SketchUcation Premium Membership
[Plugin] Mullion, Screen or Grille tool
Postby tomot » Thu Sep 18, 2008 12:39 am
As with the WindowGlass.rb (aka simple gazing tool) and the WindowGlassFrame.rb I used the "pick 3 points rectangle" approach to install a screen, grille, or mullions into any rectangular opening.
This is the last of a 3 part set of Window Rubies. I was thinking to combining all three into one Ruby, but I get frustrated when I see a long lists, 10 to 12 lines of parameters, to fill out in a dialog box. Hence I left them as separate Rubies.
I can hardly wait to see the day when we have a proper GUI front end with 3d graphics, instead of these boring simple dialog boxes that we have now.
I hope you find all 3 useful. I would also like to thank Jim Folz for helping me with some of the coding.
I'm a 60 year old designer who happens to dabble in beginner Ruby programming. I would never have been able to manufacture any of these Rubies on my own. Without the benefit of being able to look at and study previous SU Rubies. I would like to thank those that left their code unscrambled, so I could learn a bit and share the results.
tomot
Operating system: Windows
SketchUp version: 8
License type: Free
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] Mullion, Screen or Grille tool
Postby digby dart » Thu Sep 18, 2008 5:42 am
Thank You tomot for another great ruby script. :D
digby dart
Postby Edson » Thu Sep 18, 2008 11:22 am
tomot wrote:As with the WindowGlass.rb (aka simple gazing tool) and the WindowGlassFrame.rb I used the "pick 3 points rectangle" approach to install a screen, grille, or mullions into any rectangular opening.
where can WindowGlassFrame.rb be downloaded from? i could not not find it here nor anywhere.
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
User avatar
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby tomot » Thu Sep 18, 2008 3:46 pm
Edson wrote:where can WindowGlassFrame.rb be downloaded from? i could not not find it here nor anywhere.
viewtopic.php?f=180&t=12615
tomot
SketchUp version: 8
License type: Free
Postby boofredlay » Thu Sep 18, 2008 4:07 pm
How is this different from Windowizer?
User avatar
boofredlay
Global Moderator
SketchUp version: 8
License type: Pro
Postby dtrarch » Thu Sep 18, 2008 4:16 pm
Tomot
Very helpfull tool and thanks a bunch.
dtr
dtrarch
Premium Member
Premium Member
Postby tomot » Thu Sep 18, 2008 5:09 pm
Boofredlay wrote:How is this different from Windowizer?
Windowizer asks for 4 sided face to be selected first. While I use the "pick 3 point rectangle" method.
This is not a criticism of how Windowizer works, it has more to do with my work flow.
I design structures in SU using walls and slabs that have thickness. Then I punch openings in them for windows, doors, stairs etc., later I fill in those openings with the required components.
I find the "pick 3 points rectangle' method the most natural way to fill in an opening. If I were to use Windowizer, I have to fill in the opening prior to running the script.
My window routines are not offset only from the front face they are pushpulled so they look the same from the inside.
But then again Windowizer can also draw windows that trapezoidal or parallelogram in shape which the "pick 3 point rectangle" method, cant imitate. So now you have an alternative way of doing windows :)
tomot
SketchUp version: 8
License type: Free
Postby boofredlay » Thu Sep 18, 2008 6:51 pm
Thanks for the explanation, much appreciated.
User avatar
boofredlay
Global Moderator
SketchUp version: 8
License type: Pro
Postby cyan.archnet » Fri Sep 19, 2008 6:27 am
very helpful script indeed!, thanks a lot!
cyan.archnet
Postby JGA » Fri Sep 19, 2008 7:46 am
Thanks very much!
Regards,
JGA
JGA
Postby Jim » Mon Sep 22, 2008 12:58 am
tomot has released an updated version of this plugin as part of a suite of WindowTools; see here:
viewtopic.php?f=180&t=12869
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Level of SketchUp: Intermediate
by Ad Machine » 5 minutes ago
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Premium Members get 20% discount!
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Bing [Bot], majid, reando, theflysurfer, xavier9 and 11 guests
