Jon wrote:I have to agree with plot-paris. It doesn't kep it's genuine texture in Kerkythea, either.
I find this very hard to believe!
[Plugin] UVTools v0.1Re: [Plugin] UVTools v0.1
Re: [Plugin] UVTools v0.1Well, it fails with every model I've exported so far, but here's the most recent one.
With some models, there seems to be the change of the actual texture when exporting. The other spheres surrounding the model are the atmosphere and cloud layer. Thanks again, Whaat! Please, register (free) to access all the attachments on the forums.
Thanks, Jon. This seems to be an issue with non-triangular faces. If you can somehow triangulate the geometry prior to exporting, then the UVs should still be correct. My 'Polyreducer' script triangulates all of the faces of a mesh. However, it will also reduce some polys. (The minimum is 10%). Once I triangulated your spheres, I reapplied the spherical mapping and then exported to Indigo. It worked perfect! I expect it to work with other rendering engines as well. Another script that will triangulate faces is my 'SubD and Smooth' script (but it's not free) Thanks for posting the scene!
Re: [Plugin] UVTools v0.1and here we go - with a perfect spherical mapping in Indigo!
triangulated faces. thanks whaat, that really did the trick
Re: [Plugin] UVTools v0.1Thanks for the plugin.
Re: [Plugin] UVTools v0.1Excellent work, Dale. The key to decent spherical mapping lies in a combination of triangular faces (no real surprise there) plus enough of them to do the job. Attached is the standard SU sphere which has been given 2 iterations of Subdivide and Smooth to produce much smaller triangles, then a spherical map of the Earth applied. The result is about as good as it gets.
My sincere compliments. I haven't tried it yet, but it may be possible to raise the resolution of the mesh in just the polar regions and achieve pretty much the same result but with far fewer faces. Please, register (free) to access all the attachments on the forums. FormFonts
If Wile E.Coyote has enough money to buy all that Acme crap, why can't he just buy dinner?
Re: [Plugin] UVTools v0.1Nice results Alan!
I wil give the plugin a spin this weekend. Another cool Whaat piece of work.
Re: [Plugin] UVTools v0.1Dear Alan,
Could you give a little tut to show how you map the texture onto the sphere using the various tool? I cannot quite see how it all hangs together. Thanks, Bob
Re: [Plugin] UVTools v0.1It's fairly straightforward, Bob.
I imported the sphere from Shapes and exploded it. I then applied Subdivide and Smooth with 2 iterations (it maps reasonably well with just 1, but 2 is better) I then resized the sphere to exactly 10' diameter...it's a tad larger than that by default. I imported the image and exploded it, then edited its height in the Material Editor to match the sphere's diameter. I then applied the image, from the Material browser to the sphere. I then right-clicked the sphere and chose UV Tools > Spherical from the context menu....and Bingo! That's all there is to it. FormFonts
Resizing the image before using the plugin is an unecessary step. The plugin will always map the image the full height of the sphere and wrap it exactly once around the sphere.
Re: [Plugin] UVTools v0.1Thanks Dale. I should have figured that with no adjustment controls, it would be set to fit. I've only just taken a look now at the code.
FormFonts
Many thanks for the detailed explanation. As I wrote somewhere else, I tend not to texture my models, being content with the default shades, and so I haven't built up any skill in this area. Thanks again, and thanks to Dale for another useful script. The model of the globe is really very impressive. I must have a go at Mars. Kind regards, Bob
Re: [Plugin] UVTools v0.1Bob,
You'll find some decent planet maps here. http://planetpixelemporium.com/planets.html The individual planets are linked at the bottom of the page. The maps are distorted because in order to fit a sphere the entire top and bottom edges need to come to a single point at either pole, so you'll appreciate that things get progressively stretched as you move away from the equator. You don't need to start from scratch. You can merely open the Earth globe skp, go to the Material browser...In Model, select the Earth texture then in edit mode replace the earth.jpg with one of the planetary ones you download from the above site. It will map automatically. FormFonts
Re: [Plugin] UVTools v0.1Thanks for both the tut' and the link to the planet texture maps, Alan..!!
Much appreciated..!!
Many thanks for taking the time to post the link. I will have a go at that when I have a moment. I would also to create a background/sky dome simulation of Mars too. The reason for that is we have a couple of projects which involve instruments for Martian atmosphere monitoring, and it would be rather nice to see the lander in a Martian setting. Alternatively, I could get on with some real work. Kind regards, Bob
Re: [Plugin] UVTools v0.1i had a play with the plguin and found if i reduced the texture scale just a bit the mapping at the poles tended to clear.
Also exported to Maxwell with no issues!!! Whaat again you do some absolutely amazing stuff mate!
Re: [Plugin] UVTools v0.1hi there.
Is it not possible to re write the plugin to see the mapping box,a way to scale the box or edit and maybe include a box mapping too. Similar to what max is doing.But from me to you...congrats..its super so far.
Re: [Plugin] UVTools v0.1i tried the ruby , but there is a problem when exporting to Kerkythea ..... it converts the shape to lots of faces whit lots of textures!!!!!!!!!!!!!! would be it reviewed to solve this problem?
yours majid درصورتيكه به مساله اي برخورديد(مثل وارد نشدن به سايت، فراموش كردن پسورد و غیره با ما تماس بگیریدhttp://sketchucation.com/contact
Re: [Plugin] UVTools v0.1Majid,
Whaat have already provided an answer to this...
Below is made using the SubD and Smooth script and exported using SU2KT... Works like a charm...!! ![]() Please, register (free) to access all the attachments on the forums.
Re: [Plugin] UVTools v0.1 thank you!!! good!!!
Re: [Plugin] UVTools v0.1Just catching up with all the news here...
Great plugin, thanks a lot! I discovered however that if you want to UV map something on a reversed face, it gives a bugsplat. No worry about this at all though - at least it will teach everyone the lesson; "always orient your faces correctly"! Gai...
Re: [Plugin] UVTools v0.1That lead flashing must have been rather tricky to fit!!
You can already do this to a limited degree in SU by positioning a texture using the right-click context menu. Then, sample that texture with the ink-dropper prior to painting on an adjacent face. The UV mapping will then be continuous around the edge. The sample image you posted can already be done in SU. I am sure of it. I will try to recreate a similar scene using displacement mapping with only SU and Indigo to test my theory.
Re: [Plugin] UVTools v0.1Oh cool!
You weren't referring to the projected method are you? ...but to the method to texture a cilinder, right? (as in the video tuorials that once were on the official SU site).
Re: [Plugin] UVTools v0.1Like, turning on "hidden geometry", then sample the texture, and paint it on the faces that have appeared due to turning on "hidden geo"?
Bill Maher on the French: "They invented sex during the day, lingerie and the tongue."
Re: [Plugin] UVTools v0.1If you smooth the corners (bevel) and apply that awesome arroway texture, would it not work?
SketchUcation One-Liner AdvertsKeyframe Animation plugin - animate your SketchUp model by adding movement to any object.
Premium Members get 20% discount!
