Problem with pict as texture
General discussion related to SketchUp Pro and Make
Postby Edson » Fri Nov 23, 2007 6:44 am
in order to reduce the size of a file that has dozens of venetian blinds, a created an image of one to aply as a texture to a box.
I then tried to import it and use it via the colors panel, creating a new texture. it worked fine and the texture appeared as a thumbnail. but after selecting it and clicking on the face i wanted to apply it to, i got just a plain colored surface, not the texture i created, nor could i get to the texture position dialogue after double-clicking on it.
the only way to do it was to import the ima as texture via the File menu (File>>Import...).
any clues as to what can be happening that prevents me from using the first method?
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
User avatar
Edson
Global Moderator
Re: Problem with pict as texture
Postby Krisidious » Fri Nov 23, 2007 6:44 am
is it the scale of the image? is it high def?
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby Edson » Fri Nov 23, 2007 6:45 am
it may well be. any recommendations as to these? how big can be an image to be successfully imported as texture? what would be the optimum definition for it?
questions, questions...
User avatar
Edson
Global Moderator
Postby Krisidious » Fri Nov 23, 2007 6:45 am
well when you click on the face and or right click to texture... you should see the whole image... if you don't then there must be another issue. if you do, then you could just scale down.
By: Kristoff Rand
Home Designer
Unique House Plans
User avatar
Krisidious
Postby Chris Fullmer » Fri Nov 23, 2007 6:46 am
Any chance you were in shaded mode (versus shaded with textures mode)? If you wre in just shaded, it would appear as though it did not apply the texture correctly and it would only show a color. Just a thought,
User avatar
SketchUp Team
SketchUp Team
Postby Edson » Fri Nov 23, 2007 6:46 am
anything is possible. when i have a chance i will check it.
User avatar
Edson
Global Moderator
Postby John Sayers » Fri Nov 23, 2007 6:47 am
Sounds like the image is bigger than the plane you placed it on.
I usually create a flat surface and add the texture. I then 'resize' the surface to fit the image, i.e instead of the multiple tiled images you get. I then group it and 'rescale' it to fit the model.
User avatar
John Sayers
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: No registered users and 8 guests
Visit our sponsors:
