy when I read a perfectly functioning ruby script. But it looks just as easy in a script that's not doing what I expect it to do...
I copied your code to "cornflakes.rb", loaded it, it shows up in Plugins, it adds milk to my cornflakes, but I do not see it grey out any menu item. So I started editing, editing, editing, each time closing SU, restarting it, reloading Cornflakes.rb till the milk and cornflakes were coming out of my ears, but still no greyed out menu items.
[Maggy]
Maggy
Postby azuby » Tue Nov 27, 2007 5:32 am
Maybe because you have to set the @active_model before using the code - like this:
Code: Select all
@active_model = Sketchup.active_model
I haven't ried the code and at the moment I'm in university and do not have Sketchup installed. I'll care this evening, if it won't work as expected.
azuby
azuby
For me this code works with the additional line. I put it to a .rb file, load Sketchup, try to use Plugins > Cornflakes > Add mild, it is grayed, I open a .skp file and try the same and get my breakfest.
azuby
azuby
by Ad Machine » 5 minutes ago
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Developers' Forum
Who is online
Users browsing this forum: RustyT, treverth and 3 guests
