SketchUcation Premium Membership
[Plugin] Scaling to_cm
Postby sahi » Thu Jul 31, 2008 3:13 pm
A bit changed the tools of Scalin
mashtab_4.zip
sahi
Operating system: Windows
SketchUp version: pre-6
License type: Free/Make
SketchUp use: architecture
Level of SketchUp: Beginner
Re: Scaling to_cm
Postby pav_3j » Thu Jul 31, 2008 3:30 pm
sorry i'm confused, is this a scaling ruby?
pav
Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
pav_3j
Re: Scaling to_cm
Postby sahi » Thu Jul 31, 2008 3:38 pm
changes a model size.
sahi
Re: Scaling to_cm
Postby pav_3j » Thu Jul 31, 2008 3:41 pm
ah i see! i shall have a tinkle and see how i get on.
pav
pav_3j
Re: Scaling to_cm
Postby urgen » Thu Jul 31, 2008 3:53 pm
...it is "resize tool" more.. by axis... Useful idea,SAHI! :D
--pupil forever...------
User avatar
urgen
Re: Scaling to_cm
Postby stanmarsh » Thu Jul 31, 2008 4:34 pm
hi sahi thanks for this ruby! :ecstatic:
is there anyway to change it to meters?
stanmarsh
Re: Scaling to_cm
Postby sahi » Thu Jul 31, 2008 6:28 pm
stanmarsh wrote:is there anyway to change it to meters?
meters
mashtab.zip
sahi
Re: Scaling to_cm
Postby Didier Bur » Thu Jul 31, 2008 10:15 pm
This doesn't work here: it gives weird results, out of range, entities are moved elsewhere. If entities are not grouped at start, there are grouped at the end.
Am I missing something ???
Before/After a scale of 2:
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
User avatar
Didier Bur
SketchUp version: 8
License type: Pro
Level of SketchUp: Advanced
Re: Scaling to_cm
Postby sahi » Fri Aug 01, 2008 7:50 am
changed the names in a script
Menu > Plugins > Resizer
sahi
Re: Scaling to_cm
Postby N Lindenthal » Fri Aug 01, 2008 12:08 pm
On Mac I did not see the scaling tool palette. Is it Menu > Plugins > Scale?
N Lindenthal
Re: Scaling to_cm
Postby Didier Bur » Fri Aug 01, 2008 12:35 pm
Dialog is ambiguous: "on all of axes" is not a target size but adds entered size to actual size. The final size would be better IMHO ?
Why choosing the bounds center as the center of transformation ?
I suggest not to use "to_cm" or "to_m" in the code, but to use only Length type variables. Thus you will suit everyone's unit, no matter what it is.
Useful script, though.
User avatar
Didier Bur
SketchUp version: 8
License type: Pro
Re: Scaling to_cm
Postby sahi » Fri Aug 01, 2008 1:27 pm
Didier Bur wrote:Hi,
"on all of axes" ---How to name???
corrected all of other as you specified
sahi
Re: Scaling to_cm
Postby Didier Bur » Fri Aug 01, 2008 3:37 pm
Correct me if I'm wrong, but the resize operation works only for faces in XY,XZ and YZ planes (red,green,blue) ?
"On all of axes" -> "In every direction" ? English speaking people please help !
Another enhancement is to encapsulate in an operation for one step undo:
Code: Select all
def mashtabirovanie_create
Sketchup.active_model.start_operation "Resize"
ss=Sketchup.active_model.selection
Sketchup.active_model.select_tool(nil)
Sketchup.active_model.commit_operation
User avatar
Didier Bur
SketchUp version: 8
License type: Pro
Re: Scaling to_cm
Postby sahi » Fri Aug 01, 2008 3:52 pm
Didier Bur wrote:
Code: Select all
Thank you! Corrected a code.
Added an icon.
mashtab_3.zip
sahi
Re: Scaling to_cm
Postby CadFather » Fri Aug 01, 2008 5:24 pm
..growing into a nice little ruby.
Quarr-IT - SketchUp Training from the Master.. . ;) .
User avatar
CadFather
Re: Scaling to_cm
Postby ilay7k » Fri Aug 01, 2008 7:11 pm
Equal "In every direction" is global settings for object of selection(world scaling system in most graphic packages...in attached pic, like cinema4d)
or about directions of red,green,blue, Didier, you are right/something like object system/
ilay7k
SketchUp version: 8
Re: Scaling to_cm
Postby marcosrodrigues » Fri Aug 01, 2008 7:14 pm
Simple and very useful. Thank you!
| menos é mais
marcosrodrigues
Re: Scaling to_cm
Postby Fletch » Sat Aug 02, 2008 6:49 am
I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
Fletch
Twilight Render
Re: Scaling to_cm
Postby sahi » Wed Aug 06, 2008 6:36 pm
Fletch wrote:I would replace the "on all of axes" line with a checkbox called 'lock aspect ratio' as shown in attached. or just change the name to 'uniform scale'.
mashtab_4.zip
sahi
Re: [Plugin] Scaling to_cm
Postby unclebim » Thu Jun 07, 2012 9:17 pm
I don't get what should I input in the Lock aspect ratio box in order to get the selection scaled proportionally to exact dimension input in one axis?
unclebim
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Level of SketchUp: Intermediate
Postby Zacchia » Tue Jun 11, 2013 7:38 pm
I like it. Thanks!
SketchUp Pro, CasCADos, TheaRender, TwilightRender
Zacchia
by Ad Machine » 5 minutes ago
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: DETX, Google Feedfetcher, helldarc, sauerkrauten, ualuke and 15 guests
